Hello~
I’ve been on a quest trying to get Manjaro to work on a laptop of mine, and all the issues presiding daily productivity have been addressed, so now it is time to play some games.
I installed Final Fantasy XIV from Steam, thinking proton would be the easiest way to run it (and that is where my copy is). However, I will hit play, and then it will try to launch and then nothing ever comes up; no launcher or anything. I know of the workaround that the new launcher doesn’t work on linux, so you need to adjust some settings in the .config file, however those files haven’t been generated yet (or I don’t know where they are, as the video is on Ubuntu,) as the launcher doesn’t even launch. I don’t really know what you need from me, so I started with a picture of my installed driver and what I know I have, as well as an inxi.
inxi -Fazy ✔
Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=98683eee-40c6-46b7-8a60-eb43f2b1749e rw quiet apparmor=1
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Micro-Star product: GE75 Raider 10SE v: REV:1.0
Mobo: Micro-Star model: MS-17E9 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E17E9IMS.10D date: 11/17/2020
ID-1: BAT1 charge: 49.2 Wh (100.0%) condition: 49.2/51.6 Wh (95.5%)
volts: 12.3 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: Full
Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: EA
cache: L1: 384 KiB L2: 1.5 MiB L3: 12 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 62431
Speed: 2383 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 2383 2: 4386
3: 2981 4: 2732 5: 3912 6: 1334 7: 3309 8: 1276 9: 1221 10: 2181 11: 3104
12: 3107
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Device-3: Acer HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:5
chip-ID: 5986:211c class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa display-ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 128 size: 381x214mm (15.0x8.4")
diag: 437mm (17.2")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.5
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9
class-ID: 0403
Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel port: 3000 bus-ID: 03:00.0
chip-ID: 1969:e0b1 class-ID: 0200
bus-ID: 1-14:6 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 1.38 TiB used: 181.21 GiB (12.9%)
model: PC SN730 SDBPNTY-512G-1032 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 11111000 temp: 50.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 60 GiB size: 58.76 GiB (97.93%) used: 20.77 GiB (35.3%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%)
used: 25.7 MiB (8.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 46.0 C pch: 42.0 C mobo: N/A
Processes: 320 Uptime: 7m wakeups: 1 Memory: 15.45 GiB
used: 2.84 GiB (18.4%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1311 lib: 380 flatpak: 0 Shell: Zsh v: 5.8
default: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.09
Let me know if you require anything else, I’m new to linux so I’m not too sure how to go about this, I’ve tried a few things like switching to the 470xx driver, trying different proton versions and such to no avail.
Thank you so much for the help!
