I’ve reported this as a bug in bugzilla, but it seems that nobody is looking at it…and it’s so annoying :S i’ll leave here the link to it: 1766567 - Font changed in some sites but also put the description here:
User Agent: Mozilla/5.0 (X11; Linux x86_64; rv:99.0) Gecko/20100101 Firefox/99.0
Steps to reproduce:
If i enter some sites, the font changed after i’ve installed some fonts in Manjaro with Gnome in this folder with admin privileges /usr/share/fonts and then the error began to happen :S
I’ve copied them from a folder to /usr/share/fonts/TTF with admin privileges…didn’t know i could use pamac for that…so do i need to go one by one installing them from there? what if they don’t appear?
I have a folder where i put all the fonts i like and take them to any computer, they are like 100, but didn’t overwrite any.
No, didn’t know i could do that :S and not all the fonts appear there
I think you can see that accents in spanish show weird and also the font itself its pretty hard to read i’ll put a comparisson here (cause in chrome it works just fine)
IT WORKED!!! everything back to normal!!! THANKS A LOT!!! so, next time, i just create that folder and put all my fonts and voilá, it’s even faster than having to open the other one as an admin!
Ok, but how can i restore the other folder where i’ve put all the fonts? cause what I did was to order them in last modified order and selected the last 100 and moved them to the new .font folder and that was how it worked…but hope i didn’t moved an important Manjaro font
And just, one final doubt, what’s the difference between this two? cause i’ve only created and moved all the font files to the fist one.
Generally speaking, for casual users, system wide installation shall be left to the package manager. Users can “install” something within their home, not requiring superuser privileges to install, run, and remove it.
Well, that was something you could have checked before moving the files. For instance, selecting only the files modified within the last day was very possible…
If you have a backup of your system, you could check what’s in it.
Manual installation
The recommended way of adding fonts that are not in the repositories of your system is described in #Creating a package. This gives pacman the ability to remove or update them at a later time.
Alternatively, fonts can be installed manually:
For a single user, install fonts to ~/.local/share/fonts/.
In many cases this suffices, unless you run graphical applications as other users.
In the past ~/.fonts/ was used, but is now deprecated.
Ok, lessons learned, but for now, it’s not working because surely y did something with the fonts, so, changed it to the ~/.local/share/fonts but still not working right :S
Is there a way in which someone could copy that folder (/usr/share/fonts/TTF) on a google drive and send me the link so i can download it and overwrite it? maybe that will solve my problem and won’t do that mistake again
Sorry, i’m not a programmer and just changed from Windows to Linux, i’m in learning curve… and what does that do? it resets the folder in sort of speak? that would be awesome!
AWESOME!!! Thanks for the explanation! i did it and yes, i had 145 fonts after i took away the ones i thought i’ve added, and now it has 171…so, let’s hope this works and i will never touch those folders well, at least until i’m sure of what i’m doing
But unfortunately, noup, it didn’t solve the font problem in Firefox pages and now it also happens in instagram and facebook, where do you think the problem could be? i’m going to erase the folder ~/.local/share/fonts to see if that’s the problem.
YES!!! it worked! but then, how should i install my fonts? and how do i know which one is causing the problem? now i’m afraid but i need to use different fonts don’t understand why that happens only with Firefox… is it a bug? what do you recommend me to do? does it happen only to me? jajaja…sorry, i’m a bit frustrated here
Just a hint: If there is the same font name at home folder and at the global folder, then the home folder is always prioritized. Therefore I would check for equal names. Obviously the font at your home folder must have the same name as in the global folder, but its formatting is different.
