Filetransfer by bluetooth with failure
I’m using filetransfers via bluetooth for small data or when there’s no cable in reach. Normally between my XPS13 and my smartphone.
After a period of time i used the funktion again today - but resolving the following failure:
Bildschirmfoto vom 2024-02-27 14-46-01
This is my System:
  Kernel: 5.15.148-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=690d7158-803b-4b19-a9aa-5ba59a6200f5 rw apparmor=1
    security=apparmor resume=UUID=23307584-e8b5-48ac-b9cc-29b19c85459d
    udev.log_priority=3
    bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
  Desktop: Cinnamon v: 6.0.4 tk: GTK v: 3.24.41 wm: Muffin v: 6.0.1 tools:
    avail: cinnamon-screensaver dm: LightDM v: 1.32.0 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: Dell product: XPS 13 9360 v: N/A serial: <filter>
    Chassis: type: 9 serial: <filter>
  Mobo: Dell model: 05HM5Y v: A00 serial: <filter> part-nu: 075B
    uuid: 4c4c4544-0033-4710-804e-b7c04f354832 UEFI: Dell v: 1.3.5
    date: 05/08/2017
  ID-1: BAT0 charge: 16.8 Wh (33.7%) condition: 49.8/60.0 Wh (83.0%) volts: 7.4
    min: 7.6 model: SMP DELL TP1GT61 type: Li-poly serial: <filter>
    status: discharging
  System RAM: total: 8 GiB available: 7.65 GiB used: 1.78 GiB (23.3%)
    igpu: 32 MiB
  Array-1: capacity: 8 GiB slots: 2 modules: 2 EC: None
    max-module-size: 4 GiB note: est.
  Device-1: System Board Memory type: LPDDR3 detail: synchronous unbuffered
    (unregistered) size: 4 GiB speed: 1867 MT/s volts: curr: 1.2 min: 1.25
    max: 1.25 width (bits): data: 64 total: 64 manufacturer: Micron
    part-no: MT52L512M32D2PF-10 serial: N/A
  Device-2: System Board Memory type: LPDDR3 detail: synchronous unbuffered
  Info: model: Intel Core i5-7200U socket: U3E1 bits: 64 type: MT MCP
    arch: Amber/Kaby Lake note: check gen: core 7 level: v3 note: check
    built: 2017 process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
    microcode: 0xF4
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1495 high: 1987 min/max: 400/3100 base/boost: 2400/2500
    scaling: driver: intel_pstate governor: powersave volts: 0.8 V
    ext-clock: 100 MHz cores: 1: 1085 2: 1100 3: 1809 4: 1987 bogomips: 21607
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    vulnerable
    prctl and seccomp
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
    empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5916
    class-ID: 0300
  Device-2: Microdia Integrated Webcam HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0c45:670c
    class-ID: 0e02
  Display: server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
    s-diag: 485mm (19.11")
  Monitor-1: eDP-1 model: Sharp 0x1449 built: 2015 res: 1600x900 hz: 60
    dpi: 138 gamma: 1.2 size: 294x165mm (11.57x6.5") diag: 337mm (13.3")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71
    class-ID: 0403
  API: ALSA v: k5.15.148-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.3 status: n/a (root, process) tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active (root, process) with:
    tools: pacat,pactl,pavucontrol
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Rivet Networks Killer Wireless-n/a/ac 1535 driver: ath10k_pci
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 3a:00.0
    chip-ID: 168c:003e class-ID: 0280 temp: 41.0 C
  IF: wlp58s0 state: up mac: <filter>
  Info: services: NetworkManager,wpa_supplicant
  Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
    chip-ID: 0cf3:e300 class-ID: e001
  Local Storage: total: 465.76 GiB used: 135.57 GiB (29.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P2SSD8
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: P2CR010 temp: 31.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 24d 13h cycles: 991
    read-units: 3,890,802 [1.99 TB] written-units: 3,332,947 [1.70 TB]
  ID-1: / raw-size: 40.04 GiB size: 39.11 GiB (97.69%) used: 27.14 GiB (69.4%)
    fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: 690d7158-803b-4b19-a9aa-5ba59a6200f5
  ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
    used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: F3F0-FFB7
  ID-3: /home raw-size: 416.83 GiB size: 409.22 GiB (98.17%)
    used: 108.43 GiB (26.5%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p4
    maj-min: 259:4 label: N/A uuid: aa773560-dfda-4223-a404-bd1075e58946
  ID-1: swap-1 type: partition size: 8.4 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 23307584-e8b5-48ac-b9cc-29b19c85459d
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-3:2 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Device-2: 1-5:3 info: Microdia Integrated Webcam HD type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 0c45:670c class-ID: 0e02
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 45.0 C pch: 38.5 C mobo: 37.0 C sodimm: SODIMM C
  Fan Speeds (rpm): cpu: 0
  Processes: 217 Power: uptime: 31m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
    test_resume image: 3.05 GiB services: csd-power,upowerd Init: systemd
    v: 255 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1582 libs: 481 tools: pamac,yay pm: flatpak
    pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Sudo (sudo) v: 1.9.15p5
    default: Bash v: 5.2.26 running-in: gnome-terminal inxi: 3.3.33
My system is uptodate, in the update-history i found those two recent changes:
[2024-02-22T10:19:46+0100] [ALPM] upgraded blueman (2.3.5-2 → 2.3.5-3)
[2024-02-22T10:20:22+0100] [ALPM] upgraded pulseaudio-bluetooth (16.1-7 → 17.0-3)
Further i found some older entrys in “journalctl”:
Jan 05 00:17:39 tempograd-xps139360 systemd[1]: Starting Bluetooth service...
Jan 05 00:17:39 tempograd-xps139360 (uetoothd)[1109]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 5>
Jan 05 00:17:39 tempograd-xps139360 kernel: Bluetooth: hci0: using NVM file: qca/nvm_usb_00000302.bin
Jan 05 00:17:39 tempograd-xps139360 bluetoothd[1109]: Bluetooth daemon 5.71
Jan 05 00:17:39 tempograd-xps139360 systemd[1]: Started Bluetooth service.
Jan 05 00:17:39 tempograd-xps139360 systemd[1]: Reached target Bluetooth Support.
Jan 05 00:17:39 tempograd-xps139360 bluetoothd[1109]: Starting SDP server
Jan 05 00:17:39 tempograd-xps139360 bluetoothd[1109]: src/plugin.c:plugin_init() System does not support csip plugin
Jan 05 00:17:39 tempograd-xps139360 bluetoothd[1109]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Jan 05 00:17:39 tempograd-xps139360 bluetoothd[1109]: src/plugin.c:plugin_init() System does not support micp plugin
Jan 05 00:17:39 tempograd-xps139360 bluetoothd[1109]: src/plugin.c:plugin_init() System does not support vcp plugin
Jan 05 00:17:39 tempograd-xps139360 bluetoothd[1109]: src/plugin.c:plugin_init() System does not support mcp plugin
Jan 05 00:17:39 tempograd-xps139360 bluetoothd[1109]: src/plugin.c:plugin_init() System does not support bass plugin
Jan 05 00:17:39 tempograd-xps139360 bluetoothd[1109]: src/plugin.c:plugin_init() System does not support bap plugin
Jan 05 00:17:39 tempograd-xps139360 kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Jan 05 00:17:39 tempograd-xps139360 kernel: Bluetooth: BNEP filters: protocol multicast
Jan 05 00:17:39 tempograd-xps139360 kernel: Bluetooth: BNEP socket layer initialized
Jan 05 00:17:39 tempograd-xps139360 bluetoothd[1109]: Bluetooth management interface 1.14 initialized
Jan 05 00:17:39 tempograd-xps139360 wpa_supplicant[1055]: wlp58s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Jan 05 00:17:39 tempograd-xps139360 bluetoothd[1109]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Unknown Command (0x01)
Jan 05 00:17:39 tempograd-xps139360 bluetoothd[1109]: Battery Provider Manager created
The system on my smartphone is Android 11.
File exchange works for the last three years since i’m using manjaro on my notebook.
All other bluetooth connections work, such as audiostreaming, also my headphones, etc.
Are there any known issues with bluetooth with the last updates?
Btw. i use the older Kernel 5.15 cause on the old XPS it works more smoothly.
Did you try and re-pair the devices?
Yes, i did. No changes the filetransfer does not start and shows upnamed failure.
I think it has a similar reasons to that:
Link
or maybe;
Link
Here is my bluetooth status:
systemctl status bluetooth
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset>
     Active: active (running) since Tue 2024-02-27 15:08:58 CET; 2h 1min ago
       Docs: man:bluetoothd(8)
   Main PID: 1008 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 9372)
     Memory: 2.9M ()
        CPU: 955ms
     CGroup: /system.slice/bluetooth.service
             └─1008 /usr/lib/bluetooth/bluetoothd
Feb 27 15:09:00 tempograd-xps139360 bluetoothd[1008]: Endpoint registered: send>
Feb 27 15:09:46 tempograd-xps139360 bluetoothd[1008]: profiles/audio/avdtp.c:av>
Feb 27 15:11:01 tempograd-xps139360 bluetoothd[1008]: profiles/audio/transport.>
Feb 27 15:45:57 tempograd-xps139360 bluetoothd[1008]: /org/bluez/hci0/dev_4C_87>
Feb 27 15:50:07 tempograd-xps139360 bluetoothd[1008]: src/profile.c:ext_io_disc>
Feb 27 16:55:10 tempograd-xps139360 bluetoothd[1008]: profiles/audio/avdtp.c:av>
Feb 27 16:56:10 tempograd-xps139360 bluetoothd[1008]: profiles/audio/transport.>
lines 1-22/22 (END)...skipping...
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
     Status: "Running"
     Memory: 2.9M ()
        CPU: 955ms
Feb 27 15:09:00 tempograd-xps139360 bluetoothd[1008]: Endpoint registered: sender=:1.50 path=/MediaEndpoint/A2DPSink/sbc_xq_552
Feb 27 15:09:00 tempograd-xps139360 bluetoothd[1008]: Endpoint registered: sender=:1.50 path=/MediaEndpoint/A2DPSource/sbc_xq_552
Feb 27 15:09:00 tempograd-xps139360 bluetoothd[1008]: Endpoint registered: sender=:1.50 path=/MediaEndpoint/A2DPSink/faststream
Feb 27 15:09:00 tempograd-xps139360 bluetoothd[1008]: Endpoint registered: sender=:1.50 path=/MediaEndpoint/A2DPSource/faststream
Feb 27 15:09:46 tempograd-xps139360 bluetoothd[1008]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 9C:6B:72:7A:FA:9A: Host is down (112)
Feb 27 15:11:01 tempograd-xps139360 bluetoothd[1008]: profiles/audio/transport.c:set_volume() Unable to set volume: Transport endpoint is not connected (-107)
Feb 27 15:45:57 tempograd-xps139360 bluetoothd[1008]: /org/bluez/hci0/dev_4C_87_5D_57_B6_21/sep1/fd1: fd(37) ready
Feb 27 15:50:07 tempograd-xps139360 bluetoothd[1008]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
Feb 27 16:55:10 tempograd-xps139360 bluetoothd[1008]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 9C:6B:72:7A:FA:9A: Host is down (112)
Feb 27 16:56:10 tempograd-xps139360 bluetoothd[1008]: profiles/audio/transport.c:set_volume() Unable to set volume: Transport endpoint is not connected (-107)
This is an old Installation of Manjaro, maybe like in the first link to delete blueman and bluez and reinstall it could solve the problem. I will try and report.
After reinstallation of blueman and bluez the problem still exits. Any suggestions?
Terminal shows:
$ blueman-sendto
blueman-sendto 22.36.44 ERROR    Client:26 on_session_failed: 9C:6B:72:7A:F9:DA 9C:B6:D0:E3:47:28 opp  The name is not activatable
Solved the problem by installing “bluez-obex”. Don´t know why it got deinstalled, or not installed the new version with the update of bluez 5.72-2.
