FInger print scanner is not working
I’ve been trying to set up my fingerprint in my Manjaro Linux. I tried KDE plasmas fingerprint register tool. Each time I slide/put my finger on the scanner and lift it up I ran into issues before the registration process was completed. In the end, I somehow managed to register my fingerprint. But I haven’t seen my fingerprint being used anywhere for security. Is my hardware supported? Or is this a software issue??
  Kernel: 5.17.1-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
    root=UUID=fb08653b-525e-4768-90b2-4d0986419e80 rw quiet splash apparmor=1
    nouveau.modeset=0 security=apparmor
    resume=UUID=564940a7-1b64-4ba8-bd4a-cef4c3c3a4f3 udev.log_priority=3
    bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
    nvme_core.default_ps_max_latency_us=5500
  Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_wayland vt: 2
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X421IAY_M413IA
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X421IAY v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: X421IAY.305 date: 07/31/2020
  ID-1: BAT0 charge: 6.2 Wh (16.5%) condition: 37.6/42.1 Wh (89.3%)
    volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: discharging cycles: 166
  Info: model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP
    arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x8600106
  Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
    desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1426 high: 1630 min/max: 1400/2000 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1630 2: 1381
    3: 1348 4: 1498 5: 1397 6: 1397 7: 1385 8: 1379 bogomips: 31949
    STIBP: disabled, RSB filling
  Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
    bus-ID: 03:00.0 chip-ID: 1002:1636 class-ID: 0300
  Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 3-3:4 chip-ID: 13d3:56a8 class-ID: 0e02 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
    alternate: fbdev,vesa gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
  OpenGL: renderer: AMD RENOIR (DRM 3.44.0 5.17.1-3-MANJARO LLVM 13.0.1)
    v: 4.6 Mesa 21.3.8 direct render: Yes
  Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1
    chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
    bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.17.1-3-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.20 running: no
  Sound Server-4: PulseAudio v: 15.0 running: no
  Sound Server-5: PipeWire v: 0.3.49 running: yes
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-2:3
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 506.75 GiB used: 123.23 GiB (24.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
    lanes: 4 type: SSD serial: <filter> rev: 004C temp: 33.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 type: USB model: Multiple Card Reader
    size: 29.81 GiB block-size: physical: 512 B logical: 512 B type: N/A
    serial: <filter> rev: 1.00 scheme: MBR
  ID-1: / raw-size: 249.66 GiB size: 244.74 GiB (98.03%)
    used: 123.23 GiB (50.4%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-2: /boot/efi raw-size: 350 MiB size: 349.3 MiB (99.80%)
    used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
  ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6
  System Temperatures: cpu: 44.0 C mobo: N/A gpu: amdgpu temp: 42.0 C
  Fan Speeds (RPM): cpu: 2400
  Processes: 290 Uptime: 44m wakeups: 2198 Memory: 7.25 GiB
  used: 3.17 GiB (43.7%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.2.0 clang: 13.0.1 Packages: 1846 pacman: 1828 lib: 537 flatpak: 8
  snap: 10 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.15
lsusb output
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 005: ID 04f3:0903 Elan Microelectronics Corp. ELAN:Fingerprint
Bus 003 Device 004: ID 13d3:56a8 IMC Networks USB2.0 HD UVC WebCam
Bus 003 Device 003: ID 8087:0029 Intel Corp. AX200 Bluetooth
Bus 003 Device 002: ID 058f:6366 Alcor Micro Corp. Multi Flash Reader
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 04b8:118a Seiko Epson Corp. L3250 Series
I’ve modified the pam.d file. Since sddm shows no errors about enrollment I tried using gdm. It could connect with the fingerprint scanner but it fails to read the fingerprint.
I mean it enrolls fingerprints but fails to verify it.
