Hello there,
I noticed that recently Flowblade just will not start on Manjaro i3.
I’m running this on an ASUS X555L, and Flowblade had been working fine previously.
Here’s the last bit of the output when I try to run from urxvt:
fbdev
oss
pulse
sdl,sdl2
video4linux2,v4l2
xv
MLT detection succeeded, 179 formats, 117 video codecs and 80 audio codecs found.
574 MLT services found.
Loading render profiles…
Loading filters…
Loading transitions…
RGB Adjustment dropped for Color Adjustment
Hue dropped for Color Adjustment
Gamma dropped for Lift Gain Gamma
G’MIC found
Player initialized with profile: HD 1080p 30 fps
Selected color NOT detected
BG color detected
Create SDL1 consumer…
No user folders actions needed.
zsh: segmentation fault (core dumped) flowblade
Basically some of the windows seem to open but look like just outlines of windows, then they disappear after a few seconds. What should I do? Kernel 5.10.129-1 MANJARO with i3 as WM.
Thanks
Hello,
This looks a lot like this old (closed/fixed) issue
opened 08:58PM - 16 May 18 UTC
closed 09:58PM - 16 Feb 19 UTC
fixed
On Manjaro (unstable branch) and apparently Archlinux in general, the update to … **mlt 6.8.0** (and also **python2** to **2.7.15** seems to have broken flowblade.
More details on the segfault [here](https://github.com/jliljebl/flowblade/issues/445#issuecomment-389465290)
On the other hand, looks like this issue might affect your install too
opened 02:41PM - 13 Jun 22 UTC
1) Flowblade version (Help->About):
2.8.0.3
2) MLT version (Help->Runtime En… vironment):
7.4.0
3) Your distribution (Ubuntu, Debian, Mint etc.):
Fedora 36 , MATE/Compiz DE
4) If possible, try to provide step-by-step instructions on how to reproduce the issue.
Try to run flowblade.
When ran from a terminal, I get this :
[~]:$ flowblade
FLOWBLADE MOVIE EDITOR 2.8
Launch script dir: /usr/bin
Running from installation...
/usr/bin/flowblade:39: DeprecationWarning: The distutils package is deprecated and slated for removal in Python 3.12. Use setuptools or check PEP 632 for potential alternatives
from distutils.sysconfig import get_python_lib
/usr/bin/flowblade:39: DeprecationWarning: The distutils.sysconfig module is deprecated, use sysconfig instead
MLT found, version: 7.4.0
numpy version: 1.22.0
Application version: 2.8.0
OS: Fedora Linux 36 (MATE-Compiz)
Python 3.10.4 (main, Mar 25 2022, 00:00:00) [GCC 12.0.1 20220308 (Red Hat 12.0.1-0)]
GTK+ version: 3.24.34
XDG user data exists.
Locale: fr_FR
Found translations at /usr/share/locale, using those.
Use OS locale language.
Valid shortcut files found: ['flowblade.xml', 'premiere.xml']
Keyboard shortcuts file: flowblade.xml
Gtk version is 3.24.34, Flowblade theme is available.
Using Full Screen size for layout: 3600 x 1080
Small height: False
Small width: False
Detecting environment...
video_codecs:
- a64multi
- a64multi5
- alias_pix
- amv
- apng
- asv1
- asv2
- avrp
- avui
- ayuv
- bitpacked
- bmp
- cfhd
- cinepak
- cljr
- dnxhd
- dpx
- dvvideo
- exr
- ffv1
- ffvhuff
- fits
- flashsv
- flashsv2
- flv
- gif
- h261
- h263
- h263p
- hap
- huffyuv
- jpeg2000
- jpegls
- ljpeg
- magicyuv
- mjpeg
- mpeg1video
- mpeg2video
- mpeg4
- msmpeg4v2
- msmpeg4
- msvideo1
- pam
- pbm
- pcx
- pfm
- pgm
- pgmyuv
- png
- ppm
- prores
- prores_aw
- prores_ks
- qtrle
- r10k
- r210
- rawvideo
- roqvideo
- rpza
- rv10
- rv20
- sgi
- smc
- snow
- speedhq
- sunrast
- svq1
- targa
- tiff
- utvideo
- v210
- v308
- v408
- v410
- vc2
- wrapped_avframe
- wmv1
- wmv2
- xbm
- xface
- xwd
- y41p
- yuv4
- zlib
- zmbv
- libaom-av1
- libopenjpeg
- librav1e
- libsvtav1
- libtheora
- libvpx
- libvpx-vp9
- libwebp_anim
- libwebp
- libx264
- libx264rgb
- libx265
- libxvid
- h263_v4l2m2m
- h264_amf
- h264_nvenc
- h264_qsv
- h264_v4l2m2m
- h264_vaapi
- hevc_amf
- hevc_nvenc
- hevc_qsv
- hevc_v4l2m2m
- hevc_vaapi
- mjpeg_qsv
- mjpeg_vaapi
- mpeg2_qsv
- mpeg2_vaapi
- mpeg4_v4l2m2m
- vp8_v4l2m2m
- vp8_vaapi
- vp9_vaapi
- vp9_qsv
audio_codecs:
- comfortnoise
- s302m
- aac
- ac3
- ac3_fixed
- alac
- aptx
- aptx_hd
- dca
- eac3
- flac
- g723_1
- mlp
- mp2
- mp2fixed
- nellymoser
- opus
- real_144
- sbc
- sonic
- sonicls
- truehd
- tta
- vorbis
- wavpack
- wmav1
- wmav2
- pcm_alaw
- pcm_dvd
- pcm_f32be
- pcm_f32le
- pcm_f64be
- pcm_f64le
- pcm_mulaw
- pcm_s8
- pcm_s8_planar
- pcm_s16be
- pcm_s16be_planar
- pcm_s16le
- pcm_s16le_planar
- pcm_s24be
- pcm_s24daud
- pcm_s24le
- pcm_s24le_planar
- pcm_s32be
- pcm_s32le
- pcm_s32le_planar
- pcm_s64be
- pcm_s64le
- pcm_u8
- pcm_u16be
- pcm_u16le
- pcm_u24be
- pcm_u24le
- pcm_u32be
- pcm_u32le
- pcm_vidc
- roq_dpcm
- adpcm_adx
- adpcm_argo
- g722
- g726
- g726le
- adpcm_ima_amv
- adpcm_ima_alp
- adpcm_ima_apm
- adpcm_ima_qt
- adpcm_ima_ssi
- adpcm_ima_wav
- adpcm_ima_ws
- adpcm_ms
- adpcm_swf
- adpcm_yamaha
- libgsm
- libgsm_ms
- libilbc
- libmp3lame
- libopencore_amrnb
- libopus
- libspeex
- libtwolame
- libvo_amrwbenc
- libvorbis
formats:
- a64
- ac3
- adts
- adx
- aiff
- alp
- amr
- amv
- apm
- apng
- aptx
- aptx_hd
- argo_asf
- argo_cvg
- asf
- ass
- ast
- asf_stream
- au
- avi
- avm2
- avs2
- avs3
- bit
- caf
- cavsvideo
- codec2
- codec2raw
- crc
- dash
- data
- daud
- dirac
- dnxhd
- dts
- dv
- eac3
- f4v
- ffmetadata
- fifo
- fifo_test
- filmstrip
- fits
- flac
- flv
- framecrc
- framehash
- framemd5
- g722
- g723_1
- g726
- g726le
- gif
- gsm
- gxf
- h261
- h263
- h264
- hash
- hds
- hevc
- hls
- ico
- ilbc
- image2
- image2pipe
- ipod
- ircam
- ismv
- ivf
- jacosub
- kvag
- latm
- lrc
- m4v
- md5
- matroska
- matroska
- microdvd
- mjpeg
- mlp
- mmf
- mov
- mp2
- mp3
- mp4
- mpeg
- vcd
- mpeg1video
- dvd
- svcd
- mpeg2video
- vob
- mpegts
- mpjpeg
- mxf
- mxf_d10
- mxf_opatom
- null
- nut
- obu
- oga
- ogg
- ogv
- oma
- opus
- alaw
- mulaw
- vidc
- f64be
- f64le
- f32be
- f32le
- s32be
- s32le
- s24be
- s24le
- s16be
- s16le
- s8
- u32be
- u32le
- u24be
- u24le
- u16be
- u16le
- u8
- psp
- rawvideo
- rm
- roq
- rso
- rtp
- rtp_mpegts
- rtsp
- sap
- sbc
- scc
- film_cpk
- segment
- stream_segment,ssegment
- smjpeg
- smoothstreaming
- sox
- spx
- spdif
- srt
- streamhash
- sup
- swf
- tee
- 3g2
- 3gp
- mkvtimestamp_v2
- truehd
- tta
- ttml
- uncodedframecrc
- vc1
- vc1test
- voc
- w64
- wav
- webm
- webm_dash_manifest
- webm_chunk
- webp
- webvtt
- wsaud
- wtv
- wv
- yuv4mpegpipe
- chromaprint
- alsa
- fbdev
- opengl
- oss
- pulse
- sdl,sdl2
- video4linux2,v4l2
MLT detection succeeded, 180 formats, 118 video codecs and 83 audio codecs found.
614 MLT services found.
Loading render profiles...
Loading filters...
MLT service ladspa.1406 not found.
MLT service ladspa.1433 not found.
MLT service ladspa.1408 not found.
MLT service ladspa.1431 not found.
MLT service ladspa.1901 not found.
MLT service ladspa.1438 not found.
MLT service ladspa.1195 not found.
MLT service ladspa.1402 not found.
MLT service ladspa.1185 not found.
MLT service ladspa.1213 not found.
MLT service ladspa.1904 not found.
MLT service ladspa.1903 not found.
MLT service ladspa.1215 not found.
MLT service ladspa.1216 not found.
MLT service ladspa.1410 not found.
MLT service ladspa.1892 not found.
MLT service ladspa.1194 not found.
MLT service ladspa.1197 not found.
MLT service ladspa.1423 not found.
MLT service ladspa.1910 not found.
MLT service ladspa.1417 not found.
MLT service ladspa.1210 not found.
MLT service ladspa.1198 not found.
MLT service ladspa.1905 not found.
MLT service ladspa.1201 not found.
Loading transitions...
MLT transition region not found.
G'MIC found
BG color detected
Create SDL1 consumer...
Erreur de segmentation (core dumped)
