Relevant system info
OS: Manjaro ARM Linux aarch64
Host: Raspberry Pi 400 Rev 1.0
Kernel: 5.11.15-1-MANJARO-ARM
WM: sway
OpenGL: renderer: V3D 4.2 v: 2.1 Mesa 21.2.0-devel (git-c74d93cf01)
$ cat /boot/config.txt | grep dtoverlay
dtoverlay=vc4-kms-v3d-pi4
$ cat .zprofile
if [ "$(tty)" = "/dev/tty1" ] ; then
export QT_QPA_PLATFORM=wayland
export GDK_BACKEND=wayland
export MOZ_ENABLE_WAYLAND=1
export MOZ_WEBRENDER=1
export PAN_MESA_DEBUG=gl3
export XDG_SESSION_TYPE=wayland
export XDG_CURRENT_DESKTOP=sway
exec sway
fi
doing a fresh install of manjaro with the 21.04 manjaro minimal image and I’m setting up a sway environment. I’ve completely forgot what to tweak to improve firefox performance and googling around I found this thread from on the forum: Firefox WebRender
so I decide to go with gfx.webrender.all & gfx.webrender.enabled as well as setting the env variable export PAN_MESA_DEBUG=gl3. This indeed does result in great performance with the Chalkboard HTML5 Benchmark, but other than that the browser runs poorly and causes pages to glitch out – for example, about:support will not display properly, constantly blinking in and out as I scroll the page, with this issue repeating itself on other pages. Additionally, another website I like to use as a makeshift benchmark, fallingfalling, runs poorly as well. I can get the browser in working order if I change in about:config layers.acceleration.disabled to true but then the html5 benchmark scores poorly.
Am I overlooking something that’s keeping me from using WebRender in firefox and having the browser function properly? Thanks for any help and suggestions.
