Firefox & Librewolf load CPU when VAAPI is active
Hi all, recently faced with the fact that I believe with hardware acceleration VAAPI I get a frenzied temperature and CPU frequency when watching any video, and in 144 resolution. I do not know why, but sometimes this acceleration is not enabled, and the browser behaves normally, does not heat up, and does not speed up. All hardware acceleration settings are set by default in about: config. Now I use Librevolf and Firefox is not installed, but if you install it exactly repeats what I described. How do I know what’s going on? I run sudo intel_gpu_top and see Video 5.00%-6%(for example, I didn’t see more than 8%), and that’s when the crash starts. If this column is empty, the browser behaves calmly. Disabling hardware acceleration in the browser itself further increases the processor speed to 100%. This does not apply to the test version of KDE Plasma, it happens on any, and chaotically, and when this happens, it is not possible to use the browser, I tried to explain as best I could). How can this be defeated? Спасибо
flatpak list --runtime         ✔  16s 
Имя                                 ID Приложения                                     Версия                  Ветвь        Тип установки
GStreamer VA-API                    com.obsproject.Studio.Plugin.GStreamerVaapi       0.4.1                   stable       system
GStreamer                           com.obsproject.Studio.Plugin.Gstreamer            0.4.1                   stable       system
Calf                                org.freedesktop.LinuxAudio.Plugins.Calf           0.90.3                  23.08        system
LSP                                 org.freedesktop.LinuxAudio.Plugins.LSP            1.2.17                  23.08        system
MDA                                 org.freedesktop.LinuxAudio.Plugins.MDA            1.2.10                  23.08        system
TAP-plugins                         org.freedesktop.LinuxAudio.Plugins.TAP            1.0.1                   23.08        system
ZamPlugins                          org.freedesktop.LinuxAudio.Plugins.ZamPlugins     4.2                     23.08        system
SWH                                 org.freedesktop.LinuxAudio.Plugins.swh            0.4.17                  23.08        system
Freedesktop Platform                org.freedesktop.Platform                          freedesktop-sdk-24.08.5 24.08        system
Mesa                                org.freedesktop.Platform.GL.default               24.2.5                  23.08        system
Mesa (Extra)                        org.freedesktop.Platform.GL.default               24.2.5                  23.08-extra  system
Mesa                                org.freedesktop.Platform.GL.default               24.2.5                  24.08        system
Mesa (Extra)                        org.freedesktop.Platform.GL.default               24.2.5                  24.08extra   system
Mesa                                org.freedesktop.Platform.GL32.default             24.2.5                  24.08        system
gstreamer-vaapi                     …g.freedesktop.Platform.GStreamer.gstreamer-vaapi                         23.08        system
Intel VAAPI driver                  org.freedesktop.Platform.VAAPI.Intel                                      23.08        system
Intel VAAPI driver                  org.freedesktop.Platform.VAAPI.Intel                                      24.08        system
FFmpeg extension with extra codecs  org.freedesktop.Platform.ffmpeg-full                                      24.08        system
i386                                org.freedesktop.Platform.ffmpeg_full.i386                                 24.08        system
openh264                            org.freedesktop.Platform.openh264                 2.4.1                   2.4.1        system
GNOME Application Platform version… org.gnome.Platform                                                        46           system
GNOME Application Platform version… org.gnome.Platform                                                        47           system
i386                                org.gnome.Platform.Compat.i386                                            47           system
Breeze GTK theme                    org.gtk.Gtk3theme.Breeze                          6.2.0                   3.22         system
Adwaita theme                       org.kde.KStyle.Adwaita                                                    6.7          system
KDE Application Platform            org.kde.Platform                                                          6.7          system
gecko                               org.winehq.Wine.gecko                                                     stable-24.08 system
mono                                org.winehq.Wine.mono                                                      stable-24.08 system
LibreWolf              io.gitlab.librewolf-community               131.0.3-1          stable         system
inxi --admin --verbosity=8 --filter --no-host --width         ✔
  Kernel: 6.11.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
    root=UUID=b326b8d9-9b77-469c-9ab8-526f002cbfba rw quiet splash
    resume=UUID=0fce9c48-9f96-4bc5-9c34-5ffc0f3c6c62 udev.log_priority=3
    mitigations=off
  Desktop: KDE Plasma v: 6.2.2 tk: Qt v: N/A info: frameworks v: 6.7.0
  Type: Laptop System: ASUSTeK product: TP300LDB v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: TP300LDB v: 1.0 serial: <superuser required>
    part-nu: ASUS-NotebookSKU uuid: <superuser required>
    UEFI: American Megatrends v: TP300LDB.211 date: 04/16/2019
  ID-1: BAT0 charge: 40.8 Wh (100.0%) condition: 40.8/50.1 Wh (81.4%)
    volts: 11.3 min: 11.3 model: ASUSTeK UX3-44 type: Li-ion serial: N/A
    status: not charging cycles: 1078
  System RAM: total: 12 GiB available: 11.12 GiB used: 4.71 GiB (42.4%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: N/A serial: N/A
  Device-2: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
    manufacturer: 1201 part-no: R538G1601S2SL serial: N/A
  Info: model: Intel Core i5-5200U bits: 64 type: MT MCP arch: Broadwell
    gen: core 5 level: v3 note: check built: 2015-18 process: Intel 14nm
    family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2529 min/max: 500/2700 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 2529 2: 2529 3: 2529 4: 2529 bogomips: 17567
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
    avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt invpcid lahf_lm
    lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat
    pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts
    rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
    tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
  Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
  Type: mds status: Vulnerable; SMT vulnerable
  Type: meltdown status: Vulnerable
  Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
    usercopy barriers only; no swapgs barriers
  Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
  Type: srbds status: Vulnerable
  Device-1: Intel HD Graphics 5500 vendor: ASUSTeK driver: i915 v: kernel
    arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
    empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
  Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
    620M/625M/630M/720M] vendor: ASUSTeK driver: nouveau v: kernel non-free:
    series: 390.xx+ status: legacy (EOL~2022-11-22) last: release: 390.157
    kernel: 6.0 xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm
    built: 2010-2016 pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: lanes: 8
    bus-ID: 03:00.0 chip-ID: 10de:1140 class-ID: 0302
  Device-3: Suyin Asus Integrated Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-5:4 chip-ID: 064e:9700
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris,nouveau gpu: i915,nouveau display-ID: 0
  Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
    device: 0 drv: iris device: 1 drv: nouveau device: 2 drv: swrast gbm:
    drv: iris surfaceless: drv: iris wayland: drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa v: 24.2.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW GT2)
    device-ID: 8086:1616 memory: 5.43 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.3.295 layers: N/A device: 0 type: integrated-gpu
    name: Intel HD Graphics 5500 (BDW GT2) driver: mesa intel v: 24.2.5-arch1.1
    device-ID: 8086:1616 surfaces: xcb,xlib,wayland
  Device-1: Intel Broadwell-U Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
    class-ID: 0403
  API: ALSA v: k6.11.5-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
  Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:08b1 class-ID: 0280
  IF-ID-1: CloudflareWARP state: unknown speed: 10000 Mbps duplex: full
    mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-4:3 chip-ID: 8087:07dc
    class-ID: e001
  Local Storage: total: 447.13 GiB used: 59.35 GiB (13.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: TR200 size: 447.13 GiB
    block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
    serial: <filter> fw-rev: 13.6 scheme: GPT
  ID-1: / raw-size: 146.48 GiB size: 143.13 GiB (97.71%)
    used: 24.23 GiB (16.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: b326b8d9-9b77-469c-9ab8-526f002cbfba
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: B8A9-BAA4
  ID-3: /home raw-size: 284.73 GiB size: 279.2 GiB (98.06%)
    used: 35.12 GiB (12.6%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: b69511a1-4ed8-4c95-be54-807f86927a04
  Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
    zswap: yes compressor: zstd max-pool: 20%
  ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 0fce9c48-9f96-4bc5-9c34-5ffc0f3c6c62
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8001
  Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 11 rev: 2.0
  Device-1: 2-3:2 info: YICHIP Wireless Device type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3151:3020 class-ID: 0301
  Device-2: 2-4:3 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:07dc class-ID: e001
  Device-3: 2-5:4 info: Suyin Asus Integrated Webcam type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 064e:9700 class-ID: 0e02 serial: <filter>
  Device-4: 2-7:5 info: Atmel type: HID
    driver: hid-generic,hid-multitouch,usbhid interfaces: 2 rev: 2.0
    chip-ID: 03eb:8b04 class-ID: 0300
  Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 62.0 C pch: 47.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 3000
  Packages: 1415 pm: pacman pkgs: 1378 libs: 377 tools: pamac pm: flatpak
    pkgs: 37
    1: https://manjaro.mirrors.lavatech.top/unstable/$repo/$arch
    2: https://codingflyboy.mm.fcix.net/manjaro/unstable/$repo/$arch
    3: https://mirrors.ocf.berkeley.edu/manjaro/unstable/$repo/$arch
    4: https://mirror.ufro.cl/manjaro/unstable/$repo/$arch
    5: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/unstable/$repo/$arch
Processes:
  CPU top: 5 of 235
  1: cpu: 100% command: ps pid: 29537 mem: 3.61 MiB (0.0%)
  2: cpu: 49.8% command: librewolf pid: 26879 mem: 666.7 MiB (5.8%)
  3: cpu: 32.2% command: librewolf pid: 27122 mem: 264.2 MiB (2.3%)
  4: cpu: 25.2% command: librewolf pid: 27270 mem: 470.6 MiB (4.1%)
  5: cpu: 19.4% command: easyeffects pid: 24846 mem: 172.9 MiB (1.5%)
  Memory top: 5 of 235
  1: mem: 666.7 MiB (5.8%) command: librewolf pid: 26879 cpu: 49.8%
  2: mem: 525.7 MiB (4.6%) command: plasmashell pid: 1084 cpu: 1.2%
  3: mem: 470.6 MiB (4.1%) command: librewolf pid: 27270 cpu: 25.2%
  4: mem: 352.7 MiB (3.0%) command: librewolf pid: 28247 cpu: 14.0%
  5: mem: 316.5 MiB (2.7%) command: librewolf pid: 26990 cpu: 2.3%
  Processes: 235 Power: uptime: 5h 17m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 4.42 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.36
Graphics
Opportunities
Device window pixel ratios 2.2
WebRender Compositing
Linux font visibility debugging information Unknown-ID=org.fr
Asynchronous pan / zoom enabled wheel input; touch input enabled; scrollbar dragging enabled; keyboard enabled; auto-scrolling enabled; smooth gesture zooming enabled
WebGL 1-WSI Driver Information-
WebGL 1 - The WebGL driver visualizer is currently disabled.
WebGL 1-Driver Version -
WebGL 1 - Driver Extensions -
WebGL 1 - Extensions -
WebGL 2 - WSI Driver information -
WebGL 2 - The WebGL Driver Visualizer is currently disabled.
WebGL 2-Driver Version -
WebGL 2 - Driver Extensions -
WebGL 2-Extensions -
wayland Window Management Protocol
KDE desktop environment
Target frame rate 60
Default WebGPU adapter {
  "navigator. gpu": null
Backup WebGPU Adapter {
  "navigator.gpu": null
Video Card #1
Active Yes
Description of Mesa Intel (R) HD Graphics 5500 (BDW GT2)
Manufacturer code 0x8086
Device code 0x1616
MESA/iris Driver Provider
Driver version 24.2.5.0 Video
memory 0
Video Card #2
Active None
Manufacturer's code 0x10de
Device code 0x1140
Diagnostics
AzureCanvasBackend	skia
AzureContentBackend	skia
AzureFallbackCanvasBackend	skia
CMSOutputProfile	Empty profile data
Display0	1920x1080@60Hz scales:2.000000|2.000000
DisplayCount	1
Solution Log
HW_COMPOSITING
default	available
OPENGL_COMPOSITING
default	available
WEBRENDER
default	available
WEBRENDER_COMPOSITOR
default disabled Disabled by default Blocked; error code
FEATURE_FAILURE_DISABLED env blocklisted Blocklisted by gfxInfo Blocked; error code FEATURE_FAILURE_WEBRENDER_COMPOSITOR_DISABLED
runtime blocked Cannot be enabled in release or beta Blocked; error code FEATURE_FAILURE_DISABLE_RELEASE_OR_BETA
WEBRENDER_PARTIAL
default available
WEBRENDER_SHADER_CACHE
default	disabled	Disabled by default	Заблокировано; код ошибки FEATURE_FAILURE_DISABLED
WEBRENDER_OPTIMIZED_SHADERS
default	available
WEBRENDER_ANGLE
default	available
env unavailable OS not supported Blocked; error code FEATURE_FAILURE_OS_NOT_SUPPORTED
WEBRENDER_DCOMP_PRESENT
default available
user disabled User disabled via pref Blocked; error code
FEATURE_FAILURE_DCOMP_PREF_DISABLED env unavailable Requires GPU process Blocked; error code FEATURE_FAILURE_NO__PU_PROCESS
runtime unavailable Requires ANGLE Blocked; error code FEATURE_FAILURE_DCOMP_NOT_ANGLE
WEBRENDER_SCISSORED_CACHE_CLEARS
default available
WEBGPU
default	available
runtime	blocked	WebGPU cannot be enabled in release or beta	Заблокировано; код ошибки WEBGPU_DISABLE_RELEASE_OR_BETA
X11_EGL
default	available
DMABUF
default	available
HARDWARE_VIDEO_DECODING
default	available
HW_DECODED_VIDEO_ZERO_COPY
default	available
VP8_HW_DECODE
default	available
VP9_HW_DECODE
default	available
env	blocklisted	#BLOCKLIST_FEATURE_FAILURE_VIDEO_DECODING_MISSING	Заблокировано; код ошибки FEATURE_FAILURE_VIDEO_DECODING_MISSING
DMABUF_SURFACE_EXPORT
default	blocked	Blocklisted by gfxInfo	Заблокировано; код ошибки FEATURE_FAILURE_BROKEN_DRIVER
BACKDROP_FILTER
default	available
CANVAS_RENDERER_THREAD
default	available
ACCELERATED_CANVAS2D
default	available
H264_HW_DECODE
default	available
AV1_HW_DECODE
default	available
env blocklisted #BLOCKLIST_FEATURE_FAILURE_VIDEO_DECODING_MISSING Blocked; error code
REMOTE_CANVAS default disabled Disabled via pref Blocked; error code
FEATURE_FAILURE_DISABLED env unavailable-no-gpu-process Disabled without GPU process Blocked; error code FEATURE_REMOTE_CANVAS_NO__PU_PROCESS
runtime blocked Platform not supported Blocked; error code FEATURE_REMOTE_CANVAS_NOT_WINDOWS
Media
pulse-rust audio subsystem
Maximum number of channels 2
Preferred sampling rate is 48000
Circular Delay (Standard deviation) 97.00 ms (17.39)
Codec Support Information
Codec name Software decoding Hardware Decoding
H264 Supported Supported
VP9 Supported Not Supported
VP8 Supported Supported
AV1 Supported Not Supported
HEVC Not supported Not supported
AAC Supported Not Supported
MP3 Supported Not Supported
Opus Supported Not Supported
Vorbis Supported Not Supported
FLAC Supported Not Supported
Wave Supported Not Supported
