Hardware
Lenovo T14s with AMD Ryzen Pro 7
inxi -b
Host: my-pc Kernel: 5.10.148-1-MANJARO arch: x86_64 bits: 64 Console: pty pts/0
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20UJS00K00 v: ThinkPad T14s Gen 1
serial: <superuser required>
Mobo: LENOVO model: 20UJS00K00 serial: <superuser required> UEFI: LENOVO v: R1CET61W(1.30 )
date: 12/21/2020
ID-1: BAT0 charge: 29.3 Wh (58.1%) condition: 50.4/57.0 Wh (88.3%) volts: 11.5 min: 11.5
Info: 8-core AMD Ryzen 7 PRO 4750U with Radeon Graphics [MT MCP] speed (MHz): avg: 1397
min/max: 1400/1700
Device-1: AMD Renoir driver: amdgpu v: kernel
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
Display: server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3 driver: X: loaded: amdgpu
unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu tty: 120x30 resolution: 1920x1080
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi
Local Storage: total: 953.87 GiB used: 105.38 GiB (11.0%)
Processes: 339 Uptime: 26m Memory: 30.65 GiB used: 1.12 GiB (3.7%) Init: systemd Shell: Zsh
inxi: 3.3.22
Manjaro
cat /etc/os-release
NAME="Manjaro Linux"
ID=manjaro
ID_LIKE=arch
BUILD_ID=rolling
PRETTY_NAME="Manjaro Linux"
ANSI_COLOR="32;1;24;144;200"
HOME_URL="https://manjaro.org/"
DOCUMENTATION_URL="https://wiki.manjaro.org/"
SUPPORT_URL="https://manjaro.org/"
BUG_REPORT_URL="https://bugs.manjaro.org/"
LOGO=manjarolinux
uname -a
Linux my-pc 5.10.148-1-MANJARO #1 SMP PREEMPT Sat Oct 15 13:41:09 UTC 2022 x86_64 GNU/Linux
Steps
After the updates were available
sudo pamac update
I was able to download all the necessary packages as well as the process was able to generate the respective initramdisk which generally happens at the last stage of the command above.
I then triggered a reboot:
sudo reboot
Upon reboot, the display manager screen is completely frozen and even moving to TTY consoles takes about close to 5-10 minutes. I was luckily able to log into a TTY Console and I ran the following:
sudo dmesg | grep -i "error"
I get:
[ 1327.409562] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1337.436234] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1347.462915] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:52:plane-3] flip_done timed out
[ 1357.489569] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1367.516318] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1377.542905] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:52:plane-3] flip_done timed out
[ 1387.569560] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1397.596242] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1407.622892] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:52:plane-3] flip_done timed out
[ 1417.649330] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1427.676230] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1437.702915] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:52:plane-3] flip_done timed out
[ 1447.729574] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1457.756234] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1467.782955] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:52:plane-3] flip_done timed out
[ 1477.809571] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1487.836225] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1497.862893] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:52:plane-3] flip_done timed out
[ 1507.889562] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1517.916221] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1527.942885] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:52:plane-3] flip_done timed out
[ 1537.969553] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1547.996231] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1558.022881] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:52:plane-3] flip_done timed out
[ 1568.049541] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1578.076211] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1588.102881] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:52:plane-3] flip_done timed out
[ 1598.129546] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1608.156216] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1618.182882] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:52:plane-3] flip_done timed out
[ 1628.209613] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1638.236209] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1648.262893] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:52:plane-3] flip_done timed out
[ 1658.289540] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1668.316234] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1678.342884] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:52:plane-3] flip_done timed out
[ 1688.369563] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1698.396215] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1708.422893] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:52:plane-3] flip_done timed out
[ 1718.449559] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1728.476210] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1738.502987] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:52:plane-3] flip_done timed out
[ 1748.529537] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1758.556197] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1768.582883] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:52:plane-3] flip_done timed out
[ 1778.609528] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1788.636194] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
[ 1798.662859] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:52:plane-3] flip_done timed out
[ 1808.689532] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:62:crtc-0] flip_done timed out
I keep Kernel Traces upon journalctl -xe
Okt 17 22:24:30 shan-pc kernel: RSP: 0018:ffffa401809dba70 EFLAGS: 00010082
Okt 17 22:24:30 shan-pc kernel: RAX: 0000000000000001 RBX: 0000000000000287 RCX: 000000000000001e
Okt 17 22:24:30 shan-pc kernel: RDX: 0000000000000001 RSI: 0000000000000297 RDI: ffff8d6e6a200188
Okt 17 22:24:30 shan-pc kernel: RBP: ffffa401809dbd68 R08: 0000000000000002 R09: 0000000000000001
Okt 17 22:24:30 shan-pc kernel: R10: 0000000000000000 R11: ffff8d6e65ded118 R12: 0000000000000000
Okt 17 22:24:30 shan-pc kernel: R13: ffff8d6e65ded000 R14: ffff8d6e65ded118 R15: ffff8d6e62201300
Okt 17 22:24:30 shan-pc kernel: FS: 0000000000000000(0000) GS:ffff8d752fb80000(0000) knlGS:0000000000000000
Okt 17 22:24:30 shan-pc kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Okt 17 22:24:30 shan-pc kernel: CR2: 000055c323015004 CR3: 00000006a8e10000 CR4: 0000000000350ee0
Okt 17 22:24:30 shan-pc kernel: Call Trace:
Okt 17 22:24:30 shan-pc kernel: ? prb_read_valid+0x17/0x20
Okt 17 22:24:30 shan-pc kernel: ? vprintk_emit+0x14f/0x290
Okt 17 22:24:30 shan-pc kernel: ? printk+0x58/0x73
Okt 17 22:24:30 shan-pc kernel: ? drm_atomic_helper_wait_for_dependencies+0x1e4/0x200 [drm_kms_helper]
Okt 17 22:24:30 shan-pc kernel: ? __drm_err+0x72/0x90 [drm]
Okt 17 22:24:30 shan-pc kernel: commit_tail+0x94/0x130 [drm_kms_helper]
Okt 17 22:24:30 shan-pc kernel: drm_atomic_helper_commit+0x112/0x140 [drm_kms_helper]
Okt 17 22:24:30 shan-pc kernel: drm_atomic_helper_dirtyfb+0x189/0x260 [drm_kms_helper]
Okt 17 22:24:30 shan-pc kernel: drm_fb_helper_dirty_work+0x179/0x1b0 [drm_kms_helper]
Okt 17 22:24:30 shan-pc kernel: process_one_work+0x1aa/0x360
Okt 17 22:24:30 shan-pc kernel: worker_thread+0x1e0/0x390
Okt 17 22:24:30 shan-pc kernel: ? process_one_work+0x360/0x360
Okt 17 22:24:30 shan-pc kernel: kthread+0x12d/0x150
Okt 17 22:24:30 shan-pc kernel: ? kthread_associate_blkcg+0xc0/0xc0
Okt 17 22:24:30 shan-pc kernel: ret_from_fork+0x22/0x30
Okt 17 22:24:30 shan-pc kernel: ---[ end trace e5068d684a9ffbde ]---
Okt 17 22:24:34 shan-pc audit[3265]: USER_AUTH pid=3265 uid=1000 auid=1000 ses=7 subj=unconfined msg='op=PAM:authentication grantors=pam_unix acct="shantan>
Okt 17 22:24:34 shan-pc kernel: audit: type=1100 audit(1666038274.401:430): pid=3265 uid=1000 auid=1000 ses=7 subj=unconfined msg='op=PAM:authentication gr>
Okt 17 22:24:34 shan-pc dbus-daemon[1034]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' >
Okt 17 22:24:34 shan-pc dbus-daemon[1034]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.>
Okt 17 22:24:34 shan-pc sudo[3265]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Okt 17 22:24:34 shan-pc audit[3265]: USER_ACCT pid=3265 uid=1000 auid=1000 ses=7 subj=unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_ti>
Okt 17 22:24:34 shan-pc kernel: audit: type=1101 audit(1666038274.405:431): pid=3265 uid=1000 auid=1000 ses=7 subj=unconfined msg='op=PAM:accounting granto>
Okt 17 22:24:34 shan-pc sudo[3265]: shantanoo : TTY=pts/0 ; PWD=/home/shantanoo ; USER=root ; COMMAND=/usr/bin/journalctl -xe
Okt 17 22:24:34 shan-pc audit[3265]: CRED_REFR pid=3265 uid=1000 auid=1000 ses=7 subj=unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/us>
Okt 17 22:24:34 shan-pc kernel: audit: type=1110 audit(1666038274.408:432): pid=3265 uid=1000 auid=1000 ses=7 subj=unconfined msg='op=PAM:setcred grantors=>
Okt 17 22:24:34 shan-pc sudo[3265]: pam_unix(sudo:session): session opened for user root(uid=0) by user(uid=1000)
Changes tried
I tried adding video=SVIDEO-1:d in the /etc/default/grub and also tried adding idle=nomwait in the kernel boot options but nothing is working. I still keep getting delays close to 5 minutes and the UI never loads.
What have done wrong here? Can I revert the updates somehow, because before the updates everything worked well
