Hi, there!
I am struggling in trying to get FlatCAM working again.
I had it working well after a long battle with getting the correct Python version and libraries loaded.
However, there must have been an update and now it has stopped working.
As I don’t use the application very often, I’m not sure when the changes took place.
Now when I try to run it, I get the following output in a terminal.
> Traceback (most recent call last):
> File "/home/roger/Downloads/FlatCAM/FlatCAM_beta_8.994_sources/FlatCAM.py", line 6, in <module>
> from app_Main import App
> File "/home/roger/Downloads/FlatCAM/FlatCAM_beta_8.994_sources/app_Main.py", line 52, in <module>
> from appDatabase import ToolsDB2
> File "/home/roger/Downloads/FlatCAM/FlatCAM_beta_8.994_sources/appDatabase.py", line 4, in <module>
> from camlib import to_dict
> File "/home/roger/Downloads/FlatCAM/FlatCAM_beta_8.994_sources/camlib.py", line 54, in <module>
> from appParsers.ParseDXF import *
> File "/home/roger/Downloads/FlatCAM/FlatCAM_beta_8.994_sources/appParsers/ParseDXF.py", line 10, in <module>
> from ezdxf.math.vector import Vector as ezdxf_vector
> ModuleNotFoundError: No module named 'ezdxf.math.vector'
I’m not a programmer and have no idea what it is telling me.
Thanks for your comments and help.
I have done a bit more digging on the Internet and found a soulution.
Apparently, the problem was Vispy. There was an update that broke my install.
I manually re-installed Vispy 0.7 and all is now OK.
By the way, I am not using the AUR package, but the latest 8.994 release from the developer.
