File System turns read only and all open applications crash after wake up.
Software :- stable update(2021-11-19) with Gnome41.1
Hardware:-
Name : Mi NoteBook Ultra
Vendor : TIMI
-BIOS-
Date : 07/14/2021
Vendor : TIMI
Version : RMATG5B0P0D0D
-Board-
Vendor : TIMI
Version : V1.0
journalctl -p3 -b-1 output
Journal begins at Tue 2021-11-16 14:15:08 IST, ends at Tue 2021-11-23 20:47:13 IST. --
Nov 23 19:00:44 mnu-2021 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.RP09._S0W], AE_ALREADY_EXISTS (20210331/dswload2-326)
Nov 23 19:00:44 mnu-2021 kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210331/psobject-220)
Nov 23 19:00:44 mnu-2021 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.I2C0.TPD0], AE_NOT_FOUND (20210331/dswload2-162)
Nov 23 19:00:44 mnu-2021 kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210331/psobject-220)
Nov 23 19:00:44 mnu-2021 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.I2C0.TPL1], AE_NOT_FOUND (20210331/dswload2-162)
Nov 23 19:00:44 mnu-2021 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.I2C1.TPL1], AE_NOT_FOUND (20210331/dswload2-162)
Nov 23 19:00:44 mnu-2021 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.I2C2.TPL1], AE_NOT_FOUND (20210331/dswload2-162)
Nov 23 19:00:44 mnu-2021 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.DGPV], AE_NOT_FOUND (20210331/psargs-330)
Nov 23 19:00:44 mnu-2021 kernel: ACPI Error: Aborting method \_SB.PC00.RP05.PCRP._ON due to previous error (AE_NOT_FOUND) (20210331/psparse-529)
Nov 23 19:00:44 mnu-2021 kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
Nov 23 19:00:45 mnu-2021 kernel: ucsi_acpi USBC000:00: PPM init failed (-5)
Nov 23 19:00:45 mnu-2021 kernel: intel-spi 0000:00:1f.5: unrecognized JEDEC id bytes: c2 75 18 c2 75 18
Nov 23 19:00:46 mnu-2021 wpa_supplicant[741]: nl80211: kernel reports: Attribute failed policy validation
Nov 23 19:00:46 mnu-2021 wpa_supplicant[741]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Nov 23 19:00:46 mnu-2021 wpa_supplicant[741]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Nov 23 19:00:54 mnu-2021 gdm-password][1105]: gkr-pam: unable to locate daemon control file
Nov 23 19:00:56 mnu-2021 gdm-launch-environment][759]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
smartctl -i /dev/nvme0
=== START OF INFORMATION SECTION ===
Firmware Version: YM00D212
PCI Vendor/Subsystem ID: 0x1e49
IEEE OUI Identifier: 0xa428b7
Total NVM Capacity: 512,110,190,592 [512 GB]
Unallocated NVM Capacity: 0
Controller ID: 1
NVMe Version: 1.3
Number of Namespaces: 1
Namespace 1 Size/Capacity: 512,110,190,592 [512 GB]
Namespace 1 Utilization: 311,433,924,608 [311 GB]
Namespace 1 Formatted LBA Size: 512
Namespace 1 IEEE EUI-64: a428b7 2a30e90049
Local Time is: Tue Nov 23 21:00:49 2021 IST
smartctl -l error /dev/nvme0
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.13.19-2-MANJARO] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF SMART DATA SECTION ===
Error Information (NVMe Log 0x01, 16 of 256 entries)
No Errors Logged
tlp-stat -s
--- TLP 1.4.0 --------------------------------------------
+++ System Info
System = TIMI Mi NoteBook Ultra
BIOS = RMATG5B0P0D0D
OS Release = Manjaro Linux
Kernel = 5.13.19-2-MANJARO #1 SMP PREEMPT Sun Sep 19 21:31:53 UTC 2021 x86_64
/proc/cmdline = BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=2a52f4c3-5ad0-4ce9-add9-3d0e27f428ee rw quiet cryptdevice=UUID=57c9754d-b02b-4720-9bdf-72330e0d47bc:luks-57c9754d-b02b-4720-9bdf-72330e0d47bc root=/dev/mapper/luks-57c9754d-b02b-4720-9bdf-72330e0d47bc splash apparmor=1 security=apparmor udev.log_priority=3
Init system = systemd
Boot mode = UEFI
+++ TLP Status
State = enabled
RDW state = not installed
Last run = 08:55:24 PM IST, 591 sec(s) ago
Mode = battery
Power source = battery
Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
>>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
>>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Does this mean I have a conflict between gnome power-profiles and TLP?
Or this?
Any help to resolve this issue is appreciated.
