Firefox bookmarks sidebar almost complete white, not readable
Hi all,
I am using Firefox 146.0-1 (64 Bit). After the last upgrade on Wed 10.12.2025 to this version, the bookmarks and history sidebar are not readable since the entries appear with white font on white background. The icons if available are the only visible items.
Hovering around, the item under the mouse position is shown with white text color and very-light-grey background. It is nearly unreadable.
Only by clicking on a well-known icon, the webpage opens and the bookmark text ist visible with white font on black background.
It does not matter whether the Firefox apperance mode (not sure about the English terms) is set to bright, dark or automatic.
It would be great if anyone could help. Thank you in advance!
Output of inxi -zv8:
  Kernel: 6.18.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=35ec319e-09bb-4c44-bd1d-3fe78a3ab59c rw quiet splash apparmor=1
  Desktop: GNOME v: 49.2 tk: GTK v: 3.24.51 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 49.2 Distro: Manjaro
    base: Arch Linux
  Type: Desktop System: Gigabyte product: A520M S2H v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: A520M S2H v: x.x serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
    v: F19b date: 07/11/2024
  System RAM: total: 16 GiB available: 14.99 GiB used: 3.34 GiB (22.3%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-3200C16-8GIS serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
    microcode: 0xA500012
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 2991 min/max: 422/4674 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 2991 2: 2991 3: 2991
    4: 2991 5: 2991 6: 2991 7: 2991 8: 2991 9: 2991 10: 2991 11: 2991 12: 2991
    13: 2991 14: 2991 15: 2991 16: 2991 bogomips: 121372
    stibp succor svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
    v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
    wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] vendor: Gigabyte driver: amdgpu v: kernel
    arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
    speed: 8 GT/s lanes: 16 ports: active: HDMI-A-2 empty: DP-1,HDMI-A-1
    bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 32.0 C
  Device-2: Generalplus GENERAL WEBCAM driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:2
    chip-ID: 1b3f:2247 class-ID: 0102 serial: <filter>
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: crocus gpu: amdgpu display-ID: 0
  Monitor-1: HDMI-A-2 model: NEC EA231WMi serial: <filter> built: 2009
    res: 1920x1080 dpi: 96 gamma: 1.2 chroma: red: x: 0.643 y: 0.333 green:
    x: 0.302 y: 0.616 blue: x: 0.145 y: 0.071 white: x: 0.314 y: 0.329
    size: 510x287mm (20.08x11.3") diag: 585mm (23") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1400x1050, 1600x900, 1280x1024, 1440x900,
    1280x960, 1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600,
    720x576, 720x480, 640x480, 720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.1-arch1.2
    renoir ACO DRM 3.64 6.18.0-1-MANJARO) device-ID: 1002:1638 memory: 500 MiB
    unified: no display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xdpyinfo,xprop
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
    bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-3: Generalplus GENERAL WEBCAM driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.18.0-1-MANJARO status: kernel-api with: aoss
  Server-2: JACK v: 1.9.22 status: off with: a2jmidid status: off
    tools: jack_control,qjackctl
  Server-3: PipeWire v: 1.4.9 status: off with: 1: wireplumber status: off
    2: pipewire-alsa type: plugin tools: pw-cat,pw-cli,wpctl
  Server-4: PulseAudio v: 17.0-93-gbe2efb status: active with:
    tools: pacat,pactl,pavucontrol
    lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Local Storage: total: 15.46 TiB used: 8.8 TiB (56.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
    lanes: 4 tech: SSD serial: <filter> fw-rev: SCP00102 temp: 41.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST8000VN004-3CP101
    size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: SC60
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM000-1F2168
    size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 5900 serial: <filter> fw-rev: CC54 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST4000DM004-2CV104
    tech: HDD rpm: 5425 serial: <filter> fw-rev: 0001 scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH16NS55 rev: 1.00
    dev-links: cdrom
  ID-1: / raw-size: 48.83 GiB size: 47.76 GiB (97.81%) used: 31.62 GiB (66.2%)
    fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1 label: root
    uuid: 35ec319e-09bb-4c44-bd1d-3fe78a3ab59c
  ID-2: /boot/efi raw-size: 866.2 MiB size: 864.5 MiB (99.80%)
    used: 324 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
    uuid: AB88-2F26
  ID-3: /home raw-size: 849.61 GiB size: 849.61 GiB (100.00%)
    used: 835.29 GiB (98.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: home uuid: 2d70cdb3-28a4-48b8-a37c-a924500b2bd4
  ID-4: /mnt/Archiv1 raw-size: 3.62 TiB size: 3.62 TiB (100.00%)
    used: 3.61 TiB (99.7%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17 label: Archiv1
    uuid: 55b25928-a708-4f5f-89fd-828b0d04e455
  ID-5: /mnt/Archiv2 raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
    used: 3.63 TiB (99.7%) fs: btrfs dev: /dev/sdc1 maj-min: 8:33 label: Archiv2
    uuid: 2b666169-36d6-4762-a7dc-362965d4fc05
  ID-6: /mnt/Archiv3 raw-size: 7.28 TiB size: 7.28 TiB (100.00%)
    used: 732.72 GiB (9.8%) fs: btrfs dev: /dev/sda maj-min: 8:0 label: Archiv3
    uuid: 1d423d8c-eccd-4ca0-b0f7-b6b52f53f6d1
  ID-7: /mnt/DiskStorage raw-size: N/A size: 15.37 TiB
    used: 8.77 TiB (57.1%) fs: fuse.mergerfs
    logical: home:mnt/Archiv1:mnt/Archiv2:mnt/Archiv3
  ID-1: swap-1 type: partition size: 32.23 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: 23fcba61-42b9-449b-bedc-1120dbf49688
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0
  Device-1: 1-7:2 info: Generalplus GENERAL WEBCAM type: video,audio
  Device-2: 1-9:3 info: Integrated Express RGB LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
  Device-1: 3-1:2 info: Microsoft Wired Keyboard 400 type: keyboard
    chip-ID: 045e:0752 class-ID: 0301
  Device-2: 3-2:3 info: Microsoft Basic Optical Mouse v2.0 type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 045e:00cb class-ID: 0301
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 38.4 C mobo: 30.0 C gpu: amdgpu temp: 33.0 C
  Fan Speeds (rpm): N/A
  Packages: 1897 pm: pacman pkgs: 1883 libs: 440 tools: gnome-software,pamac
    pm: flatpak pkgs: 14
    1: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    2: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
    3: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    4: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    5: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    6: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    8: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 489
  1: cpu: 17.6% command: localsearch-extractor-3 pid: 8552
    mem: 45.2 MiB (0.2%)
  2: cpu: 8.4% command: firefox pid: 5287 mem: 628.3 MiB (4.0%)
  3: cpu: 4.7% command: firefox pid: 6054 mem: 279.8 MiB (1.8%)
  4: cpu: 4.0% command: gnome-shell pid: 3105 mem: 303.4 MiB (1.9%)
  5: cpu: 3.0% command: localsearch-3 pid: 3595 mem: 40.6 MiB (0.2%)
  Memory top: 5 of 489
  1: mem: 628.3 MiB (4.0%) command: firefox pid: 5287 cpu: 8.4%
  2: mem: 510.2 MiB (3.3%) command: firefox pid: 6068 cpu: 3.0%
  3: mem: 303.4 MiB (1.9%) command: gnome-shell pid: 3105 cpu: 4.0%
  4: mem: 279.8 MiB (1.8%) command: firefox pid: 6054 cpu: 4.7%
  5: mem: 251.2 MiB (1.6%) command: firefox pid: 5982 cpu: 1.8%
  Processes: 489 Power: uptime: 4m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.97 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9
    running-in: gnome-terminal inxi: 3.3.40
I helped myself:
First, I played with settings and discovered that adding a theme brings back readable sidebars. But I didn’t like most themes. I discovered a “system theme - automatic” and activated it. Now the sidebars look like before in dark mode: white text color, dark background.
