well i tried to install waydroid using the “yay” but it says
“Failed to install the following packages. Manual intervention is required:”
well idk what that means but can someone help me to fix this problem?
yay -S waydroid ✔ 18s base
Sync Make Dependency (2): python-setuptools-1:75.2.0-2, cython-3.0.11-1
AUR Explicit (1): waydroid-1.4.3-1
AUR Dependency (1): python-gbinder-1.1.2-3
:: (1/2) Downloaded PKGBUILD: python-gbinder
:: (2/2) Downloaded PKGBUILD: waydroid
2 waydroid (Build Files Exist)
1 python-gbinder (Build Files Exist)
==> Packages to cleanBuild?
==> [N]one [A]ll [Ab]ort [I]nstalled [No]tInstalled or (1 2 3, 1-3, ^4)
==> a
:: Deleting (1/2): /home/ezey/.cache/yay/waydroid
HEAD is now at d19d582 upgrade to 1.4.3
:: Deleting (2/2): /home/ezey/.cache/yay/python-gbinder
HEAD is now at b68b6da apply pr 12
==> Diffs to show?
==> n
==> Making package: waydroid 1.4.3-1 (Sun 02 Feb 2025 04:27:45 PM +0545)
==> Retrieving sources...
-> Cloning waydroid git repo...
Cloning into bare repository '/home/ezey/.cache/yay/waydroid/waydroid'...
remote: Enumerating objects: 3253, done.
remote: Counting objects: 100% (726/726), done.
remote: Compressing objects: 100% (205/205), done.
remote: Total 3253 (delta 615), reused 526 (delta 521), pack-reused 2527 (from 3)
Receiving objects: 100% (3253/3253), 1.22 MiB | 752.00 KiB/s, done.
Resolving deltas: 100% (2106/2106), done.
==> WARNING: Skipping verification of source file PGP signatures.
waydroid ... Passed
==> Making package: python-gbinder 1.1.2-3 (Sun 02 Feb 2025 04:27:51 PM +0545)
-> Cloning python-gbinder git repo...
Cloning into bare repository '/home/ezey/.cache/yay/python-gbinder/python-gbinder'...
remote: Enumerating objects: 100, done.
remote: Counting objects: 100% (51/51), done.
remote: Compressing objects: 100% (21/21), done.
remote: Total 100 (delta 38), reused 30 (delta 30), pack-reused 49 (from 1)
Receiving objects: 100% (100/100), 45.63 KiB | 531.00 KiB/s, done.
Resolving deltas: 100% (45/45), done.
-> Found pr12.patch
==> Validating source files with sha512sums...
python-gbinder ... Passed
pr12.patch ... Passed
:: Remove make dependencies after install? [y/N] n
:: (1/2) Parsing SRCINFO: waydroid
:: (2/2) Parsing SRCINFO: python-gbinder
resolving dependencies...
Packages (9) python-autocommand-2.2.2-6 python-jaraco.collections-5.0.1-1 python-jaraco.context-5.3.0-1 python-jaraco.functools-4.0.2-1
python-jaraco.text-4.0.0-1 python-more-itertools-10.3.0-1 python-platformdirs-4.3.6-1 cython-3.0.11-1
Total Installed Size: 27.34 MiB
:: Proceed with installation? [Y/n] y
(9/9) checking keys in keyring [################################################] 100%
(9/9) checking package integrity [################################################] 100%
(9/9) loading package files [################################################] 100%
(9/9) checking for file conflicts [################################################] 100%
(9/9) checking available disk space [################################################] 100%
(1/9) installing cython [################################################] 100%
(2/9) installing python-more-itertools [################################################] 100%
(3/9) installing python-jaraco.functools [################################################] 100%
(4/9) installing python-jaraco.context [################################################] 100%
(5/9) installing python-autocommand [################################################] 100%
(6/9) installing python-jaraco.text [################################################] 100%
Optional dependencies for python-jaraco.text
python-inflect: for show-newlines script
(7/9) installing python-jaraco.collections [################################################] 100%
(8/9) installing python-platformdirs [################################################] 100%
(9/9) installing python-setuptools [################################################] 100%
(1/1) Arming ConditionNeedsUpdate...
==> Making package: python-gbinder 1.1.2-3 (Sun 02 Feb 2025 04:28:05 PM +0545)
-> Updating python-gbinder git repo...
-> Found pr12.patch
==> Extracting sources...
-> Creating working copy of python-gbinder git repo...
Cloning into 'python-gbinder'...
done.
Switched to a new branch 'makepkg'
==> Starting prepare()...
patching file setup.py
==> Starting pkgver()...
==> Sources are ready.
==> Making package: python-gbinder 1.1.2-3 (Sun 02 Feb 2025 04:28:12 PM +0545)
==> WARNING: Using existing $srcdir/ tree
==> Starting build()...
File "/home/ezey/.cache/yay/python-gbinder/src/python-gbinder/setup.py", line 27, in <module>
from Cython.Build import cythonize
ModuleNotFoundError: No module named 'Cython'
==> ERROR: A failure occurred in build().
Aborting...
-> Failed to install layer, rolling up to next layer.error:error making: python-gbinder - exit status 4
==> Making package: waydroid 1.4.3-1 (Sun 02 Feb 2025 04:28:13 PM +0545)
==> Missing dependencies:
-> python-gbinder
==> ERROR: Could not resolve all dependencies.
-> error making: waydroid-exit status 8
==> Making package: python-gbinder 1.1.2-3 (Sun 02 Feb 2025 04:28:15 PM +0545)
-> Found pr12.patch
done.
==> Making package: python-gbinder 1.1.2-3 (Sun 02 Feb 2025 04:28:21 PM +0545)
==> Removing existing $pkgdir/ directory...
Aborting...
-> error making: python-gbinder-exit status 4
-> Failed to install the following packages. Manual intervention is required:
waydroid - exit status 8
