Flatpak game after symlink with performance issues
Im experience heavy performance issues, since i used the symlink for a Flatpak game, called BAR (Beyond all Reason). I play it almost daily and i never had problems, not till i used this symlink.
I moved BAR from my External Samsung SSD T5 (500gb) (connected with USB 3.0) to my Internal Samsung SSD 860 Pro (1TB) that i mainly use for gaming, but also for Win10 and since i though my External SSD has enough work to do with Linux and Swap and BAR.
I though it makes sense to use my idling and unused (in Linux) 860 SDD that connected with SATA, but instead improving the performance i think i made it worse. I just dont get it, whats going on here?
Maybe is there read/access degration when using Symlinks? Is there a way to improve access to the Data for my gaming SSD?
This is the commands that i used befor i had this issues.
# move exiting installation to new directory (dont create a Folder named “bar”)
$ mv ~/.var/app/info.beyondallreason.bar/data/ /media/linux-games/bar
# give app in flatpak permission to read and write to new data directory
$ flatpak override --user --filesystem=/media/linux-games/bar info.beyondallreason.bar
# symlink the old data directory to new one
$ ln -s /media/linux-games/bar ~/.var/app/info.beyondallreason.bar/data
$ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 5.15.94-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/vmlinuz-5.15-x86_64
    root=UUID=eb235aa7-d461-413d-800e-ea57385703fb rw quiet apparmor=1
    sysrq_always_enabled=1 retbleed=off security=apparmor
    resume=UUID=717b267e-7322-4bf9-a840-f1210d422d1a udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop System: Gigabyte product: Z170X-UD3 v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: Z170X-UD3-CF v: x.x serial: <superuser required>
    UEFI-[Legacy]: American Megatrends v: F23d date: 12/01/2017
  RAM: total: 15.58 GiB used: 2.57 GiB (16.5%)
  Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x5E (94) stepping: 3 microcode: 0xF0
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 4501 high: 4505 min/max: 800/4700 scaling:
    driver: intel_pstate governor: performance cores: 1: 4501 2: 4501 3: 4499
    4: 4500 5: 4499 6: 4499 7: 4505 8: 4504 bogomips: 64026
    dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    vulnerable
  Type: retbleed status: Vulnerable
    prctl and seccomp
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: Micro-Star MSI
    driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
    status: current (as of 2023-02) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:1e07 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 122 s-size: 532x302mm (20.94x11.89")
    s-diag: 612mm (24.08")
  Monitor-1: DP-4 res: 2560x1440 dpi: 123 size: 527x296mm (20.75x11.65")
    diag: 604mm (23.8") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce RTX 2080
    Ti/PCIe/SSE2 direct-render: Yes
  Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
    class-ID: 0403
  Device-2: NVIDIA TU102 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 01:00.1 chip-ID: 10de:10f7 class-ID: 0403
  Device-3: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
    Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 0b:00.0 chip-ID: 1102:0012 class-ID: 0403
  Sound API: ALSA v: k5.15.94-1-MANJARO running: yes
  Sound Server-1: JACK v: 1.9.22 running: no
  Sound Server-3: PipeWire v: 0.3.65 running: yes
  Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 5.48 TiB used: 245.65 GiB (4.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 2B7QCXE7 temp: 39.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 PRO 1TB
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 2B6Q scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HDN724030ALE640
    size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    type: HDD rpm: 7200 serial: <filter> rev: A5E0 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Samsung
    model: Portable SSD T5 size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B type: SSD serial: <filter> scheme: MBR
  ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate model: BUP Slim BK
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: N/A
    serial: <filter> rev: 0302 scheme: GPT
  ID-1: / raw-size: 88.61 GiB size: 86.66 GiB (97.80%) used: 26.83 GiB (31.0%)
    fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: N/A
    uuid: eb235aa7-d461-413d-800e-ea57385703fb
  ID-2: /boot raw-size: 200 MiB size: 188.2 MiB (94.09%)
    used: 68.9 MiB (36.6%) fs: ext3 dev: /dev/sdc3 maj-min: 8:35 label: N/A
    uuid: 26eda82e-b403-49b8-abca-202167417020
  ID-3: /home raw-size: 332.03 GiB size: 325.75 GiB (98.11%)
    used: 7.62 GiB (2.3%) fs: ext4 dev: /dev/sdc4 maj-min: 8:36 label: N/A
    uuid: ada4a6a2-bd0a-4652-b386-7c637bba7ee9
  ID-4: /media/linux-games raw-size: 196.58 GiB size: 192.43 GiB (97.89%)
    used: 132.26 GiB (68.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
    label: Linux-games uuid: dd5af583-9d00-4017-adf7-e1d8876486e7
  ID-5: /media/temp raw-size: 63.48 GiB size: 62.18 GiB (97.96%)
    used: 20.05 GiB (32.2%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: temp
    uuid: 1e81b7c2-3438-438a-b572-ff8a966a78e1
  ID-6: /run/media/koboldx/Backup PC raw-size: 462.76 GiB
    size: 454.43 GiB (98.20%) used: 58.82 GiB (12.9%) fs: ext4 dev: /dev/sdd1
    maj-min: 8:49 label: Backup PC uuid: 8a779c83-ea89-4c23-acdb-8524194cd97f
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
  ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sdc2 maj-min: 8:34 label: N/A
    uuid: 717b267e-7322-4bf9-a840-f1210d422d1a
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 442.47 GiB fs: ntfs label: ssm
    uuid: AE7EDC0696B158FD
  ID-2: /dev/sda1 maj-min: 8:1 size: 50 MiB fs: ntfs label: System-reserviert
    uuid: B2286A122869D5BF
  ID-3: /dev/sda2 maj-min: 8:2 size: 97.09 GiB fs: ntfs label: win10
    uuid: 5E60C09860C077F3
  ID-4: /dev/sda4 maj-min: 8:4 size: 585.94 GiB fs: ntfs label: games
    uuid: 165692E31D7ADAF2
  ID-5: /dev/sdb2 maj-min: 8:18 size: 1.57 TiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-6: /dev/sdb3 maj-min: 8:19 size: 1.09 TiB fs: <superuser required>
  ID-7: /dev/sdd2 maj-min: 8:50 size: 468.75 GiB fs: ext4
    label: Backup Laptop uuid: ba42cd8d-3994-4491-85a2-f55f60a1d0e9
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 1-9:2 info: Endor AG ClubSportPedal type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 0eb7:183b class-ID: 0300
  Device-2: 1-13:3 info: A4Tech XL-730K / XL-750BK XL-755BK Mice
    type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 12 Mb/s power: 100mA chip-ID: 09da:9090 class-ID: 0301
  Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
  Device-1: 2-3:3 info: Seagate RSS LLC Backup Plus Portable Drive
    type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s
    power: 144mA chip-ID: 0bc2:ab24 class-ID: 0806 serial: <filter>
  Device-2: 2-5:2 info: Samsung Portable SSD T5 type: Mass Storage
    driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 896mA
    chip-ID: 04e8:61f5 class-ID: 0806 serial: <filter>
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 23.0 C mobo: N/A gpu: nvidia temp: 27 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
  Processes: 243 Uptime: 14m wakeups: 1 Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1484
  pm: pacman pkgs: 1478 libs: 417 tools: pamac pm: flatpak pkgs: 6 Shell: Bash
  v: 5.1.16 running-in: konsole inxi: 3.3.25
I reverted my changes few days later (with Timeshift) and my performance is back to normal after this.
So must be some heavily and strange performance issue with Flatpak Symlink.
I also had played the same game on the same SSD (860 pro) under win10 and there was no issues at all.
Anyone have a idea, why is there a problem?
Because “flatpak” happens. Use it as intended, or get gray hairs. Flatpak is designed to aim somewhat Androids pm, so no wonder it will not work good, when you use symlinks. :man_shrugging:
