Fingerprint reader on my HP Laptop
My new project is trying to get my Fingerprint reader working on my HP Laptop.
Below are my system specs.
[demo@manjaro autostart]$ inxi --admin --verbosity=7 --filter --width
  Kernel: 6.0.7-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
    root=UUID=45ca132d-4a37-4dc3-afa0-be2e80d6a4a2 rw quiet pci=nocrs
    acpi=force "acpi_osi=Windows 2022" ibt=off
  Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.7 info: latte-dock
    wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
    v: N/A serial: <superuser required> Chassis: type: 31
  Mobo: HP model: 863F v: 54.24 serial: <superuser required> UEFI: AMI
    v: F.28 date: 07/14/2022
  ID-1: BAT0 charge: 40.4 Wh (58.0%) condition: 69.7/69.7 Wh (100.0%)
    volts: 11.0 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
    status: discharging cycles: 180
  Device-1: hid-0018:04F3:2992.0001-battery model: ELAN2514:00 04F3:2992
    serial: N/A charge: N/A status: N/A
  RAM: total: 15.26 GiB used: 4.82 GiB (31.6%)
  Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
    built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
    stepping: 0xC (12) microcode: 0xF0
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1925 high: 2300 min/max: 400/4900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2300 2: 800 3: 800 4: 2300
    5: 2300 6: 2300 7: 2300 8: 2300 bogomips: 36812
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
    md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
    pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
    rdseed rdtscp rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1
    xsaves xtopology xtpr
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
    ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9b41
    class-ID: 0300
  Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
    driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
    status: current (as of 2022-10) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 4 bus-ID: 3b:00.0
    chip-ID: 10de:1d13 class-ID: 0302
  Device-3: Chicony HP Wide Vision FHD Camera type: USB driver: uvcvideo
    bus-ID: 1-5:2 chip-ID: 04f2:b67b class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: modesetting,nvidia dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
    s-diag: 1165mm (45.88")
  Monitor-1: eDP-1 mapped: eDP-1-1 model: AU Optronics 0x30eb built: 2017
    res: 3840x2160 hz: 60 dpi: 284 gamma: 1.2 size: 344x193mm (13.54x7.6")
    diag: 394mm (15.5") ratio: 16:9 modes: 3840x2160
  API: OpenGL v: 4.6.0 NVIDIA 520.56.06 renderer: NVIDIA GeForce
    MX250/PCIe/SSE2 direct render: Yes
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
    driver: sof-audio-pci-intel-cnl
    alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
    chip-ID: 8086:02c8 class-ID: 0401
  Sound API: ALSA v: k6.0.7-2-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.59 running: yes
  Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
  Local Storage: total: 931.51 GiB used: 262.73 GiB (28.2%)
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    rev: 2B2QEXM7 temp: 40.9 C scheme: GPT
  ID-1: / raw-size: 239 GiB size: 234.94 GiB (98.30%) used: 43.72 GiB (18.6%)
    fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
    uuid: 45ca132d-4a37-4dc3-afa0-be2e80d6a4a2
    used: 68.8 MiB (71.6%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 6865-B8CE
  ID-3: /home raw-size: 415.57 GiB size: 407.98 GiB (98.17%)
    used: 218.95 GiB (53.7%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
    label: home uuid: 1f7a0eb8-f3e9-46ef-a88a-e3ae0ed0233d
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs label: Recovery
    uuid: 28C6655CC6652AF0
  ID-2: /dev/nvme0n1p11 maj-min: 259:9 size: 16 GiB fs: swap label: N/A
    uuid: 1b9cd8e2-756a-4a24-9641-d3cdd3bed29a
  ID-3: /dev/nvme0n1p12 maj-min: 259:10 size: 3 MiB fs: ufs label: N/A
    uuid: 6354a81a1b0b8929
  ID-4: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-5: /dev/nvme0n1p4 maj-min: 259:4 size: 219.37 GiB fs: ntfs label: N/A
    uuid: EAEA681CEA67E375
  ID-6: /dev/nvme0n1p5 maj-min: 259:5 size: 961 MiB fs: ntfs label: N/A
    uuid: 863E127D3E126709
  ID-7: /dev/nvme0n1p6 maj-min: 259:6 size: 40 GiB fs: ext4 label: rootMX21
    uuid: ae691757-a5f4-43d3-9580-0da970b5827f
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-5:2 info: Chicony HP Wide Vision FHD Camera type: Video
    driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
  Device-2: 1-9:3 info: Synaptics type: <vendor specific> driver: N/A
    interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00bb
    class-ID: ff00 serial: <filter>
  Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 53.0 C pch: 50.0 C mobo: N/A gpu: nvidia temp: 63 C
  Processes: 254 Uptime: 1h 49m wakeups: 846 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
  Packages: 1620 pm: pacman pkgs: 1614 libs: 425 tools: pamac,pikaur,yay
  pm: flatpak pkgs: 6 pm: snap pkgs: 0 Shell: Bash v: 5.1.16
  running-in: konsole inxi: 3.3.23
[demo@manjaro ~]$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 06cb:00bb Synaptics, Inc.
Bus 001 Device 002: ID 04f2:b67b Chicony Electronics Co., Ltd HP Wide Vision FHD Camera
[demo@manjaro ~]$ lspci
00:00.0 Host bridge: Intel Corporation Comet Lake-U v1 4c Host Bridge/DRAM Controller (rev 0c)
00:02.0 VGA compatible controller: Intel Corporation CometLake-U GT2 [UHD Graphics] (rev 02)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 0c)
00:12.0 Signal processing controller: Intel Corporation Comet Lake Thermal Subsytem
00:13.0 Serial controller: Intel Corporation Comet Lake Integrated Sensor Solution
00:14.0 USB controller: Intel Corporation Comet Lake PCH-LP USB 3.1 xHCI Host Controller
00:14.2 RAM memory: Intel Corporation Comet Lake PCH-LP Shared SRAM
00:14.3 Network controller: Intel Corporation Comet Lake PCH-LP CNVi WiFi
00:15.0 Serial bus controller: Intel Corporation Serial IO I2C Host Controller
00:15.1 Serial bus controller: Intel Corporation Comet Lake Serial IO I2C Host Controller
00:16.0 Communication controller: Intel Corporation Comet Lake Management Engine Interface
00:1c.0 PCI bridge: Intel Corporation Device 02ba (rev f0)
00:1c.4 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #5 (rev f0)
00:1d.0 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #9 (rev f0)
00:1d.4 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #13 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Comet Lake PCH-LP LPC Premium Controller/eSPI Controller
00:1f.3 Multimedia audio controller: Intel Corporation Comet Lake PCH-LP cAVS
00:1f.4 SMBus: Intel Corporation Comet Lake PCH-LP SMBus Host Controller
00:1f.5 Serial bus controller: Intel Corporation Comet Lake SPI (flash) Controller
01:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS525A PCI Express Card Reader (rev 01)
02:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 2C 2018] (rev 06)
03:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 2C 2018] (rev 06)
03:01.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 2C 2018] (rev 06)
03:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 2C 2018] (rev 06)
04:00.0 System peripheral: Intel Corporation JHL7540 Thunderbolt 3 NHI [Titan Ridge 2C 2018] (rev 06)
3a:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [Titan Ridge 2C 2018] (rev 06)
3b:00.0 3D controller: NVIDIA Corporation GP108M [GeForce MX250] (rev a1)
3c:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
Look here: Laptop/HP - ArchWiki
I see this:
https://wiki.archlinux.org/title/HP_Spectre_x360_15-df1010na
But I think I am a df-1033dx
Many fingerpriint readers are INTERNALly connected usb devices. On my HP Probook 520, the effective display command is:
$ lsusb
Bus 001 Device 004: ID 138a:003f Validity Sensors, Inc. VFS495 Fingerprint Reader <<<<<<
Bus 001 Device 003: ID 8087:0a2b Intel Corp. Bluetooth wireless interface
Bus 001 Device 002: ID 04ca:706d Lite-On Technology Corp. HP HD Camera
and more detailed info could be displayed with:
$ lsusb -v -d 138a:003f
Physically, the sensor is a roller bar, as contrasted to a flat surface, and does function under Microsoft
Unfortunately, the device us not detected by:
$ sudo fprintd-enroll -f right-ring-finger
Impossible to enroll: GDBus.Error:net.reactivated.Fprint.Error.NoSuchDevice: No devices available
So it seems linux/Ubuntu support is not yet available for this fingerprint reader
SIGH!
