When I tried to update my Flatpaks today on my Laptop I received this error.
OSTree:ERROR:src/libostree/ostree-fetcher-curl.c:534:sock_cb: code should not be reached
Bail out! OSTree:ERROR:src/libostree/ostree-fetcher-curl.c:534:sock_cb: code should not be reached
zsh: IOT instruction (core dumped) flatpak update
I have tried to update via Terminal where I receive this message. I have tried via Pamac and it just sits there doing nothing with no error message. I have no idea how to proceed.
When Googling I found 1 issue that was similar to mine⦠A possible solution suggested was to rename .local/share/flatpak which I tried but it made no difference.
Here is my inxi
Kernel: 6.10.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.10-x86_64
root=UUID=6b4c8783-748f-415b-967e-9a9da24a70b5 rw rootflags=subvol=@ quiet
splash resume=UUID=5aa92ae9-fd80-4e36-a23d-db07e178ce87
udev.log_priority=3
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Laptop System: Dell product: Latitude 7390 v: N/A
Mobo: Dell model: 09386V v: A00 serial: <superuser required> part-nu: 081B
uuid: <superuser required> UEFI: Dell v: 1.31.1 date: 02/02/2023
ID-1: BAT0 charge: 25.7 Wh (68.4%) condition: 37.6/60.0 Wh (62.7%) volts: 7.6
min: 7.6 model: LGC-LGC7.780 DELL MYJ9696 type: Li-ion serial: <filter>
status: discharging
System RAM: total: 16 GiB available: 15.37 GiB used: 2.46 GiB (16.0%)
Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
Device-1: DIMM A type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 2400 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: 01980000802C
part-no: K821PJ-MIE serial: <filter>
Device-2: ChannelB-DIMM0 type: no module installed
Info: model: Intel Core i7-8650U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF6
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 890 min/max: 400/4200 scaling: driver: intel_pstate
governor: powersave cores: 1: 890 2: 890 3: 890 4: 890 5: 890 6: 890 7: 890
8: 890 bogomips: 33615
sgx smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic
vulnerable
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: Realtek Integrated Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0bda:5650
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 res: 1745x982 size: N/A modes: N/A
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
device-ID: 8086:5917 memory: 7.51 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 7 device: 0 type: integrated-gpu name: Intel
UHD Graphics 620 (KBL GT2) driver: mesa intel v: 24.2.2-arch1.1
device-ID: 8086:5917 surfaces: xcb,xlib,wayland
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.10.12-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 8086:2725 class-ID: 0280
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0032
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 5 state: up address: see --recommends
Local Storage: total: 1.82 TiB used: 309.23 GiB (16.6%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SD1TB size: 931.44 GiB block-size:
physical: 512 B logical: 512 B type: Removable tech: SSD serial: <filter>
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 4B2QEXM7 temp: 25.9 C scheme: GPT
ID-1: / raw-size: 914.3 GiB size: 914.3 GiB (100.00%)
used: 154.61 GiB (16.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 6b4c8783-748f-415b-967e-9a9da24a70b5
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 2D5C-E300
ID-3: /home raw-size: 914.3 GiB size: 914.3 GiB (100.00%)
ID-4: /var/cache raw-size: 914.3 GiB size: 914.3 GiB (100.00%)
ID-5: /var/log raw-size: 914.3 GiB size: 914.3 GiB (100.00%)
ID-6: /var/tmp/flatpak-cache-BTABV2/com.github.KRTirtho.Spotube.Locale-DNABV2 raw-size: N/A size: 914.3 GiB used: 154.61 GiB (16.9%) fs: fuse.revokefs-fuse
source: ERR-102
ID-1: swap-1 type: partition size: 16.91 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 5aa92ae9-fd80-4e36-a23d-db07e178ce87
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: Realtek Integrated Webcam_HD type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0bda:5650 class-ID: 0e02 serial: <filter>
Device-2: 1-7:3 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0032 class-ID: e001
Device-3: 1-8:4 info: Siliconworks SiW HID Touch Controller type: HID
driver: hid-generic,hid-multitouch,usbhid interfaces: 2 rev: 2.0
chip-ID: 1fd2:7002 class-ID: 0300
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
System Temperatures: cpu: 29.0 C pch: 26.5 C mobo: 23.0 C
Fan Speeds (rpm): cpu: 0
Processes: 277 Power: uptime: 3h 20m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.14 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Packages: 1820 pm: dpkg pkgs: 0 pm: pacman pkgs: 1764 libs: 511
tools: pamac,yay pm: flatpak pkgs: 56 Compilers: clang: 18.1.8 gcc: 14.2.1
Shell: Zsh v: 5.9 default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
