Hi,
I had a dual boot setup windows/manjaro, with each having a dedicated hard drive. The windows hard drive has failed, and so I will be replacing it, but I cannot do so right away. The problem is that grub was installed on the windows hard drive, so now when I try to boot just manjaro it does not find the OS.
I assume all I have to do is reinstall grub. I could just reinstall manjaro as a whole, but I don’t want to lose my data and/or reconfigure everything (all my work stuff is in there). I thought running a live USB and using some sort “fix install” option, but there doesn’t seem to be any, just “install alongside” (which is not what I’m after, although I suppose I could do such an install, get grub installed that way, and then delete the new install and give the partition space back). How could I get this done?
One issue I noticed is that it appears there is only one single partition on the entire 1TB hard drive, ext4 linux. I’m aware it’s a good practice to separate it more, all I can say is that I ran into issues doing the original install and I was frustrated, I “temporarily” left it as it was once I got it working and completely forgot to clean the mess up.
I can mount the old installation, and even do manjaro-chroot -a to have full access there, but I just don’t know what to do about it. grub-update gives the following output:
[manjaro /]# update-grub
Generating grub configuration file …
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.9-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.9-x86_64.img
Found initrd fallback image: /boot/initramfs-5.9-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.7-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.7-x86_64.img
Found initrd fallback image: /boot/initramfs-5.7-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.4-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
It’s output will be used to detect bootable binaries on them and create new boot entries.
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
done
I thought of using grub-install, but I’m not sure of the parameters I’d need as the ones I saw online won’t work as-is. Looking into it now, but I figured I’d ask for help just in case.
EDIT: I figured it out, I had to install grub with sdba as the parameter. I’m back in. I jumped the gun asking for help.
