Flatpak openh264 download not accessible from Russia for some reason
Hello everyone, has anyone encountered this?, it gives a 403 error, if you follow the link it says “blocked in your country”, I turn on the VPN nothing changes, access is blocked
flatpak update         ✔
Looking for updates…
        ID                                           Branch           Op           Remote            Download
 1. [✗] org.freedesktop.Platform.openh264            2.5.1            i            flathub             1.7 kB / 971.4 kB
 2. [✓] org.gtk.Gtk3theme.Breeze                     3.22             i            flathub           114.5 kB / 192.6 kB
Warning: While downloading http://ciscobinary.openh264.org/libopenh264-2.5.1-linux64.7.so.bz2: Server returned status 403
Installation complete.
This didn’t exist yesterday.
:facepalm:The whole problem was solved through another VPN). It turns out that now we have to abandon Flatpak since it is no longer available in Russia
flatpak update         ✔
 1. [✓] org.freedesktop.Platform.openh264            2.5.1            i            flathub           620.4 kB / 971.4 kB
So you used one VPN and failed - then used another VPN and succeeded?
So how do you reach the conclusion that Flathub is banned in/by Russia?
The response 403 - Forbidden - means the request was refused by the server.
This response - when originating on the server - usually means - I recognise your request but you are not authorised to receive the content.
It is more likely the sanctions against Russia which is impacting digital content when you are accessing the content from a Russian network.
i understand the sentence like, he tried it first the normal way got blocked and then turned on the first vpn and got also blocked…
Flathub is not blocking you. http://ciscobinary.openh264.org/ is blocking your IP address.
An open issue has been lodged on the openh264 GitHub page:
It looks like Amazon CloudFront, which hosts openh264.org, may have been been configured to block access from certain countries, including Russia.
True, it also blocked Germany, since the VPN of Germany showed the same page), and upgraded from Latvia
