For the past month, randomly all of the non system applications open will crash, like Firefox and discord, however applications like settings, are perfectly fine and stays open. Afterwards, I can open them back up just fine and keep using them until they crash again. I have opened the apps with the command line and looked for errors that come when they crash, however none occur at the time of the crash. I was wondering if anyone had a similar issue, and or knew how to fix it? Thanks
Maybe start with system info
inxi -Fazy
sorry about that
Kernel: 6.5.13-7-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=9630c494-0a4a-43d7-a8b4-9ea15c78698f rw quiet
cryptdevice=UUID=2fabc450-56f0-4337-a516-9d3b0a6e5a03:luks-2fabc450-56f0-4337-a516-9d3b0a6e5a03
root=/dev/mapper/luks-2fabc450-56f0-4337-a516-9d3b0a6e5a03 splash
Desktop: GNOME v: 45.2 tk: GTK v: 3.24.39 wm: gnome-shell dm: GDM v: 45.0.1
Type: Laptop System: LENOVO product: 81SY v: Legion Y540-15IRH-PG0
serial: <superuser required> Chassis: type: 10 v: Legion Y540-15IRH-PG0
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
serial: <superuser required> UEFI: LENOVO v: BHCN42WW date: 05/21/2021
ID-1: BAT0 charge: 45.4 Wh (100.0%) condition: 45.4/52.5 Wh (86.5%)
volts: 12.7 min: 11.4 model: SMP L17M3PG3 type: Li-poly serial: <filter>
status: full cycles: 113
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2821 high: 4299 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 4291 2: 800 3: 800 4: 800
5: 800 6: 800 7: 4294 8: 4255 9: 4208 10: 4271 11: 4299 12: 4243
bogomips: 62431
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
driver: nouveau v: kernel non-free: 545.xx+ status: current (as of 2023-11;
EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
temp: 38.0 C
Device-2: Microdia Webcam Vitade AF driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2.3:8
chip-ID: 0c45:6366 class-ID: 0102 serial: <filter>
Device-3: Lite-On Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 04ca:7070
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: nouveau gpu: nouveau display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0700 built: 2016 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 800x600
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau wayland:
drv: nouveau x11: drv: nouveau
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: NV167 device-ID: 10de:1f91
memory: 3.89 GiB unified: no display-ID: :0.0
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
class-ID: 0403
Device-3: C-Media Audio Adapter (Unitek Y-247A)
driver: cmedia_hs100b,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-2.1:4 chip-ID: 0d8c:0014 class-ID: 0300
Device-4: Microdia Webcam Vitade AF driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.5.13-7-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: off tools: pw-cli
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: yes pairing: yes class-ID: 7c010c
Local Storage: total: 1.14 TiB used: 28.66 GiB (2.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB256HBHQ-000L2
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 3L1QEXH7 temp: 31.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172
tech: HDD rpm: 7200 serial: <filter> fw-rev: LXM3 scheme: GPT
ID-1: / raw-size: 89.16 GiB size: 87.21 GiB (97.81%) used: 28.63 GiB (32.8%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-2fabc450-56f0-4337-a516-9d3b0a6e5a03
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 28.9 MiB (11.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 58.0 C pch: 51.0 C mobo: N/A gpu: nouveau
temp: 38.0 C
Fan Speeds (rpm): N/A
Processes: 361 Uptime: 2h 2m wakeups: 1 Memory: total: 8 GiB
available: 7.68 GiB used: 3.44 GiB (44.8%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1296 libs: 357 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.31
You have no SWAP.
It is expected you will lock up when you hit the 7.68G of memory use.
You have a number of options for SWAP β¦ I usually recommend zram these days.
Continuing the discussion from Awful performance since install:
PS.
The 6.5 kernel is EOL. Please install 6.6, boot into it, and remove 6.5.
Ok thank you so much!
Set up the swap. I suggest you zram
: zram - ArchWiki Install zram-generator
zram - ArchWiki
After changing to a fresher kernel (e.g. 6.6) I would recommend to install the proprietary Nvidia driver for your graphics device:
sudo mhwd -a pci nonfree 0300
Any particular reason you are dividing by 1?
Yeah - most guides have it divide by 4 or 5, etc.
I keep the division there to denote the possibility of using arithmetic.
But I find that usually a zram (swap) device equal to RAM is usually roughly what is desired.
Also, given the compression ratio (in this case of zstd) this should mean that at any given point, if all things are filled β¦ it should only take at maximum somewhere around 1/4 of the physical RAM for that compressed swap device.
(see more of the technical mathematics at the archwiki: zram - ArchWiki)
Ok, makes sense I guess. Just asked because itβs redundant. I know it takes around 1/4 to 1/5 of what the setting is (with zstd compression at least). I use ram / 2, but with twice as much ram.
And if you build (big, blink) browsers then it will probably not be enough
