Filelight pie chart no longer shown
It’s been some months since I last used filelight, so I cannot exactly say which update caused this problem.
Filelight no longer shows the pie chart. Just an empty space in the window.
journalctl shows an error message when filelight is started:
qrc:/ui/OverviewPage.qml:11:1: QML OverviewPage: Created graphical object was not placed in the graphics scene.
It seems to be Wayland-related. When I log in with an X session then everything’s fine. Does anyone have the same problem?
Plasma 6.3.4 + Nvidia proprietary driver + Wayland
$ inxi -G
  Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] driver: nvidia
    v: 570.133.07
    compositor: kwin_wayland driver: X: loaded: nvidia
    gpu: nvidia,nvidia-nvswitch resolution: 2560x1440~120Hz
  API: EGL v: 1.5 drivers: nouveau,nvidia,swrast
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.133.07
    renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
  API: Vulkan v: 1.4.309 drivers: nvidia surfaces: xcb,xlib,wayland
It works fine here in Wayland. However, I don’t have an invidious Nvidia GPU. :stuck_out_tongue:
I see the bug is reported:
https://bugs.kde.org/show_bug.cgi?id=502709
I removed my previous edit, as for some reason when I reboot the nvidia driver wasn’t apparently loaded correctly and that’s why filelight seemed work correctly. I did a full shutdown, then booted up and now the driver is correctly detected, but filelight doesn’t show the pie chart.
A quick glance at the bug report linked - it appears to be a Nvidia related issue.
Tested on all AMD - no issues.
Thanks to the user pallaswept, a workaround we can use in the meantime until it’s fixed is to change the environment variable for filelight: QT_QPA_PLATFORM=xcb filelight
What I did: I entered QT_QPA_PLATFORM=xcb into the Environment variables: section for Filelight using KDE Menu Editor.
