Like it says in the title, its so annoying cant play, i think its something to do with refresh rate or maybe v sync i tried all options also performance is slightly worse then w11, i also have civ 6 installed works without a problem. please help i don’t want to switch back
edit: i tried to check nvidia setting to enable or look refresh rate but there was not option regarding that.
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=23ad8632-174e-4c9e-83b2-1224ce01328e rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 1
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506HC_FX506HC
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: FX506HC v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: FX506HC.313 date: 03/03/2023
ID-1: BAT1 charge: 38.3 Wh (100.0%) condition: 38.3/48.1 Wh (79.7%)
volts: 12.5 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
status: full
System RAM: total: 16 GiB note: est. available: 15.37 GiB
used: 5.92 GiB (38.6%)
Info: model: 11th Gen Intel Core i5-11400H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
microcode: 0x4E
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 909 high: 1042 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 1039 3: 800 4: 800
5: 800 6: 1004 7: 800 8: 1016 9: 1009 10: 1008 11: 800 12: 1042
bogomips: 64536
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid x2apic
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: ASUSTeK driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 0000:00:02.0
chip-ID: 8086:9a68 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 bus-ID: 0000:01:00.0
chip-ID: 10de:25a5 class-ID: 0300
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:4 chip-ID: 322e:202c
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915,nvidia display-ID: 0
Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.3.3-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT1)
device-ID: 8086:9a68 memory: 15.01 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.274 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3050 Laptop GPU driver: nvidia v: 545.29.06
device-ID: 10de:25a5 surfaces: xcb,xlib,wayland
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 10de:2291 class-ID: 0403
API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel bus-ID: 0000:2d:00.0
chip-ID: 14c3:7961 class-ID: 0280
IF: wlp45s0 state: up mac: <filter>
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 0000:2e:00.0
IF: enp46s0 state: down mac: <filter>
Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-14:5 chip-ID: 13d3:3563
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 250.14 GiB (52.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZ
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 31.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 250.14 GiB (53.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 23ad8632-174e-4c9e-83b2-1224ce01328e
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: BF63-47AC
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 3-7:4 info: Sonix USB2.0 HD UVC WebCam type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 322e:202c class-ID: 0e02
Device-2: 3-14:5 info: IMC Networks Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Hub-4: 4-0:1 info: super-speed hub ports: 8 rev: 3.1
System Temperatures: cpu: 36.0 C mobo: N/A
Fan Speeds (rpm): cpu: 3200
Processes: 296 Uptime: 4h 53m wakeups: 0 Init: systemd v: 255
Packages: 1354 pm: pacman pkgs: 1347 libs: 447 tools: pamac pm: flatpak
pkgs: 7 Shell: Zsh v: 5.9 default: Bash v: 5.2.21 running-in: konsole
inxi: 3.3.31
