Long story short, the filechooser window doesn’t show up when I click on something that calls it. No browser uploads, no Ctrl+O in Okular to open a document.
I digged and found this:
When no filechooser is called, the “xdg-desktop-portal-gnome” service is running fine (checked using systemctl --user status [ServiceName] )
But when I call a filechooser, that service dies with this error:
Settings schema 'org.gtk.gtk4.Settings.FileChooser' does not contain a key named 'view-type'
What should I do?
Update: I’m on gnome 45.3 with the 6.1 Manjaro Kernel and have not messed with gtk4 stuff in any way
That didn’t work… I had already tried that
here’s the service’s status before calling a filechooser:
> systemctl --user status xdg-desktop-portal-gnome
xdg-desktop-portal-gnome.service - Portal service (GNOME implementation)
Loaded: loaded (/usr/lib/systemd/user/xdg-desktop-portal-gnome.service; static)
Active: active (running) since Thu 2024-01-18 09:21:19;
Main PID: 6144 (xdg-desktop-por)
Tasks: 5 (limit: 9347)
Memory: 23.3M (peak: 23.8M)
CPU: 863ms
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/xdg-desktop-portal-gnome.service
└─6144 /usr/lib/xdg-desktop-portal-gnome
Jan 18 09:21:18 [myname] systemd[1092]: Starting Portal service (GNOME implementation)...
Jan 18 09:21:19 [myname] xdg-desktop-por[6144]: Theme parser error: gtk.css:4603:21-28: Expected a valid color.
Jan 18 09:21:19 [myname] xdg-desktop-por[6144]: Theme parser error: gtk.css:4682:21-28: Expected a valid color.
Jan 18 09:21:19 [myname] xdg-desktop-por[6144]: Theme parser error: gtk.css:4812:21-28: Expected a valid color.
Jan 18 09:21:19 amirslaptop systemd[1092]: Started Portal service (GNOME implementation).
and here’s after calling a filechooser window (same thing all over the system):
Active: failed (Result: core-dump) since Thu 2024-01-18 09:27:29;
Duration: 6min 10.558s
Process: 6144 ExecStart=/usr/lib/xdg-desktop-portal-gnome (code=dumped, signal=TRAP)
Main PID: 6144 (code=dumped, signal=TRAP)
CPU: 1.212s
Jan 18 09:21:18 [myusernamehere] systemd[1092]: Starting Portal service (GNOME implementation)...
Jan 18 09:21:19 [myusernamehere] xdg-desktop-por[6144]: Theme parser error: gtk.css:4603:21-28: Expected a valid color.
Jan 18 09:21:19 [myusernamehere] xdg-desktop-por[6144]: Theme parser error: gtk.css:4682:21-28: Expected a valid color.
Jan 18 09:21:19 [myusernamehere] xdg-desktop-por[6144]: Theme parser error: gtk.css:4812:21-28: Expected a valid color.
Jan 18 09:21:19 [myusernamehere] systemd[1092]: Started Portal service (GNOME implementation).
Jan 18 09:27:25 [myusernamehere] xdg-desktop-por[6144]: Settings schema 'org.gtk.gtk4.Settings.FileChooser' does not contain a key named 'view-type'
Jan 18 09:27:29 [myusernamehere] systemd-coredump[11866]: Process 6144 (xdg-desktop-por) of user 1000 dumped core.
Stack trace of thread [threadnumber]:
[Deleted]
Jan 18 09:27:29 [myusernamehere] systemd[1092]: xdg-desktop-portal-gnome.service: Main process exited, code=dumped, status=5/TRAP
Jan 18 09:27:29 [myusernamehere] systemd[1092]: xdg-desktop-portal-gnome.service: Failed with result 'core-dump'.
Jan 18 09:27:29 [myusernamehere] systemd[1092]: xdg-desktop-portal-gnome.service: Consumed 1.212s CPU time, 23.8M memory peak.
Question: Is it a good idea to add the key myself and recompile the schemas? I assume not because it’ll be broken after the next gtk4 update
Question-2: Is there a way to reset the schemas in a way? or find the “Default” schema and replace the filechooser schema with what it was supposed to be?
UPDATE: It works with VS Code but doesn’t work with basically anything else that I have tried. I Think VS Code uses another filechooser service call (I know xdg-desktop-portal-gtk is on here too because it’s required by xdg-desktop-portal-gnome).
