Hello there! After the upgrade to Firefox 89 I get random crashes and choppy out of sync videos on Youtube (works smooth in Chromium). It gets slightly better if I disable all extensions (less crashes, still bad video). Tried removing my .mozilla folder, troubleshoot mode, refresh firefox and reinstalling all firefox packages. Still no luck.
Any help is greatly appreciated because I really like and have a long relationship with Firefox since 1.0 ![]()
My inxi
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.11.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=f657ea71-cca9-4d7c-9550-42aa84924c79 rw quiet apparmor=1
Desktop: Cinnamon 4.8.6 tk: GTK 3.24.29 vt: 7 dm: LightDM 1.30.0
Type: Desktop Mobo: Intel model: D54250WYK v: H13922-303 serial: <filter>
BIOS: Intel v: WYLPT10H.86A.0054.2019.0902.1752 date: 09/02/2019
RAM: total: 15.53 GiB used: 4.86 GiB (31.3%)
Info: Dual Core model: Intel Core i5-4250U bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26 cache:
L2: 3 MiB bogomips: 15171
Speed: 798 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 798 2: 798
3: 1183 4: 1297
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:0a26 class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-1.4.4:7 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.20.11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI1 res: 1920x1080 hz: 60 dpi: 96 size: 510x290mm (20.1x11.4")
diag: 587mm (23.1")
OpenGL: renderer: llvmpipe (LLVM 11.1.0 256 bits) v: 4.5 Mesa 21.0.3
compat-v: 3.1 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.11.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Intel Ethernet I218-V driver: e1000e v: kernel port: f080
bus-ID: 00:19.0 chip-ID: 8086:1559 class-ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel port: f040
bus-ID: 02:00.0 chip-ID: 8086:08b1 class-ID: 0280
bus-ID: 1-1.7:5 chip-ID: 8087:07dc class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
Local Storage: total: 931.51 GiB used: 490.03 GiB (52.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 1TB
rotation: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-1: / raw-size: 93.32 GiB size: 91.36 GiB (97.89%) used: 34.24 GiB (37.5%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: f657ea71-cca9-4d7c-9550-42aa84924c79
ID-2: /home raw-size: 823.29 GiB size: 810.24 GiB (98.42%)
used: 455.79 GiB (56.3%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 4f19f012-020f-43ab-8c10-7a114deaec38
ID-1: /dev/sda2 maj-min: 8:2 size: 1 KiB fs: <superuser required> label: N/A
uuid: N/A
ID-2: /dev/sda6 maj-min: 8:6 size: 14.9 GiB fs: swap label: N/A
uuid: 650fe82c-7262-4579-99c6-e9790e524522
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-3: 1-1.3:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-1.3.1:10 info: eTurboTouch TD2340 230 SP13005 Touch Panel
type: HID driver: hid-generic,hid-multitouch,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 22b9:0021 class-ID: 0300
Hub-4: 1-1.4:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-5: 1-1.4.1:6 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-1.4.1.1:8 info: Xenta 2.4G Receiver type: Keyboard,Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 1d57:fa60 class-ID: 0300
Device-2: 1-1.4.1.3:9 info: Shenzhen Rapoo 2.4G Wireless Device Serial
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 24ae:2000 class-ID: 0301
Device-3: 1-1.4.4:7 info: Logitech Webcam C270 type: Video,Audio
power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Device-4: 1-1.7:5 info: Intel Bluetooth wireless interface type: Bluetooth
System Temperatures: cpu: 54.0 C mobo: 27.8 C
Processes: 243 Uptime: 9h 44m wakeups: 0 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1601
pacman: 1587 lib: 444 flatpak: 5 snap: 9 Shell: Bash v: 5.1.8
running-in: gnome-terminal inxi: 3.3.04
Also posted a question with crash reports over at mozilla:
https://support.mozilla.org/en-US/questions/1338461
Any ideas? ![]()
