Hello everyone,
Since the last update on May 30th, I no longer see any Samba shares in the file browser (Nemo).
Previously I could always see “Manjaro network” or “-Printer”, unfortunately I can’t remember exactly. My RaspberryPi is also no longer displayed.
Network is now simply empty.
nemo-share
, manjaro-settings-samba
and samba
are installed.
Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=d4cadd54-c5b2-430c-8d01-8255a883e094 rw quiet
resume=UUID=c17035ff-5fe1-42ff-967b-bd90b2acb0b4 udev.log_priority=3
Desktop: Cinnamon v: 6.0.4 tk: GTK v: 3.24.42 wm: Muffin v: 6.0.1 tools:
avail: cinnamon-screensaver vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro
base: Arch Linux
Type: Desktop Mobo: MSI model: Z170A GAMING M3 (MS-7978) v: 2.0
serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends v: A.D0 date: 07/04/2018
System RAM: total: 32 GiB available: 31.31 GiB used: 3.28 GiB (10.5%)
Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
speed: 2133 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: Kingston part-no: 9905625-062.A00G serial: <filter>
Device-2: ChannelA-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
Device-4: ChannelB-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x5E (94) stepping: 3 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4200 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 64026
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: gather_data_sampling status: Vulnerable: No microcode
vulnerable
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Micro-Star MSI
driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:13c2
class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.87x11.85")
s-diag: 610mm (24")
Monitor-1: Unknown-1 mapped: DVI-D-0 res: 1920x1080 hz: 60 dpi: 92
size: 531x298mm (20.91x11.73") modes: 1024x768
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fbb
class-ID: 0403
API: ALSA v: k6.6.32-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Qualcomm Atheros Killer E2400 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 07:00.0 chip-ID: 1969:e0a1 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager, smbd, systemd-timesyncd
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 0bda:2550
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 3.64 TiB used: 973.12 GiB (26.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 2TB
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH10LS30 rev: 1.02
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 39.06 GiB size: 38.15 GiB (97.67%) used: 12.84 GiB (33.6%)
fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: d4cadd54-c5b2-430c-8d01-8255a883e094
used: 300 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: C133-24D7
ID-3: /home raw-size: 1.78 TiB size: 1.75 TiB (98.37%)
used: 960.28 GiB (53.6%) fs: ext4 dev: /dev/sdb4 maj-min: 8:20 label: N/A
uuid: c1353faa-c068-436a-a8bb-c5d80db2999b
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: c17035ff-5fe1-42ff-967b-bd90b2acb0b4
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: 4623-FC5A
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 1.82 TiB fs: ntfs label: snydar
uuid: 01DA9218B14EE8E0
ID-4: /dev/sda4 maj-min: 8:4 size: 1.96 GiB fs: ntfs label: N/A
uuid: 01DA9218B182A310
Device-1: 1-2:2 info: Personal Communication Systems Dual PSX Adaptor
type: HID driver: pantherlord,usbhid interfaces: 1 rev: 1.0
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 500mA
chip-ID: 0810:0001 class-ID: 0300
Device-2: 1-6:3 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0bda:2550 class-ID: e001 serial: <filter>
Device-3: 1-7:4 info: Alcor Micro AU6477 Card Reader Controller
type: mass storage,HID driver: hid-generic,usb-storage,usbhid interfaces: 2
rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 250mA
chip-ID: 058f:6364 class-ID: 0300 serial: <filter>
Device-4: 1-11:5 info: Dell KB212-B Quiet Key Keyboard type: keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 413c:2107 class-ID: 0301
Device-5: 1-12:6 info: Logitech M-BT85 [UltraX Optical Mouse] type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 98mA chip-ID: 046d:c03f class-ID: 0301
Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
System Temperatures: cpu: 26.0 C pch: 39.5 C mobo: N/A gpu: nvidia temp: 53 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Processes: 253 Power: uptime: 10h 37m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.51 GiB services: csd-power,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1446 libs: 424 tools: pamac pm: flatpak pkgs: 0
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Bash v: 5.2.26
running-in: gnome-terminal inxi: 3.3.34
Here is the samba.conf
[global]
workgroup = WORKGROUP
dns proxy = no
log file = /var/log/samba/%m.log
max log size = 1000
client min protocol = SMB2
server role = standalone server
passdb backend = tdbsam
obey pam restrictions = yes
unix password sync = yes
passwd program = /usr/bin/passwd %u
passwd chat = *New*UNIX*password* %n\n *ReType*new*UNIX*password* %n\n *passwd:*all*authentication*tokens*updated*successfully*
pam password change = yes
map to guest = Bad Password
usershare allow guests = yes
name resolve order = lmhosts bcast host wins
security = user
guest account = nobody
usershare path = /var/lib/samba/usershare
usershare max shares = 100
usershare owner only = yes
force create mode = 0070
force directory mode = 0070
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
show add printer wizard = no
[homes]
comment = Home Directories
browseable = no
read only = yes
create mask = 0700
directory mask = 0700
valid users = %S
[printers]
comment = All Printers
browseable = no
path = /var/spool/samba
printable = yes
guest ok = no
read only = yes
create mask = 0700
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
browseable = yes
read only = yes
guest ok = no
With
smb://BATOCERA.local/share
an error message appears:
“smb://batocera.local/share” could not be displayed.
Error: Mount of Windows share failed: The argument is invalid.
Please select another viewer and try again.
With
smb://192.168.2.102/share
I can access the RaspberryPi without any problems.
Greetings
snydar
