Fires
8 October 2020 17:52
1
Was Reading this Thread
[HowTo] make a crash-proof backup for Manjaro - Contributions / Tutorials - Manjaro Linux Forum
witch Directed me here
https://wiki.manjaro.org/index.php/Arch_User_Repository#Accessing_the_AUR
pamac install base-devel git
There are 24 members in group base-devel:
1: autoconf 2.69-7 core
2: automake 1.16.2-3 core
3: binutils 2.35-2 core
4: bison 3.6.4-1 core
5: fakeroot 1.24-2 core
6: file 5.39-1 core
7: findutils 4.7.0-2 core
8: flex 2.6.4-3 core
9: gawk 5.1.0-1 core
10: gcc 10.2.0-2 core
11: gettext 0.21-1 core
12: grep 3.4-1 core
13: groff 1.22.4-3 core
14: gzip 1.10-3 core
15: libtool 2.4.6+42+gb88cebd5-14 core
16: m4 1.4.18-3 core
17: make 4.3-3 core
18: pacman 5.2.2-2 core
19: patch 2.7.6-8 core
20: pkgconf 1.7.3-1 core
21: sed 4.8-1 core
22: sudo 1.9.3.p1-1 core
23: texinfo 6.7-3 core
24: which 2.21-5 core
Enter a selection (default=all): all
Preparing...
Nothing to do.
~ >>> git clone https://aur.archlinux.org/foo.git
fatal: destination path 'foo' already exists and is not an empty directory.
~ >>> cd foo [128]
~/foo >>> makepkg -s ±[master]
==> ERROR: foo is not available for the 'x86_64' architecture.
~/foo >>> ±[master]
Strit
8 October 2020 17:55
2
Check that the “foo” package PKGBUILD has “x86_64” in it’s arch=()
array.
PS: I can’t find a foo package in the AUR, so I assume you have replaced the real pkgname with foo in this example.
Strit
8 October 2020 17:58
4
Open the PKGBUILD file in a text editor.
Fires
8 October 2020 17:59
5
pkgver=1.0.0
pkgrel=1
pkgdesc="Test package"
arch=('all')
licence=('GPL')
build() {
cd .
package() {
cd .
Strit
6
Change arch=('all')
to arch=('any')
and it should work.
Fires
8 October 2020 18:05
7
ur the best
It Worked
~/foo >>> makepkg -s ±[●][master]
==> Making package: foo 1.0.0-1 (Do 08 Okt 2020 20:00:51 CEST)
==> Retrieving sources...
==> Extracting sources...
==> Starting build()...
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "foo"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: foo 1.0.0-1 (Do 08 Okt 2020 20:00:52 CEST)
~/foo >>> ls ±[●●][master]
foo-1.0.0-1-any.pkg.tar.xz pkg PKGBUILD src
~/foo >>> sudo pacman -U foo.pkg.zst ±[●●][master]
[sudo] password for tempo:
loading packages...
error: 'foo.pkg.zst': could not find or read package
~/foo >>> sudo pacman -U foo-1.0.0-1-any.pkg.tar.xz ±[●●][master]
loading packages...
resolving dependencies...
Packages (1) foo-1.0.0-1
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [######################] 100%
(1/1) checking package integrity [######################] 100%
(1/1) loading package files [######################] 100%
(1/1) checking for file conflicts [######################] 100%
(1/1) checking available disk space [######################] 100%
(1/1) installing foo [######################] 100%
~/foo >>> ```
A Fast Question
So I don't need to do these last 2 commands any more correct ?
makepkg -i and makepkg -is
Fires
8 October 2020 18:06
8
A Fast Question
So I don’t need to do these last 2 commands any more correct ?
Strit
8 October 2020 18:08
9
makepkg -si
does what makepkg -i
does, so you only need to do the -si
one.
But no, you don’t need to do that, when you did pacman -U.
When you build the package again with makepkg, you can simply do makepkg -si
and it will build and install the package and it’s dependencies. So you don’t need the pacman -U
command.
guinux
12 October 2020 17:14
10
You can also use pamac build
command with no argument to build and install from the PKGBUILD in the current directory. It automatically check for base-devel packages and other dependencies needed.
Fires
12 October 2020 17:22
11
guinux:
pamac build
Can u please show me a command example for pacman build ?
Thank u
pamac build google-chrome
system
Closed
27 October 2020 17:48
14
