Im trying for a couple of days now, but can’t get it right. I have this defined in user and root .bashrc
export ANDROID_SDK=$PATH:/opt/android-sdk
export ANDROID_PATH=$PATH:/opt/android-sdk/tools:$PATH:opt/android-sdk/platform-tools
export PATH=$PATH:$ANDROID_PATH:$FLUTTER
on flutter doctor i get
[ ! ] Unable to locate Android SDK
No valid Android SDK platforms found in /opt/android-sdk/platforms.
Candidates were:
- android-30
but i got exactly this sdk version…
error message return “bad” platforms …
I guess you don’t have a platform installed?
ls -l /opt/android-sdk/platforms
# for me :
#drwxr-xr-x 6 patrick users 4,0K 27 févr. 15:05 android-24
#drwxr-xr-x 6 patrick users 4,0K 26 févr. 22:34 android-29
#drwxr-xr-x 6 patrick users 4,0K 26 févr. 21:32 android-30
and run :
avdmanager list target
#(same result as ls)
avdmanager list avd
# if empty : create one
typo error in 3 lines :
ANDROID_SDK : not add $PATH
ANDROID_PATH : not add $PATH and add root at opt/ : /opt
$PATH : (view @Yochanan )
return :
env | grep -Ei “android|path|flutter”
how to installed android-sdk ? is aur package ? if yes var is set in package…
sorry, that i did mistype here only. On bashrc it is actually export
BAL3IA:
Just making sure.
RTFM (Read The Friendly Manual)
Get started with Flutter. Widgets, examples, updates, and API docs to help you write your first Flutter app.
for me
returned:
total 4
drwxr-xr-x 6 root root 4096 jul 31 18:17 android-30
Availabe Android targets:==========] 100% Fetch remote reporsitory....
id: 1 or "android-30"
Name: Android API 30
TYpe: Platform
API leve: 30
Revision: 3
and avdmanager list avd
Availabe Android Virtual Devices:
here
ADROID_PATH : not add $PATH and add root at opt/ : `/opt
you meant like this?
export ANDROID_PATH=/opt/android-sdk/tools:$ROOT:opt/android-sdk/platform-tools
My .bashrc is growing large
export ANDROID_SDK_ROOT=/opt/android-sdk/
export ANDROID_SDK_HOME=/home/gabriel/.android/
export ANDROID_AVD_HOME=/home/gabriel/.android/avd/
export ANDROID_EMULATOR_HOME=//home/gabriel/.android/
export ANDROID_PATH=$ANDROID_SDK_ROOT:/tools/:$ANDROID_SDK_ROOT:/platform-tools/
export FLUTTER="$PATH:/home/gabriel/Flutter/Flutter 2.2.3/flutter/bin"
ok, you have android-30 == android 11
“Android Virtual Devices” is empty ! it’s at us to create one android emulator
can create with android-studio gui or
sdkmanager --install "system-images;android-30;default;x86"
avdmanager create avd -n flutter -k "system-images;android-30;default;x86"
where did you find your environment variables? (not in doc, not in aur packages…)
I have (as aur package) only for flutter:
FLUTTER_ROOT= and i repeat: not add $PATH in this variable !
if we not have chrome but chromium, add var CHROME_EXECUTABLE=chromium
no sens : you set 4 bad path, for set 2 path:
export ANDROID_PATH=$ANDROID_SDK_ROOT/tools/:$ANDROID_SDK_ROOT/platform-tools/
at you to verify after close/open terminal
env | grep -Ei "android|path|flutter"
Hello there, and thanks for your time.
I just restored my system and installed all again, and it is partially working now, except the avd emulator will always crash my system - it will start, than memory consuption will start growing larger, and larger till the system freezes completely
for the paths, i found this post on SO ( https://stackoverflow.com/questions/26483370/android-emulator-error-message-panic-missing-emulator-engine-program-for-x86/49511666 ) where someone advised to write this in bashrc:
export ANDROID_SDK=$HOME/Library/Android/sdk
export PATH=$ANDROID_SDK/emulator:$PATH
export PATH=$ANDROID_SDK/tools:$PATH
export PATH=$ANDROID_SDK/tools/bin:$PATH
export PATH=$ANDROID_SDK/platform-tools:$PATH
export ANDROID_SDK_ROOT=$ANDROID_SDK
export ANDROID_AVD_HOME=$HOME/.android/and
alias emulator='$ANDROID_SDK/emulator/emulator'
i did, and it is working… dont know if all lines are essential
Hey guys, as my problem with the paths are over and the avd issues are another subject, im going to mark as solved. thansk!
system
Closed
19 August 2021 17:29
11
