Since yesterday whenever I start Firefox the tabs won’t load but instead keeps going backwards to the front page. It is not possible to load a page. Every tab just goes back and keeps loading.
if the problem comes from an bad addon or problems in your profile you can export your bookmarks as @Mirdarthos say and starting firefox over the profile manager. In profile manager create a new profile and there reimport your bookmarks.
Starting Firefox profile manager:
firefox -p
In profile manager you can also set the new profile to default, so normal starting firefox will load the new profile.
So you will have also an “backup” of your old profile in reach. And for each profile there should be a directory in ‘~/mozilla/firefox/’ which hold the data for every sigle profile.
I make a backup of the two files corresponding to firefox and thunderbird.
These two files are .mozilla and .thunderbird in the home directory.
The files are hidden.
places.sqlite is your bookmarks. They are in your profile folder. FF automatically backs up bookmarks in your profile folder as well in a folder called bookmarksbackup. If you open Bookmarks Manager, Import and Backup- Choose Restore and the contents of the bookmarksbackupfolder are shown.
places.sqlite=bookmarks
logins.json = saved passwords
key4.db= has to do with passwords, I don’t remember exactly, but worth backing up
search.json.mozlz4= Search engines, including custom
cert9.db=certificates
prefs.js- self explanatory
