Volume widget (Task Bar) doesn’t affect Firefox Volume.
Got to have text here, apparently.
@BG405 I think we have a new winner for that reward of yours…
Please post more information about system
inxi -SMAa
Audio stream from Firefox
pactl list sink-inputs
And audio stream from PulseAudio/PipeWire
pactl list sinks
Volume changes in Firefox GUI controls should change sink-input volume
Volume changes in “Volume widget (Task Bar)” should change sink volume
I’m not exactly sure what your issue is, but a couple of hints. There are two tabs in the widget, Device and Application. Make sure they are both set like you want. I had issue with videos being too quiet. I checked the box to raise maximum volume. Other wise you will need to supply more info as nikgnomic suggested
Please edit your post above and reformat the output so that it is readable. See…
pactl list sinks
shows 2 audio sinks
Sink #51
State: SUSPENDED
Description: Built-in Audio Analog StereoVolume: front-left: 51118 / 78% / -6.47 dB, front-right: 51118 / 78% / -6.47 dB
analog-output-lineout: Line Out (type: Line, priority: 9000, availability group: Legacy 3, available)
Sink #63
State: SUSPENDED
Description: Easy Effects SinkVolume: front-left: 38666 / 59% / -13.75 dB, front-right: 38666 / 59% / -13.75 dB
balance 0.00
Both sinks are shown as SUSPENDED. That suggests Firefox is not playing audio to either sink
KDE should also have GUI controls to adjust audio levels from Firefox
Or install PulseAudio Volume Control - pavucontrol-qt
Or build myxer-bin
from AUR - Myxer: A modern Volume Mixer for PulseAudio.
inxi -SMAa ✔
Host: merlin800 Kernel: 6.11.2-4-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 14.2.1 clocksource: tsc avail: hpet,acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
root=UUID=a92d8ab9-a697-4fde-b491-1b5203791a4f rw splash
resume=UUID=cce62a56-a576-4050-a76b-cc2b12eecddd udev.log_priority=3
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Desktop System: HP product: HP EliteDesk 800 G3 SFF v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: HP model: 8299 v: KBC Version 06.21 serial: <superuser required>
part-nu: Z4D04ET#ABU uuid: <superuser required> UEFI: HP v: P01 Ver. 02.27
date: 04/14/2019
Device-1: Intel 200 Series PCH HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:a2f0 class-ID: 0403
API: ALSA v: k6.11.2-4-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
pactl list sinks ✔
Sink #63
State: SUSPENDED
Driver: PipeWire
Sample Specification: float32le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: no
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: easyeffects_sink.monitor
Latency: 0 usec, configured 0 usec
Flags: DECIBEL_VOLUME LATENCY
Properties:
application.id = "com.github.wwmm.easyeffects"
node.name = "easyeffects_sink"
device.description = "Easy Effects Sink"
node.virtual = "true"
node.passive = "out"
factory.name = "support.null-audio-sink"
media.class = "Audio/Sink"
audio.position = "FL,FR"
monitor.channel-volumes = "false"
monitor.passthrough = "true"
priority.session = "0"
factory.id = "19"
clock.quantum-limit = "8192"
client.id = "60"
node.driver = "true"
port.group = "stream.0"
node.loop.name = "data-loop.0"
library.name = "audioconvert/libspa-audioconvert"
object.id = "61"
object.serial = "63"
node.driver-id = "53"
Formats:
pcm
Sink #897
State: SUSPENDED
Driver: PipeWire
Sample Specification: s32le 2ch 48000Hz
Mute: no
balance 0.00
Monitor Source: alsa_output.pci-0000_00_1f.3.analog-stereo.monitor
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.card = "0"
alsa.class = "generic"
alsa.components = "HDA:14f15098,103c8299,00100100 HDA:8086280b,80860101,00100000"
alsa.device = "0"
alsa.id = "PCH"
alsa.long_card_name = "HDA Intel PCH at 0x1ff1010000 irq 136"
alsa.mixer_name = "Conexant CX20632"
alsa.name = "CX20632 Analog"
alsa.resolution_bits = "16"
alsa.subclass = "generic-mix"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.sync.id = "00000000:00000000:00000000:00000000"
api.alsa.card.longname = "HDA Intel PCH at 0x1ff1010000 irq 136"
api.alsa.card.name = "HDA Intel PCH"
api.alsa.path = "front:0"
api.alsa.pcm.card = "0"
api.alsa.pcm.stream = "playback"
audio.channels = "2"
card.profile.device = "7"
device.api = "alsa"
device.class = "sound"
device.id = "42"
device.profile.description = "Analog Stereo"
device.profile.name = "analog-stereo"
device.routes = "4"
factory.name = "api.alsa.pcm.sink"
device.description = "Built-in Audio"
node.name = "alsa_output.pci-0000_00_1f.3.analog-stereo"
node.nick = "CX20632 Analog"
node.pause-on-idle = "false"
object.path = "alsa:acp:PCH:7:playback"
port.group = "playback"
priority.driver = "1009"
priority.session = "1009"
factory.id = "19"
client.id = "41"
object.id = "53"
object.serial = "897"
api.acp.auto-port = "false"
api.alsa.card = "0"
api.alsa.use-acp = "true"
api.dbus.ReserveDevice1.Priority = "-20"
device.bus = "pci"
device.enum.api = "udev"
device.icon_name = "audio-card-analog-pci"
device.name = "alsa_card.pci-0000_00_1f.3"
device.nick = "HDA Intel PCH"
device.plugged.usec = "6095594"
device.product.id = "0xa2f0"
device.product.name = "200 Series PCH HD Audio"
device.subsystem = "sound"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.vendor.id = "0x8086"
device.string = "0"
Ports:
analog-output-speaker: Speakers (type: Speaker, priority: 10000, availability group: Legacy 4, not available)
analog-output-headphones: Headphones (type: Headphones, priority: 9900, availability group: Legacy 2, not available)
analog-output-headphones-2: Headphones 2 (type: Headphones, priority: 9800, availability group: Legacy 5, not available)
Active Port: analog-output-lineout
Formats:
pcm
As already stated, when running Firefox I am unable to alter volume from taskbar icon. For other sound based applications it works fine.
Since you are using Plasma, do you see a separate slider appear in System Settings
→ Audio
when audio is playing? If so, does that have any effect, or move “by itself” when audio level is adjusted in the browser?
Yes, when I open Browser (Youtube) and click a video a new section opens up.
And,yes it syncs with the Browser volume control.
It is assigned to EasyEffects sink.
So, do you mean adjusting the master volume has no effect (i.e. the taskbar icon mouse-over and scroll)? Is audio actually playing, or is that slider muted? (Check, it happens to me sometimes).
Exactly. It isnt muted either. I should add this is a new phenomenon to me. Always worked before. Cant pin it down to any update.
I am able to raise/lower volume if needed via the speaker volume control, so not that inconvenient, just a bit weird.
Issue is probably with plasma-pa
audio applet
plasma-pa
is inherited from Arch and latest version 6.2.3-1 is available on Testing branch
