I want to use Manjaro on my Radxa Zero. But I can’t flash it to the eMMC.
The img file I use is Manjaro-ARM-gnome-radxa-zero-20210906.img
Is there any tutorial or something of how to do this?
I flashed it with BalenaEtcher, reconnected the device and it doesn’t boot. What am I doing wrong?
@spikerguy I don’t made it to install android on the eMMC. I installed Armbian 21.08.0 instead. Manjaro also booted with a SD Card and the Armbian on the eMMC. Then I executed sudo /boot/install-aml-emmc.sh and from time to time there was some messages that some time stamps are in the future. I don’t know if this is bad but the command runs and ends successfully.
Then I tried to boot without SD card but it only shows the Manjaro loading screen. I let it run for over half an hour but nothing changes. Is it normal that it takes to much time or is there something?
I think I know the problem with the time. I can’t connect to the Wifi. There is nothing where I can find the available networks and nmtui doesn’t shows any network.
Congratulations to the Manjaro team for this release.
The Radxa board is simply awesome, I’m using it as daily driver. Yes, it works! A fully working desktop, completely silent, cool and with less than 5 watt of power consumption… …
And with the flexibility and power of Manjaro it has to be amazing.
Does this version of Manjaro support restart and suspend/resume? (Not working on the Debian image provided by the Radxa team).
Is it stable?..
Is Pacman working ok? (updated to the latest app versions, support for kernel install and AUR working?)…
