Should I have received it already, or do I have an update problem? I have the standard firefox browser that comes with the OS. this is my current version:
80.0.1 (64-bit)
inxi -Fxxxrza
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=d7a0274b-6c69-4419-be7e-089b7b33e931 rw quiet
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B365M-A v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 1203
date: 10/10/2019
Info: 8-Core model: Intel Core i7-9700 bits: 64 type: MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: D (13)
microcode: D6 L2 cache: 12.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
vmx
bogomips: 48016
Speed: 3239 MHz min/max: 800/4700 MHz Core speeds (MHz):
1: 3239 2: 1337 3: 1533 4: 1051 5: 1807 6: 1488 7: 1126
8: 2321
Vulnerabilities: Type: itlb_multihit
status: KVM: Split huge pages
Type: spec_store_bypass mitigation: Speculative Store Bypass
disabled via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and
__user pointer sanitization
Type: spectre_v2
mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:3e98
Device-2: IMC Networks XHC Camera type: USB driver: uvcvideo
bus ID: 1-7.3:8 chip ID: 13d3:784b
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11
driver: intel unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96
s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: DP1 res: 1920x1080 hz: 60 dpi: 102
size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
Monitor-2: HDMI2 res: 1920x1080 hz: 60 dpi: 94
size: 520x290mm (20.5x11.4") diag: 595mm (23.4")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
v: 4.6 Mesa 20.1.7 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:a2f0
Device-2: JMTek LLC. type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-7.4:9
chip ID: 0c76:161f
Sound Server: ALSA v: k5.8.6-1-MANJARO
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit
Ethernet
vendor: ASUSTeK driver: r8169 v: kernel port: e000
bus ID: 03:00.0 chip ID: 10ec:8168
IF: enp3s0 state: up speed: 1000 Mbps duplex: full
mac: <filter>
Local Storage: total: 2.26 TiB used: 575.10 GiB (24.9%)
SMART Message: Unable to run smartctl. Root privileges
required.
ID-1: /dev/sda vendor: Kingston model: SA400S37480G
size: 447.13 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: K1B3 scheme: GPT
ID-2: /dev/sdb vendor: Toshiba model: HDWD120 size: 1.82 TiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: ACF0 scheme: GPT
ID-1: / raw size: 47.72 GiB size: 46.72 GiB (97.91%)
used: 19.68 GiB (42.1%) fs: ext4 dev: /dev/sda6
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Packages: 1357 pacman: 1341 lib: 366 flatpak: 11 snap: 5
1: https://uk.mirrors.fossho.st/manjaro/stable/$repo/$arch
2: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
3: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
4: https://manjaro.grena.ge/stable/$repo/$arch
5: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
6: https://us.mirrors.fossho.st/manjaro/stable/$repo/$arch
7: https://osmirror.org/manjaro/stable/$repo/$arch
8: https://mirror.dacentec.com/manjaro/stable/$repo/$arch
9: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
10: http://manjaro.dcc.uchile.cl/stable/$repo/$arch
11: http://linorg.usp.br/manjaro/stable/$repo/$arch
12: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
13: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
14: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
15: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
16: http://distro.ibiblio.org/manjaro/stable/$repo/$arch
17: http://mirror.inode.at/manjaro/stable/$repo/$arch
18: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
19: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
20: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
21: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
22: https://manjaro.lucassymons.net/stable/$repo/$arch
23: http://manjaro.telecoms.bg/stable/$repo/$arch
24: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
25: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
26: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
27: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
28: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
Processes: 308 Uptime: 4h 15m Memory: 15.50 GiB
used: 7.75 GiB (50.0%) Init: systemd v: 246 Compilers:
gcc: 10.2.0 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.06
