Firewall on Startup
Hi all,
For some reason, I need to reactivate my firewall eachtime I boot up. I’ve tried the ‘enable’ command in the terminal, and am using gufw for the GUI interface, but everytime I turn on the computer, the firewall is turned off. Does anyone know how to get it to switch itself on?
Thanks,
A
It’s difficult to say - I frankly I have no idea - I have been using firewalld for my purposes.
If you have no preference - I’d recommend disabling ufw service and removing the packages.
Then install the package firewalld instead - the command to enable is
systemctl enable --now firewalld
did you follow this guide?
https://wiki.manjaro.org/index.php/Firewalls
Thanks for the help all, it still seems to want to turn itself off on each reboot. Is there a way I can set up a script or something?
Thanks,
A
run these commands:
sudo systemctl enable ufw.service
sudo ufw enable
sudo systemctl start ufw.service
and it will stay on after a reboot.
Brilliant, that’s solved it! Thanks!
