Scyte
11 October 2022 16:38
1
Hello,
I try to install manjaro-arm on raspberrypi without extra keyboard and monitor.
0. I downloaded Manjaro-ARM-kde-plasma-rpi4-22.08.img.xz
unpacked it
Moved the image with dd to the sd card.
Put the sd in the raspberry pi
Plugged in the power supply
Try to connect to the raspberry pi
ssh root@manjaro-arm (with not password)
→ root@manjaro-arm’s password:
Permission denied, please try again.
the same as 6. with ip
ssh root@192.168.178.56
root@192.168.178.56 ’s password:
The “root:no password” combination is from here
Is this user:password combination changed? Or any other suggestions
Thanks in advanced
xabbu
11 October 2022 17:06
2
Headless setup via SSH is only available with the minimal image. Not with a desktop image like Plasma or Gnome.
Manjaro ARM 22.08 released!
Today is my birthday and what better way to celebrate, then to release our next images!
We are proud to announce the release of Manjaro ARM 22.08.
You can find all our images on manjaro.org !
[ARM_release_22.08_forum]
Application for flashing images
We have our own GUI app to make it easy for users to flash a Manjaro ARM image on to an SD card, eMMC card or USB stick.
If you are on Manjaro ARM, simply install manjaro-arm-flasher and launch the app “Manjaro ARM …
Scyte
11 October 2022 18:03
3
Thank you! I overread that part
Please note:
Only the minimal image has SSH enabled.
Desktop images does not enable SSH and requires peripherals to setup.
After a test using Xfce image - the SSH service is active - but the setup cannot be completed - because the initial setup is using Calamares GUI.
There is certain hacks for Raspberry Pi using Raspberry Pi OS which enables SSH and wireless - but after some testing these appears ineffective on Manjaro images.
It is possible to hack the desktop images and setup the system.
