Hey guys, I just got Manjaro running for my friend here. I got the latest plasma ISO and flashed a drive, which we then put on his SSD.
That all works fine, until I go to run sudo pacman -Syyu in the console. For some reason the console seems to be getting stuck on core. I can’t even determine easily if it’s downloading anything.
I’m not sure what to do. There was some talk online about checking the pacman download mirrors, which I tried, but I’ve had no luck fixing the issue with that advice.
Following this advice now. Thanking you kindly. It’s running the mirror check now.
Hey linux-aarhus, after running that command and updating the Mirror list, it doesn’t appear to have solved the issue. It is exhibiting the same behavior as before. Any other ideas?
cat /etc/pacman.d/mirrorlist INT ✘ 6s
## Manjaro Linux default mirrorlist
## Generated on 2022-10-23 05:52
## Please use 'pacman-mirrors -f [NUMBER] [NUMBER]' to modify mirrorlist
## (Use 0 for all mirrors)
## Country : Australia
Server = https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
## Country : South_Korea
Server = https://mirror.funami.tech/manjaro/stable/$repo/$arch
## Country : Germany
Server = https://mirror.moson.org/manjaro/stable/$repo/$arch
## Country : United_States
Server = https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
## Country : Brazil
Server = https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
cat /etc/pacman.conf ✔
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir = /
#DBPath = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile = /var/log/pacman.log
#GPGDir = /etc/pacman.d/gnupg/
#HookDir = /etc/pacman.d/hooks/
HoldPkg = pacman glibc manjaro-system
# If upgrades are available for these packages they will be asked for first
SyncFirst = manjaro-system archlinux-keyring manjaro-keyring
#XferCommand = /usr/bin/curl -L -C - -f -o %o %u
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta = 0.7
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
#Color
#NoProgressBar
# We cannot check disk space from within a chroot environment
CheckSpace
#VerbosePkgLists
#ParallelDownloads = 5
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Manjaro Linux
# packagers with `pacman-key --populate archlinux manjaro`.
# REPOSITORIES
# - can be defined here or included from another file
# - pacman will search repositories in the order defined here
# - local/custom mirrors can be added here or in separate files
# - repositories listed first will take precedence when packages
# have identical names, regardless of version number
# - URLs will have $repo replaced by the name of the current repo
# - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
# [repo-name]
# Server = ServerName
# Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
[core]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[extra]
[community]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[multilib]
# An example of a custom package repository. See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
$ curl -O https://manjaro.lucassymons.net/stable/core/x86_64/core.db
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 162k 100 162k 0 0 1806k 0 --:--:-- --:--:-- --:--:-- 1830k
it will download the core.db to the folder - you can remove it
