Hey all,
I’m using a RTX 2070 Super w/ MaxQ in a MSI GS66 Stealth on Manjaro GNOME
I seem to have some serious screan tearing isues when playing games/watching videos. I’ve tried Googling this and none of the options have worked, I’ve been dealing with this for months and need to keep going back to PopOS. Does anyone have any solutions I could try?
Here is the output of inxi -Fazy
Kernel: 5.10.32-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64
root=UUID=1e76304c-c2d9-4915-b8f2-3b3bc641fa30 rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor
resume=UUID=b996df8a-0e33-4fb9-9a8e-79145e767d3b udev.log_priority=3
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: Micro-Star product: GS66 Stealth 10SFS v: REV:1.0
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Micro-Star model: MS-16V1 v: REV:1.0 serial: <filter>
UEFI: American Megatrends v: E16V1IMS.106 date: 03/11/2020
ID-1: BAT1 charge: 48.7 Wh (77.1%) condition: 63.2/95.0 Wh (66.5%)
volts: 15.9 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: Charging
Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: E0
cache: L2: 12 MiB
bogomips: 62399
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Device-1: Intel UHD Graphics vendor: Micro-Star MSI driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU104M [GeForce RTX 2070 SUPER Mobile / Max-Q]
vendor: Micro-Star MSI driver: nvidia v: 460.73.01
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1e91
class-ID: 0300
Device-3: Acer HD Camera type: USB driver: uvcvideo bus-ID: 1-11:3
chip-ID: 5986:2127 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.0.3
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
Sound Server-1: ALSA v: k5.10.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: no
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel port: 4000 bus-ID: 00:14.3 chip-ID: 8086:06f0
class-ID: 0280
Device-2: Intel driver: igc v: kernel port: 3000 bus-ID: 3c:00.0
chip-ID: 8086:3100 class-ID: 0200
IF: enp60s0 state: down mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-14:4
chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 953.87 GiB used: 280.22 GiB (29.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HALR-00000
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: EXA7301Q temp: 46.9 C
scheme: GPT
ID-1: / raw-size: 935.94 GiB size: 935.94 GiB (100.00%)
used: 280.22 GiB (29.9%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 954 MiB size: 952.1 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 935.94 GiB size: 935.94 GiB (100.00%)
ID-1: swap-1 type: partition size: 17 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 61.0 C mobo: N/A
Processes: 320 Uptime: 5m wakeups: 1 Memory: 15.46 GiB
used: 2.47 GiB (16.0%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: pacman: 1190 lib: 322 flatpak: 0 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.04
