Firefox only partial hardware acceleration (nvidia)
Hello,
I saw in about:support that i have unsupported HW:Accelerations, i was looking for a solution and i found out, that i need to install libva-nvidia-driver to get it working.
I still don’t have full HW Support yet but still the most necessary video codecs are supported after the package. Should i stay with partial HW Acceleration and call it a day or is there more i can do?
about:support and play a video file in your browser:
  Kernel: 6.1.64-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/vmlinuz-6.1-x86_64
    root=UUID=eb235aa7-d461-413d-800e-ea57385703fb rw quiet
    sysrq_always_enabled=1 nvidia_drm.modeset=1 retbleed=off
    resume=UUID=717b267e-7322-4bf9-a840-f1210d422d1a udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Desktop System: Gigabyte product: Z170X-UD3 v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: Z170X-UD3-CF v: x.x serial: <superuser required>
    UEFI-[Legacy]: American Megatrends v: F23d date: 12/01/2017
  System RAM: total: 16 GiB available: 15.58 GiB used: 4.63 GiB (29.7%)
  Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x5E (94) stepping: 3 microcode: 0xF0
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 4500 min/max: 800/4700 scaling: driver: intel_pstate
    governor: performance cores: 1: 4500 2: 4500 3: 4500 4: 4500 5: 4500 6: 4500
    7: 4500 8: 4500 bogomips: 64026
    dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Type: retbleed status: Vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: Micro-Star MSI
    driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2023-11; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: none off: DP-3 empty: DP-1, DP-2, HDMI-A-1, Unknown-1
    bus-ID: 01:00.0 chip-ID: 10de:1e07 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.9 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 122 s-size: 532x302mm (20.94x11.89")
    s-diag: 612mm (24.08")
  Monitor-1: DP-3 mapped: DP-4 note: disabled model: Dell S2417DG
    serial: <filter> built: 2018 res: 2560x1440 dpi: 123 gamma: 1.2
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
    max: 2560x1440 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2
    memory: 10.74 GiB
  API: Vulkan v: 1.3.269 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 2080 Ti driver: nvidia v: 545.29.06 device-ID: 10de:1e07
    surfaces: xcb,xlib
  Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
    class-ID: 0403
  Device-2: NVIDIA TU102 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 01:00.1 chip-ID: 10de:10f7 class-ID: 0403
  Device-3: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
    Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 0b:00.0 chip-ID: 1102:0012 class-ID: 0403
  API: ALSA v: k6.1.64-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
  Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 5.93 TiB used: 350.53 GiB (5.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: MP600 PRO LPX
    lanes: 4 tech: SSD serial: <filter> fw-rev: EIFM31.6 temp: 33.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 PRO 1TB
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HDN724030ALE640
    size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: A5E0 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: Portable SSD T5
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
    scheme: MBR
  ID-1: / raw-size: 88.61 GiB size: 86.66 GiB (97.80%) used: 18.72 GiB (21.6%)
    fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: N/A
    uuid: eb235aa7-d461-413d-800e-ea57385703fb
  ID-2: /boot raw-size: 200 MiB size: 188.2 MiB (94.09%)
    used: 113.1 MiB (60.1%) fs: ext3 dev: /dev/sdc3 maj-min: 8:35 label: N/A
    uuid: 26eda82e-b403-49b8-abca-202167417020
  ID-3: /home raw-size: 332.03 GiB size: 325.75 GiB (98.11%)
    used: 18.62 GiB (5.7%) fs: ext4 dev: /dev/sdc4 maj-min: 8:36 label: N/A
    uuid: ada4a6a2-bd0a-4652-b386-7c637bba7ee9
  ID-4: /media/nvme-games raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 279.8 GiB (15.3%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
    label: nvme-games uuid: 423e0b4c-a042-4ca4-9b01-f066f692d375
  ID-5: /media/temp raw-size: 63.48 GiB size: 62.18 GiB (97.96%)
    used: 32.77 GiB (52.7%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: temp
    uuid: 1e81b7c2-3438-438a-b572-ff8a966a78e1
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
  ID-1: swap-1 type: partition size: 7.81 GiB used: 526.2 MiB (6.6%)
    priority: -2 dev: /dev/sdc2 maj-min: 8:34 label: N/A
    uuid: 717b267e-7322-4bf9-a840-f1210d422d1a
  ID-1: /dev/sda1 maj-min: 8:1 size: 50 MiB fs: ntfs label: System-reserviert
    uuid: B2286A122869D5BF
  ID-2: /dev/sda2 maj-min: 8:2 size: 97.09 GiB fs: ntfs label: win10
    uuid: 5E60C09860C077F3
  ID-3: /dev/sda4 maj-min: 8:4 size: 782.51 GiB fs: ntfs label: games
    uuid: 165692E31D7ADAF2
  ID-4: /dev/sdb2 maj-min: 8:18 size: 1.57 TiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-5: /dev/sdb3 maj-min: 8:19 size: 1.09 TiB fs: <superuser required>
  Device-1: 1-13:2 info: A4Tech XL-730K / XL-750BK XL-755BK Mice
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 09da:9090 class-ID: 0301
  Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
  Device-1: 2-5:2 info: Samsung Portable SSD T5 type: mass storage
    driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 896mA chip-ID: 04e8:61f5 class-ID: 0806
    serial: <filter>
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 33 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 25%
  Processes: 279 Uptime: 6h 11m wakeups: 0 Init: systemd v: 254
  Packages: 1532 pm: pacman pkgs: 1526 libs: 439 tools: pamac pm: flatpak
  pkgs: 6 Shell: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
Firefox - about:config
media.av1.enabled	true
media.av1.use-dav1d	true
maximum av1, more is not possible as far as I know
Maybe try:
If hardware video acceleration is blocked with error code FEATURE_HARDWARE_VIDEO_DECODING_DISABLE in about:support , you can override it with media.hardware-video-decoding.force-enabled=true . See [11] for more information.
– Firefox - ArchWiki
Those values appear to be enabled by default and AV1 hardware decoding works for me.
I try’d that already… not working. The error code also not showed up in the support window.
Edit: Actually i had media.hardware-video-decoding.force-enabled = true already activated and i just set it to false again and check the result and the HW Acceleration is fully is gone.
So the command alone did not changed anything, but after install libva-nvidia-driver
the additional command gave me the HW Support.
Out of all of those decoders, Firefox won’t support HEVC for now
Mozilla will not support HEVC while it is encumbered by patents.
Also, to my understanding, hardware-accelerated AV1 decoding was introduced with 3000-series (and encoding with 4000-series) Nvidia cards.
Yeah true story… i still wondering why the other sound codecs are not have HW Support… even if i don’t really need it, but shouldn’t it supported by default?
If you have hardware that supports them. I don’t, so all the audio decoders are software-only for me :person_shrugging:
I have a Creative Soundblaster AE-5… but i have no idea about the Linux drivers for this Soundcard.
I haven’t had a dedicated sound card since I was a kid, so I have no idea what to do there :frowning:
This thread reminded me my ryzen was just on the cutoff for av1 accelerated decode.
So enhanced-h264ify – Get this Extension for 🦊 Firefox (en-US) it is :person_shrugging:
Maybe there is no HW Sound support, i need to check my Firefox in Win10.
