Flickering mouse cursor on wayland
I booted the latest (from github) Manjaro KDE on a Pi-5. It booted quite quickly. However, i was immediately greeted with a flickering mouse cursor. The cursor even vanishes unless i move the mouse. That was an issue with KDE-5 wayland on Pi-5 also. I do not remember having this issue on Pi-4. And also, it goes away if i switch to X11. I would think that the latest KDE Plasma (6) would have solved these issues but i guess i was wrong.
Today i tried the latest (nightly) version of Manjaro ARM (for RPI-4) on a RPI-5. The mouse cursor is still flickering and disappearing. Is it because this is still a RPI-4 release? Other than that it actually works quite well.
I have had that issue in the past and disabling Window Compositing fixed it for me. I always keep it disabled and have not tested with it enabled in a long time.
Is that even possible to do under Wayland? I also disable compositing on X11 but as far as i know, it is not possible to do in wayland.
Not sure as I do not do KDE of any sort (not a fan of KDE and rpi) but seems like there was something similar mentioned a long time ago with the flickering mouse issue with it.
Additional 2024-09-22:
Some one has the same issue and opened an issue on the RPi kernel github. If I were you I would post there also to confirm it so they know more than one has the same issue.
https://github.com/raspberrypi/linux/issues/6381
That is my bug report actually :slight_smile:
I just tested the latest RPI4 release on my RPI5 (downloaded from github) and i think it is safe to say that this issue that i mentioned in the original post has been fixed. No mouse cursor artifacts in wayland or X.
