Mozilla apps seem to have twisted mind on their own for placing new windows in dual monitor setup. For example they follow mouse cursor when opening new windows instead of sticking to one monitor. If you move your mouse in a split second when opening the app you are in for a surprise… There is another annoying behavior when computer wakes from sleep and mozilla apps always end up on secondary monitor.
Is there any way to force this apps to stick to selected monitor?
“Primary display” is properly set as primary AND display no.1 in display settings, no problem here. Off course one of the displays will always be detected first but this should not affect application behavior and afaik mozilla apps are the only ones behaving like this.
I forgot to mention earlier but this switch to secondary monitor also happens after display sleep when, I believe, displays are not being detected again.
@linux-aarhus is correct, go to System Settings > Windows > Behavior
From there you can command where windows go when opening. Note: Chromium/Chrome have a mind of their own.
My settings are like this. Doesn’t matter which one I choose instead of Automatic, firefox seems to always follow the cursor and change to secondary screen after sleep. No problems with chrome. Or any other application.
Like I said, all options work exactly the same for firefox - firefox follows cursor. The only slight exception is Manual where I need to confirm window placement with click.
Devilspie2 does help when opening new firefox window so I can force it to always open on the same monitor. Sadly firefox will still migrate to secondary monitor after sleep. Shame on you mozilla.
