Login – install plasma-wayland-session/plasma-wayland-protocols – switch to 200% screen – Logout – Login – Firefox displays like this:
Dolphin, Pamac GUI, System Settings etc. Normal
But Firefox is blurred
i think you have to change something in about:config for hidpi.
200% ? maybe changing the resolution lower would give you better results.
But my screen is 2736*1824 so it must do ~200%
interesting resolution, so without 200 scaling everything’s tiny?
Yes, absolutely. That’s not a 1920x1080 and I do 200% also on windows
Did you find the solution?
You can run firefox like this:
MOZ_ENABLE_WAYLAND=1 firefox
I don’t know how to make it persistent.
i usually stick it in /etc/environment so it’s system wide.
Thank you
I’ve been reading Environment variables - ArchWiki but I don’t understand this.
