Firefox's security features may offer less protection on your current operating system
Hi
Since firefox 129.0 update I see this message notification below the address bar:
Some of Firefox’s security features may offer less protection on your current operating system. How to fix this issue
On this page it describes how to fix the issue:
The page describes a fix:
Security features warning
You may see a warning that “some of Firefox’s security features may offer less protection on your current operating system”.
The sandbox in Firefox makes use of unprivileged user namespaces when creating new processes for enforcing more security. This can be considered a security risk, therefore some Linux distributions have started to restrict its usage and only allow it to work where there is an AppArmor profile.
Such profiles can only cover a limited set of installations paths, including Snap and Debian packages. They cannot however cover some other use cases, such as tarball installations as well as local development builds.
To create an AppArmor profile for Firefox:
In /etc/apparmor.d/, create a file with the name firefox-local
in the file, add the following:
# This profile allows everything and only exists to give the
# application a name instead of having the label "unconfined"
abi <abi/4.0>,
include <tunables/global>
profile firefox-local
/home/<USER>/bin/firefox/{firefox,firefox-bin,updater}
flags=(unconfined) {
    userns,
    # Site-specific additions and overrides. See local/README for details.
    include if exists <local/firefox>
Replace <USER> with your Linux user name This assumes the Firefox install is at $HOME/bin/
Once you have saved the file, run sudo systemctl restart apparmor.service in the Linux terminal.
However, the fix does not work for me.
I created a firefox-local profile:
/etc/apparmor.d/firefox-local
Contents:
abi <abi/4.0>,
#/home/<USER>/bin/firefox/{firefox,firefox-bin,updater}
#/usr/local/bin/firefox/{firefox,firefox-bin,updater}
/usr/bin/firefox/{firefox,firefox-bin,updater}
    userns,
error:
apparmor.d in profile /etc/apparmor.d/firefox-local at line 4: Could not open 'abi/4.0': No such file or directory.
I run both Apparmor and Firejail and I installed and run Firefox from the official manjaro repository
This looks like you’re running Firefox from a user-local directory or custom installation and not the official repos, right?
No, I run firefox from the official repo
A conflict ?
I have not seen such message you describe - possibly a local issue - it must relate to either apparmor or firejail.
