Hi! The login screen of Manjaro KDE freezes when I try to enter my password, and therefore I’m currently locked out. Aside from freezing, it shows an error below the user card, which says the breath2 theme can’t be loaded. So in order to fix it, I must chroot and run some commands to reinstall the theme, or reset kde settings.
- I’ve tried
chrooting into the system, and updating with pacman, but this hasn’t solved the issue. - I’ve tried deleting the kde folders in /home/user/.config, and still getting the issue.
The error reads as follows:
The current theme cannot be loaded due to the errors below, please select another theme. \n file:///user/share/sddm/themes/breath2/Main.qml:26:1: plugin cannot be loaded for module "org.kde.plasma.core": Cannot load library /usr/lib/qt/qml/org/kde/plasma/core/libcorebindingsplugin.so: (/usr/lib/libKF5QuickAddons.so.5: file too short)
So I’m looking for commands I can run in chroot, which can potentially fix that issue with the login screen. Here’s a screenshot:
