After updating to this version, any PDF I embed in a page using an object tag (unless set a very small width) has a horizontal scroll bar that appears to be only to show the Tools icon (>>) of the top menu, which is that last item on the right. And, when enlarge the PDF, although can see a darker area of the horizontal scroll bar shrink, when you hover on the bar it is still the original size just to reveal that Tools icon, which doesn’t appear to be within the shaded area of that menu; and you can’t scroll to see the document. It’s as if the scroll container is the menu plus the icon and the document enlarges (hidden) within a child container. (See, now, that if place mouse over document to give it the focus, then can arrow right/left to horizonal scroll and view the document.)
If I run the same progam on my laptop which has not yet been updated to this new version (still has 155.0.1-1), all works as expected. It also works fine in Brave; so, I suppose anything chrome based.
Could it be a setting or is it a problem with Firefox? Thank you.
Found this on bugs for version 158 2084084 - On the new UI, PDF files don't have the side to side scroll bar when you zoom in which seems to be the same issue but I don’t follow that last one that seems to read version 160 is affected and won’t fix.
