I restarted my computer to install a GPU that i plan on using for virtualization GPU passthrough, but i’m still using my original gpu, and displays fine.
But then Firefox tabs started crashing randomly, and firefox too.
So i installed Chromium cause i thought Mozilla is having issues.
Then chromium crashed as well.
Then i wanted to restart the computer and got this:
There was one more that appeared before it actually restarted, and i got one of those before the login screen showed up.
What’s happening?
EDIT: The “boot” LED on my Asrock B550m mobo was flashing, not sure if that’s related.
EDIT2:
I thought it was maybe a failing ssd (though it shouldn’t it’s new), so i installed smartctl and this is the output from smartctl -a /dev/nvme0n1.
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.1.0-x64v1-xanmod1-MANJARO] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number: KINGSTON SNV2S500G
Serial Number: 50026B7282DB8CBD
Firmware Version: SBI02102
PCI Vendor/Subsystem ID: 0x2646
IEEE OUI Identifier: 0x0026b7
Controller ID: 1
NVMe Version: 1.4
Number of Namespaces: 1
Namespace 1 Size/Capacity: 500.107.862.016 [500 GB]
Namespace 1 Formatted LBA Size: 512
Namespace 1 IEEE EUI-64: 0026b7 282db8cbd5
Local Time is: Thu Jan 5 15:47:21 2023 CET
Firmware Updates (0x12): 1 Slot, no Reset required
Optional Admin Commands (0x0016): Format Frmw_DL Self_Test
Optional NVM Commands (0x009f): Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat Verify
Log Page Attributes (0x12): Cmd_Eff_Lg Pers_Ev_Lg
Maximum Data Transfer Size: 64 Pages
Warning Comp. Temp. Threshold: 83 Celsius
Critical Comp. Temp. Threshold: 90 Celsius
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
0 + 5.00W - - 0 0 0 0 0 0
1 + 3.50W - - 1 1 1 1 0 200
2 + 2.50W - - 2 2 2 2 0 1000
3 - 1.50W - - 3 3 3 3 5000 5000
4 - 1.50W - - 4 4 4 4 20000 70000
Supported LBA Sizes (NSID 0x1)
Id Fmt Data Metadt Rel_Perf
0 + 512 0 0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning: 0x00
Temperature: 31 Celsius
Available Spare: 100%
Available Spare Threshold: 10%
Percentage Used: 0%
Data Units Read: 2.637.030 [1,35 TB]
Data Units Written: 3.377.737 [1,72 TB]
Host Read Commands: 24.849.753
Host Write Commands: 28.558.357
Controller Busy Time: 3.309
Power Cycles: 109
Power On Hours: 702
Unsafe Shutdowns: 3
Media and Data Integrity Errors: 0
Error Information Log Entries: 0
Warning Comp. Temperature Time: 0
Critical Comp. Temperature Time: 0
Error Information (NVMe Log 0x01, 16 of 64 entries)
No Errors Logged
So the disk seems fine. No idea why the boot LED is flashing red.
EDIT3: inxi -Fza
Kernel: 6.1.0-x64v1-xanmod1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 12.2.0 parameters: BOOT_IMAGE=/@/boot/vmlinuz-manjaro-xanmod
root=UUID=27a6f9c0-8b45-42c5-85e1-be095307048f rw rootflags=subvol=@
amdgpu.gpu_recovery=1 audit=0 quiet splash
resume=UUID=b58bc35c-1a93-4c4c-a1ec-5eefe535dea6 udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: B550M Pro4 serial: N/A UEFI: American
Megatrends LLC. v: P2.30 date: 02/24/2022
Info: model: AMD Ryzen 5 5600G with Radeon Graphics socket: AM4 bits: 64
type: MT MCP arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3900 min/max: 1400/4464 boost: enabled
base/boost: 3900/4450 scaling: driver: acpi-cpufreq governor: performance
volts: 1.4 V ext-clock: 100 MHz cores: 1: 3900 2: 3900 3: 3900 4: 3900
5: 3900 6: 3900 7: 3900 8: 3900 9: 3900 10: 3900 11: 3900 12: 3900
bogomips: 93418
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Bonaire XTX [Radeon R7 260X/360] vendor: PC Partner / Sapphire
driver: radeon v: kernel alternate: amdgpu arch: GCN-2 code: Sea Islands
process: GF/TSMC 16-28nm built: 2013-17 pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: none empty: DP-1, DVI-D-1, DVI-I-1, HDMI-A-1
bus-ID: 01:00.0 chip-ID: 1002:6658 class-ID: 0300 temp: 31.0 C
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
driver: amdgpu v: kernel arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm)
built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: DP-2,HDMI-A-2 empty: DP-3 bus-ID: 06:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 30.0 C
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: kwin_x11 driver: X: loaded: radeon unloaded: amdgpu,modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.31x15.00")
s-diag: 1407mm (55.38")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,left
model: AOC Q3279WG5B serial: <filter> built: 2020 res: 2560x1440 dpi: 90
gamma: 1.2 size: 725x428mm (28.54x16.85") diag: 842mm (33.1") ratio: 15:9
modes: max: 2560x1440 min: 720x400
Monitor-2: HDMI-A-2 mapped: HDMI-A-1 pos: right model: AOC Q3279WG5B
serial: <filter> built: 2020 res: 2560x1440 dpi: 90 gamma: 1.2
size: 725x428mm (28.54x16.85") diag: 842mm (33.1") ratio: 15:9 modes:
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.49 6.1.0-x64v1-xanmod1-MANJARO) direct render: Yes
Device-1: AMD Tobago HDMI Audio [Radeon R7 360 / R9 OEM]
vendor: PC Partner / Sapphire driver: snd_hda_intel v: kernel
bus-ID: 3-2.2:4 pcie: chip-ID: 1235:8200 class-ID: 0103 gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aac0 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Focusrite-Novation Scarlett 2i4 USB type: USB
driver: snd-usb-audio
Sound API: ALSA v: k6.1.0-x64v1-xanmod1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-1: JACK v: 1.9.21 running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 3-2.1:3 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 698.65 GiB used: 164.59 GiB (23.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: SBI02102 temp: 29.9 C scheme: GPT
SMART: yes health: PASSED on: 29d 7h cycles: 109
read-units: 2,637,082 [1.35 TB] written-units: 3,378,709 [1.72 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
family: based SSDs size: 232.89 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 1B6Q temp: 27 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 314d 2h cycles: 2080
written: 34.03 TiB
ID-1: / raw-size: 448.97 GiB size: 448.97 GiB (100.00%)
used: 164.58 GiB (36.7%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 608 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 448.97 GiB size: 448.97 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 448.97 GiB size: 448.97 GiB (100.00%)
maj-min: 259:2
Kernel: swappiness: 30 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: partition size: 16.5 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 38.5 C mobo: N/A
GPU: device: amdgpu temp: 31.0 C device: radeon temp: 31.0 C
Processes: 313 Uptime: 35m wakeups: 0 Memory: 15.01 GiB
used: 3.28 GiB (21.8%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1619 libs: 469 tools: pamac pm: flatpak pkgs: 0 Shell: Bash (su)
v: 5.1.16 running-in: konsole inxi: 3.3.24
