File system errors
help, I get a lot of errors and I don’t know why.
lately firefox closes a lot when i try to open some pages.
.xsession-errors
/bin/sh: line 1: start-pulseaudio-x11: command not found
/bin/sh: line 1: pa-applet: command not found
/bin/sh: line 1: ff-theme-util: command not found
(nitrogen:1019): Gtk-WARNING **: 06:31:41.638: Unable to locate theme engine in module_path: "murrine",
(nitrogen:1019): Gtk-WARNING **: 06:31:41.664: Unable to locate theme engine in module_path: "murrine",
(nitrogen:1019): Gtk-WARNING **: 06:31:41.679: Unable to locate theme engine in module_path: "murrine",
conky: desktop window (0x48e) is root window
conky: window type - override
conky: drawing to created window (0x1200001)
conky: drawing to double buffer
conky: forked to background, pid is 1076
i3status: trying to auto-detect output_format setting
i3status: auto-detected "i3bar"
conky: FOUND: console
conky: FOUND: ncurses
conky: FOUND: file
conky: FOUND: x11
conky: FOUND: wayland
(polkit-gnome-authentication-agent-1:1014): Gtk-WARNING **: 06:31:41.971: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(clipit:1020): Gtk-WARNING **: 06:31:42.062: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
conky: 'i3' x11 session running 'i3' desktop
(xfce4-power-manager:1017): Gtk-WARNING **: 06:31:42.209: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
conky: drawing to created window (0x1c00001)
conky: forked to background, pid is 1084
conky: FOUND: file
conky: FOUND: x11
(pamac-tray:1018): Gtk-WARNING **: 06:31:42.344: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(nitrogen:1019): Gtk-WARNING **: 06:31:42.347: Unable to locate theme engine in module_path: "murrine",
(nitrogen:1019): Gtk-WARNING **: 06:31:42.348: Unable to locate theme engine in module_path: "murrine",
(nitrogen:1019): Gtk-WARNING **: 06:31:42.361: Unable to locate theme engine in module_path: "murrine",
(nm-applet:1016): Gtk-WARNING **: 06:31:42.421: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(nitrogen:1019): GLib-GObject-CRITICAL **: 06:31:42.424: Attempting to freeze the notification queue for object GtkSettings[0x55a88c868160]; Property notification does not work during instance finalization.
(nitrogen:1019): GLib-GObject-CRITICAL **: 06:31:42.424: Attempting to thaw the notification queue for object GtkSettings[0x55a88c868160]; Property notification does not work during instance finalization.
(xfce4-power-manager:1017): xfce4-power-manager-WARNING **: 06:31:43.108: Unable to connect to session manager : Failed to connect to the session manager: SESSION_MANAGER environment variable not defined
[ 07/08/2024 06:31:43.626 parse_config_libconfig WARN ] The refresh-rate option has been deprecated. Please remove it from your configuration file. If you encounter any problems without this feature, please feel free to open a bug report
(pamac-tray:1018): Gdk-CRITICAL **: 06:31:45.057: gdk_window_thaw_toplevel_updates: assertion 'window->update_and_descendants_freeze_count > 0' failed
** Message: 06:32:14.613: updates_checker.vala:70: check updates
** Message: 06:32:16.035: updates_checker.vala:100: 0 updates found
[1297, Main Thread] WARNING: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not(): 'glib warning', file /usr/src/debug/firefox/firefox-127.0.1/toolkit/xre/nsSigHandlers.cpp:187
(firefox:1297): Gtk-WARNING **: 06:33:18.063: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
[Parent 1297, Main Thread] WARNING: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not(): 'glib warning', file /usr/src/debug/firefox/firefox-127.0.1/toolkit/xre/nsSigHandlers.cpp:187
(firefox:1297): Gtk-WARNING **: 06:33:19.221: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(firefox:1297): Gtk-WARNING **: 06:33:19.884: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(firefox:1297): Gtk-WARNING **: 06:33:20.259: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(firefox:1297): Gtk-WARNING **: 06:33:22.734: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(firefox:1297): Gtk-WARNING **: 06:33:23.391: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(firefox:1297): Gtk-WARNING **: 06:33:23.781: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(firefox:1297): Gtk-WARNING **: 06:33:31.147: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(firefox:1297): Gtk-WARNING **: 06:33:31.849: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(firefox:1297): Gtk-WARNING **: 06:33:32.254: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(discord:1773): Gtk-WARNING **: 06:35:48.066: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
[1773:0708/063548.507121:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.DBus.Properties.Get: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.InvalidArgs: No such interface β€œorg.freedesktop.portal.FileChooser”
[1773:0708/063548.507230:ERROR:select_file_dialog_linux_portal.cc(286)] Failed to read portal version property
[1834:0708/063549.605506:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.610188:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.610853:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.611171:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.611755:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.612051:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.612420:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.612705:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.613177:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.613454:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.616938:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.617243:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.617613:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.617836:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.618126:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.618479:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.618876:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.619117:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.619443:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.624122:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.624659:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.624934:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.625280:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.625496:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.625825:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.626043:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.626364:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.630228:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.630671:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.630989:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.631369:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.631588:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.631915:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.632186:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.633310:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.633644:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.633997:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.634267:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.634597:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.634815:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.635148:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.635362:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.635711:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.635941:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.636228:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.637386:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.637962:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.639279:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.639708:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.641973:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.642466:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.642676:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.643008:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.643329:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.643665:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.644617:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.646895:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.647202:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.647522:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.647714:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.648004:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.648186:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.648493:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.649998:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.653036:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.654317:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.655165:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.658578:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.659025:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.659257:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.659609:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.663439:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.664426:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.664710:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.665048:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.665248:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.665554:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.665733:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
[1834:0708/063549.666019:ERROR:gbm_wrapper.cc(72)] Failed to get fd for plane.: No such file or directory (2)
[1834:0708/063549.666227:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)
(volumeicon:2916): Gtk-WARNING **: 06:55:41.432: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
ExceptionHandler::WaitForContinueSignal waiting for continue signal...
ExceptionHandler::GenerateDump cloned child 4346
ExceptionHandler::SendContinueSignalToChild sent continue signal to child
Exiting due to channel error.
(crashreporter:4347): Gtk-WARNING **: 07:10:55.344: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(chromium:4377): Gtk-WARNING **: 07:11:20.934: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
[4377:4410:0708/071121.434777:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.DBus.Properties.Get: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.InvalidArgs: No such interface β€œorg.freedesktop.portal.FileChooser”
[4377:4410:0708/071121.434879:ERROR:select_file_dialog_linux_portal.cc(287)] Failed to read portal version property
[4424:4424:0708/071122.480327:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.481797:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.482591:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.483286:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.483736:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.483981:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.484259:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.484465:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.484816:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.485081:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.485430:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.485621:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.485898:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.486091:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.486474:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.486708:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.487001:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.487213:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.487529:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.487755:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.488045:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.488210:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.488564:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.488774:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.489048:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.489204:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.489510:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.489799:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.490137:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.490309:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.490625:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.490797:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.491068:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.491295:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.491588:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.491800:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.492103:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.492291:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.492582:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.492762:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.493159:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.493334:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.493860:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.494086:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.494395:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.494559:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.494858:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.495024:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.495324:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.495506:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.495800:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.495962:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.496333:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.496581:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.496894:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.497079:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.497456:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.497649:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.497941:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.498115:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.498389:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.498582:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.498868:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.499037:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.499315:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.499691:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.500073:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.500310:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.500645:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.500828:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.501102:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.501262:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.501523:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.501681:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.501966:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.502137:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.502409:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.502582:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4424:4424:0708/071122.502836:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
[4424:4424:0708/071122.503273:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
[4636, Main Thread] WARNING: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not(): 'glib warning', file /usr/src/debug/firefox/firefox-127.0.1/toolkit/xre/nsSigHandlers.cpp:187
(firefox:4636): Gtk-WARNING **: 07:11:52.278: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
[Parent 4636, Main Thread] WARNING: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not(): 'glib warning', file /usr/src/debug/firefox/firefox-127.0.1/toolkit/xre/nsSigHandlers.cpp:187
(firefox:4636): Gtk-WARNING **: 07:11:53.473: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(firefox:4636): Gtk-WARNING **: 07:11:54.192: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(firefox:4636): Gtk-WARNING **: 07:11:54.588: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(firefox:4636): Gtk-WARNING **: 07:11:56.967: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(firefox:4636): Gtk-WARNING **: 07:11:57.644: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(firefox:4636): Gtk-WARNING **: 07:11:58.061: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(firefox:4636): Gtk-WARNING **: 07:12:05.930: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(firefox:4636): Gtk-WARNING **: 07:12:06.718: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(firefox:4636): Gtk-WARNING **: 07:12:07.164: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
ExceptionHandler::GenerateDump cloned child 4994
(crashreporter:4995): Gtk-WARNING **: 07:15:57.289: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
** Message: 07:31:44.698: updates_checker.vala:70: check updates
** Message: 07:31:47.444: updates_checker.vala:100: 0 updates found
[7917, Main Thread] WARNING: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not(): 'glib warning', file /usr/src/debug/firefox/firefox-127.0.1/toolkit/xre/nsSigHandlers.cpp:187
(firefox:7917): Gtk-WARNING **: 07:39:31.544: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
[9851, Main Thread] WARNING: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not(): 'glib warning', file /usr/src/debug/firefox/firefox-127.0.1/toolkit/xre/nsSigHandlers.cpp:187
(firefox:9851): Gtk-WARNING **: 08:15:46.706: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(pcmanfm:10501): Gtk-WARNING **: 08:17:17.117: Unable to locate theme engine in module_path: "murrine",
(pcmanfm:10501): Gtk-WARNING **: 08:17:17.118: Unable to locate theme engine in module_path: "murrine",
(pcmanfm:10501): Gtk-WARNING **: 08:17:17.125: Unable to locate theme engine in module_path: "murrine",
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.364: GFileInfo created without standard::edit-name
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.364: file ../glib/gio/gfileinfo.c: line 1742 (g_file_info_get_edit_name): should not be reached
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.364: GFileInfo created without standard::size
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.364: file ../glib/gio/gfileinfo.c: line 1845 (g_file_info_get_size): should not be reached
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.364: GFileInfo created without standard::is-symlink
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.364: file ../glib/gio/gfileinfo.c: line 1676 (g_file_info_get_is_symlink): should not be reached
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.364: GFileInfo created without standard::is-hidden
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.364: file ../glib/gio/gfileinfo.c: line 1632 (g_file_info_get_is_hidden): should not be reached
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.364: GFileInfo created without standard::is-backup
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.364: file ../glib/gio/gfileinfo.c: line 1654 (g_file_info_get_is_backup): should not be reached
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.365: GFileInfo created without standard::edit-name
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.378: file ../glib/gio/gfileinfo.c: line 1742 (g_file_info_get_edit_name): should not be reached
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.378: GFileInfo created without standard::size
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.378: file ../glib/gio/gfileinfo.c: line 1845 (g_file_info_get_size): should not be reached
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.378: GFileInfo created without standard::content-type
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.378: file ../glib/gio/gfileinfo.c: line 1821 (g_file_info_get_content_type): should not be reached
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.378: GFileInfo created without standard::is-symlink
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.378: file ../glib/gio/gfileinfo.c: line 1676 (g_file_info_get_is_symlink): should not be reached
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.378: GFileInfo created without standard::is-backup
(pcmanfm:10501): GLib-GIO-CRITICAL **: 08:17:19.378: file ../glib/gio/gfileinfo.c: line 1654 (g_file_info_get_is_backup): should not be reached
unable to connect to the rxvt-unicode daemon: Connection refused
[10747, Main Thread] WARNING: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not(): 'glib warning', file /usr/src/debug/firefox/firefox-127.0.1/toolkit/xre/nsSigHandlers.cpp:187
(firefox:10747): Gtk-WARNING **: 08:19:09.975: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
[10889, Main Thread] WARNING: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not(): 'glib warning', file /usr/src/debug/firefox/firefox-127.0.1/toolkit/xre/nsSigHandlers.cpp:187
(firefox:10889): Gtk-WARNING **: 08:19:50.362: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
[11007, Main Thread] WARNING: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not(): 'glib warning', file /usr/src/debug/firefox/firefox-127.0.1/toolkit/xre/nsSigHandlers.cpp:187
(firefox:11007): Gtk-WARNING **: 08:20:27.035: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
** Message: 08:31:47.697: updates_checker.vala:70: check updates
** Message: 08:31:49.008: updates_checker.vala:100: 0 updates found
[11991, Main Thread] WARNING: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not(): 'glib warning', file /usr/src/debug/firefox/firefox-127.0.1/toolkit/xre/nsSigHandlers.cpp:187
(firefox:11991): Gtk-WARNING **: 08:43:59.963: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
[12131, Main Thread] WARNING: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not(): 'glib warning', file /usr/src/debug/firefox/firefox-127.0.1/toolkit/xre/nsSigHandlers.cpp:187
(firefox:12131): Gtk-WARNING **: 08:45:16.800: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
WARNING: The convert command is deprecated in IMv7, use "magick"
** Message: 09:31:49.704: updates_checker.vala:70: check updates
** Message: 09:31:51.592: updates_checker.vala:100: 0 updates found
[Updates] Error fetching https://discord.com/api/updates/stable?platform=linux&version=0.0.58: getaddrinfo EAI_AGAIN discord.com
** Message: 10:02:03.727: updates_checker.vala:70: check updates
** Message: 10:02:05.161: updates_checker.vala:100: 0 updates found
** Message: 10:31:51.697: updates_checker.vala:70: check updates
** Message: 10:31:53.000: updates_checker.vala:100: 0 updates found
** Message: 10:46:52.437: updates_checker.vala:70: check updates
** Message: 10:46:53.786: updates_checker.vala:100: 0 updates found
(pcmanfm:10501): GLib-CRITICAL **: 10:49:04.872: Source ID 47 was not found when attempting to remove it
(pcmanfm:10501): GLib-CRITICAL **: 10:49:04.956: Source ID 8893 was not found when attempting to remove it
(pcmanfm:10501): GLib-CRITICAL **: 10:49:04.969: Source ID 8913 was not found when attempting to remove it
(pcmanfm:10501): GLib-CRITICAL **: 10:49:04.978: Source ID 8923 was not found when attempting to remove it
(pcmanfm:10501): GLib-CRITICAL **: 10:49:04.987: Source ID 8932 was not found when attempting to remove it
(pcmanfm:10501): GLib-CRITICAL **: 10:49:12.332: Source ID 8941 was not found when attempting to remove it
(pcmanfm:10501): GLib-CRITICAL **: 10:49:14.429: Source ID 9191 was not found when attempting to remove it
(pcmanfm:10501): GLib-CRITICAL **: 10:49:15.961: Source ID 9235 was not found when attempting to remove it
[20384, Main Thread] WARNING: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not(): 'glib warning', file /usr/src/debug/firefox/firefox-127.0.1/toolkit/xre/nsSigHandlers.cpp:187
(firefox:20384): Gtk-WARNING **: 11:30:03.410: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
** Message: 11:47:27.367: updates_checker.vala:70: check updates
** Message: 11:47:28.728: updates_checker.vala:100: 0 updates found
(pcmanfm:22252): Gtk-WARNING **: 12:02:15.550: Unable to locate theme engine in module_path: "murrine",
(pcmanfm:22252): Gtk-WARNING **: 12:02:15.554: Unable to locate theme engine in module_path: "murrine",
(pcmanfm:22252): Gtk-WARNING **: 12:02:15.556: Unable to locate theme engine in module_path: "murrine",
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.963: GFileInfo created without standard::edit-name
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.963: file ../glib/gio/gfileinfo.c: line 1742 (g_file_info_get_edit_name): should not be reached
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.963: GFileInfo created without standard::size
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.964: file ../glib/gio/gfileinfo.c: line 1845 (g_file_info_get_size): should not be reached
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.964: GFileInfo created without standard::content-type
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.964: file ../glib/gio/gfileinfo.c: line 1821 (g_file_info_get_content_type): should not be reached
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.964: GFileInfo created without standard::is-symlink
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.964: file ../glib/gio/gfileinfo.c: line 1676 (g_file_info_get_is_symlink): should not be reached
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.964: GFileInfo created without standard::is-backup
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.964: file ../glib/gio/gfileinfo.c: line 1654 (g_file_info_get_is_backup): should not be reached
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.970: GFileInfo created without standard::edit-name
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.971: file ../glib/gio/gfileinfo.c: line 1742 (g_file_info_get_edit_name): should not be reached
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.971: GFileInfo created without standard::size
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.971: file ../glib/gio/gfileinfo.c: line 1845 (g_file_info_get_size): should not be reached
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.971: GFileInfo created without standard::is-symlink
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.971: file ../glib/gio/gfileinfo.c: line 1676 (g_file_info_get_is_symlink): should not be reached
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.971: GFileInfo created without standard::is-hidden
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.971: file ../glib/gio/gfileinfo.c: line 1632 (g_file_info_get_is_hidden): should not be reached
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.971: GFileInfo created without standard::is-backup
(pcmanfm:22252): GLib-GIO-CRITICAL **: 12:02:15.971: file ../glib/gio/gfileinfo.c: line 1654 (g_file_info_get_is_backup): should not be reached
(mousepad:22318): Gtk-WARNING **: 12:02:23.006: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
Mousepad-Message: 12:02:23.305: Failed to load plugin "mousepad-plugin-gspell": libgspell-1.so.2: cannot open shared object file: No such file or directory
(xarchiver:22364): Gtk-WARNING **: 12:02:48.369: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(xarchiver:22487): Gtk-WARNING **: 12:04:24.794: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(xarchiver:22516): Gtk-WARNING **: 12:04:50.407: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(pcmanfm:22252): GLib-CRITICAL **: 12:06:17.149: Source ID 46 was not found when attempting to remove it
(pcmanfm:22252): GLib-CRITICAL **: 12:06:20.431: Source ID 3598 was not found when attempting to remove it
(xarchiver:22627): Gtk-WARNING **: 12:06:23.558: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(xarchiver:22874): Gtk-WARNING **: 12:10:37.786: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(pcmanfm:22252): GLib-CRITICAL **: 12:11:26.013: Source ID 3728 was not found when attempting to remove it
(mousepad:22958): Gtk-WARNING **: 12:11:39.431: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
Mousepad-Message: 12:11:39.708: Failed to load plugin "mousepad-plugin-gspell": libgspell-1.so.2: cannot open shared object file: No such file or directory
(xarchiver:23016): Gtk-WARNING **: 12:11:59.492: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(blueman-manager:23980): Gtk-WARNING **: 06:23:32.229: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
** Message: 06:46:53.729: updates_checker.vala:70: check updates
** Message: 06:53:27.898: updates_checker.vala:100: 1 updates found
** Message: 07:31:43.776: updates_checker.vala:70: check updates
** Message: 07:31:48.141: updates_checker.vala:100: 1 updates found
** Message: 07:41:50.503: updates_checker.vala:70: check updates
** Message: 07:41:53.824: updates_checker.vala:100: 0 updates found
BUG: single log message > 4k
i3status: exiting due to signal.
** Message: 07:53:27.806: updates_checker.vala:70: check updates
** Message: 07:53:29.455: updates_checker.vala:100: 0 updates found
** Message: 08:53:29.806: updates_checker.vala:70: check updates
** Message: 08:53:31.155: updates_checker.vala:100: 0 updates found
** Message: 09:53:31.806: updates_checker.vala:70: check updates
** Message: 09:53:33.139: updates_checker.vala:100: 0 updates found
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 014024da
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 0100018b
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 02800032
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 0380002e
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 01800041
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 01a00b9d
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 0280003f
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 01402fa6
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 010001c6
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 01800056
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 0380003d
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 01a01147
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 01a01154
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 0280004c
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 01800063
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 01402fb3
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 0380004a
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 010001d3
** Message: 10:53:33.807: updates_checker.vala:70: check updates
** Message: 10:53:35.150: updates_checker.vala:100: 0 updates found
** Message: 12:00:13.878: updates_checker.vala:70: check updates
** Message: 12:00:15.357: updates_checker.vala:100: 0 updates found
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 01800072
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 0380005b
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 01a0115d
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 01402fc0
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 010001de
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 02800063
(pcmanfm:40897): Gtk-WARNING **: 19:46:39.605: Unable to locate theme engine in module_path: "murrine",
(pcmanfm:40897): Gtk-WARNING **: 19:46:39.607: Unable to locate theme engine in module_path: "murrine",
(pcmanfm:40897): Gtk-WARNING **: 19:46:39.610: Unable to locate theme engine in module_path: "murrine",
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.114: GFileInfo created without standard::edit-name
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.114: file ../glib/gio/gfileinfo.c: line 1742 (g_file_info_get_edit_name): should not be reached
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.114: GFileInfo created without standard::size
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.114: file ../glib/gio/gfileinfo.c: line 1845 (g_file_info_get_size): should not be reached
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.114: GFileInfo created without standard::content-type
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.114: file ../glib/gio/gfileinfo.c: line 1821 (g_file_info_get_content_type): should not be reached
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.114: GFileInfo created without standard::is-symlink
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.114: file ../glib/gio/gfileinfo.c: line 1676 (g_file_info_get_is_symlink): should not be reached
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.114: GFileInfo created without standard::is-backup
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.114: file ../glib/gio/gfileinfo.c: line 1654 (g_file_info_get_is_backup): should not be reached
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.120: GFileInfo created without standard::edit-name
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.120: file ../glib/gio/gfileinfo.c: line 1742 (g_file_info_get_edit_name): should not be reached
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.120: GFileInfo created without standard::size
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.120: file ../glib/gio/gfileinfo.c: line 1845 (g_file_info_get_size): should not be reached
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.120: GFileInfo created without standard::is-symlink
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.120: file ../glib/gio/gfileinfo.c: line 1676 (g_file_info_get_is_symlink): should not be reached
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.120: GFileInfo created without standard::is-hidden
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.121: file ../glib/gio/gfileinfo.c: line 1632 (g_file_info_get_is_hidden): should not be reached
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.121: GFileInfo created without standard::is-backup
(pcmanfm:40897): GLib-GIO-CRITICAL **: 19:46:40.121: file ../glib/gio/gfileinfo.c: line 1654 (g_file_info_get_is_backup): should not be reached
(mousepad:40922): Gtk-WARNING **: 19:46:42.261: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
Mousepad-Message: 19:46:42.531: Failed to load plugin "mousepad-plugin-gspell": libgspell-1.so.2: cannot open shared object file: No such file or directory
** Message: 19:50:43.649: updates_checker.vala:70: check updates
** Message: 19:50:48.051: updates_checker.vala:100: 0 updates found
You have this thread marked as both Gnome and i3.
I’ll take a guess that you hav tried having both coexist in one Manjaro instance. I’ll avoid focusing on what an inherently bad idea that is, but it might help others to know under which DE you are getting these errors, and also whether you are using X11 or Wayland (if Gnome).
Cheers.
Sorry, I only put i3 of manjaro, I don’t know how to mark it.
I installed i3 from the official manjaro site and I haven’t DE
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   aaa@aaa-80e1
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   ------------
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   OS: Manjaro Linux x86_64
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Host: 80E1 Lenovo G40-45
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ                         β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Kernel: 6.6.34-1-MANJARO
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Uptime: 2 days, 16 hours, 22 mins
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Packages: 1378 (pacman)
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Shell: bash 5.2.26
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Resolution: 1366x768
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   WM: i3
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Theme: Adapta-Nokto-Eta-Maia [GTK2/3]
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Icons: Papirus-Dark [GTK2/3]
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Terminal: urxvt
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Terminal Font: 9x15,xft
                               CPU: AMD E1-6010 APU with AMD Radeon R2 Graphics (2) @ 1.350GHz
                               GPU: AMD ATI Radeon R2 Graphics
                               Memory: 2191MiB / 6902MiB
Information from neofetch or similar isn’t as useful as you might think. Please provide output of the following commands:
System information;
inxi --admin --verbosity=8 --filter --no-host --width
Recent logs;
journalctl --boot=-1 --priority=3 --catalog --no-pager
Most of your errors are indication that the murrine theme engine is missing; you could try installing that to begin with; then reboot and compare the difference in errors.
This indicates an error with whatever dark theme you are currently using; it looks like the error is in gtk-contained-dark.css.
All/most of this seems theme related.
Please create a new User account in Manjaro, login to it, and report back whether or not you have the same errors.
  Kernel: 6.6.34-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=e1dcd096-1707-4bc3-b652-365351f808f8 rw quiet apparmor=1
    security=apparmor resume=UUID=8a7f014f-4983-47e9-b9ab-adb4f9cf69b3
    udev.log_priority=3
  Desktop: i3 v: 4.23 with: i3bar tools: xautolock avail: i3lock vt: 7
    dm: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 80E1 v: Lenovo G40-45
    serial: <superuser required> Chassis: type: 10 v: Lenovo G40-45
  Mobo: LENOVO model: Lancer 4B2 v: SDK0H15299 WIN
    serial: <superuser required> part-nu: LENOVO_MT_80E1_BU_idea_FM_Lenovo G40-45
    uuid: <superuser required> UEFI-[Legacy]: LENOVO v: A2CN34WW(V2.02)
    date: 02/28/2015
  ID-1: BAT1 charge: 19.4 Wh (99.0%) condition: 19.6/28.5 Wh (68.9%)
    power: 9.4 W volts: 15.9 min: 14.4 model: LENOVO PABAS0241231 type: Li-ion
    serial: <filter> status: discharging
  System RAM: total: 8 GiB available: 6.74 GiB used: 2.58 GiB (38.3%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: Channel-A DIMM 0 type: DDR3 detail: synchronous unbuffered
    (unregistered) size: 4 GiB speed: spec: 800 MT/s actual: 667 MT/s
    volts: N/A width (bits): data: 64 total: 64 manufacturer: Micron Technology
    part-no: 8KTF51264HZ-1G6E1 serial: <filter>
  Device-2: Channel-A DIMM 1 type: DDR3 detail: synchronous unbuffered
    volts: N/A width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M471B5173EB0-YK0 serial: <filter>
  Info: model: AMD E1-6010 APU with AMD Radeon R2 Graphics bits: 64 type: MCP
    arch: Puma level: v2 built: 2014-15 process: GF 28nm family: 0x16 (22)
    model-id: 0x30 (48) stepping: 1 microcode: 0x7030105
  Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
    desc: d-2x32 KiB; i-2x32 KiB L2: 1024 KiB desc: 1x1024 KiB
  Speed (MHz): avg: 1148 high: 1277 min/max: 1000/1350 boost: disabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1277 2: 1020
    bogomips: 5392
  Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avx bmi1 bpext
    clflush cmov cmp_legacy constant_tsc cpuid cr8_legacy cx16 cx8 de
    decodeassists extapic extd_apicid f16c flushbyasid fpu fxsr fxsr_opt ht
    hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe
    msr mtrr nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_llc perfctr_nb pfthreshold pge pni
    popcnt pse pse36 ptsc rdtscp rep_good sep skinit ssbd sse sse2 sse4_1
    sse4_2 sse4a ssse3 svm svm_lock syscall topoext tsc tsc_scale vme vmmcall
    wdt xsave xsaveopt
  Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
  Device-1: AMD Mullins [Radeon R2 Graphics] vendor: Lenovo driver: radeon
    v: kernel alternate: amdgpu arch: GCN-2 code: Sea Islands
    process: GF/TSMC 16-28nm built: 2013-17 ports: active: eDP-1
    empty: HDMI-A-1,VGA-1 bus-ID: 00:01.0 chip-ID: 1002:9853 class-ID: 0300
  Device-2: Bison Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.2:3 chip-ID: 5986:0652
  Display: x11 server: X.org v: 1.21.1.13 compositor: Picom v: git-89c2c
    driver: X: loaded: radeon unloaded: modesetting alternate: fbdev,vesa
    dri: radeonsi gpu: radeon display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 mapped: eDP model: LG Display 0x0455 built: 2014
    res: 1366x768 hz: 60 dpi: 112 gamma: 1.2 chroma: red: x: 0.584 y: 0.349
    green: x: 0.329 y: 0.565 blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
    size: 310x174mm (12.2x6.85") diag: 355mm (14") ratio: 16:9 modes: 1366x768,
    1280x720, 1152x768, 1024x768, 800x600, 848x480, 720x480, 640x480
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.5 vendor: amd mesa v: 24.1.1-manjaro1.1 glx-v: 1.4
    direct-render: yes renderer: KABINI (radeonsi LLVM 17.0.6 DRM 2.50
    6.6.34-1-MANJARO) device-ID: 1002:9853 memory: 1000 MiB unified: no
  Device-1: AMD Kabini HDMI/DP Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
  Device-2: AMD FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel
    bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
  API: ALSA v: k6.6.34-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
  Device-1: Qualcomm Atheros QCA6164 802.11ac Wireless Network Adapter
    vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:0041 class-ID: 0280
    vendor: Lenovo driver: r8168 v: 8.053.00-NAPI modules: r8169 pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 driver: btusb v: 0.8
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.3:4
    chip-ID: 0cf3:e300 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 9 state: down bt-service: enabled,running
    rfk-block: hardware: no software: yes address: <filter> bt-v: 4.1 lmp-v: 7
    status: discoverable: no pairing: no
  Local Storage: total: 447.13 GiB used: 72.25 GiB (16.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 480GB SSD
    size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0KA3 scheme: MBR
  ID-1: / raw-size: 438.33 GiB size: 430.38 GiB (98.19%) used: 71.6 GiB (16.6%)
    fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: e1dcd096-1707-4bc3-b652-365351f808f8
  ID-1: swap-1 type: partition size: 8.8 GiB used: 668.6 MiB (7.4%)
    priority: -2 dev: /dev/sda2 maj-min: 8:2 label: swap
    uuid: 8a7f014f-4983-47e9-b9ab-adb4f9cf69b3
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
    chip-ID: 0438:7900 class-ID: 0900
  Device-1: 1-1.3:3 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
  Device-1: 2-1.2:3 info: Bison Lenovo EasyCamera type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 5986:0652 class-ID: 0e02 serial: <filter>
  Device-2: 2-1.3:4 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0
    type: bluetooth driver: btusb interfaces: 2 rev: 1.1
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.0
  System Temperatures: cpu: 50.0 C mobo: N/A gpu: radeon temp: 51.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1378 libs: 344 tools: pamac,yay
    1: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    2: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    3: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    4: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    5: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    7: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    9: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    10: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    11: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    12: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    13: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    14: https://manjaro.ynh.ovh/stable/$repo/$arch
    15: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    16: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    17: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    18: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    19: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    20: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    22: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    24: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    25: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    26: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    27: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    28: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    29: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    30: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    31: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    32: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    33: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    34: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    35: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    36: https://mirrors2.manjaro.org/stable/$repo/$arch
    37: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 205
  1: cpu: 250% command: ps pid: 45141 mem: 3.37 MiB (0.0%)
  2: cpu: 33.3% command: sh pid: 45140 mem: 3.00 MiB (0.0%)
  3: cpu: 5.9% command: firefox pid: 39197 mem: 606.6 MiB (8.7%)
  4: cpu: 4.9% command: firefox pid: 45108 mem: 48.4 MiB (0.7%)
  5: cpu: 4.0% command: Discord pid: 1896 mem: 304.1 MiB (4.4%)
  Memory top: 5 of 205
  1: mem: 606.6 MiB (8.7%) command: firefox pid: 39197 cpu: 5.9%
  2: mem: 304.1 MiB (4.4%) command: Discord pid: 1896 cpu: 4.0%
  3: mem: 210.5 MiB (3.0%) command: firefox pid: 43009 cpu: 1.3%
  4: mem: 179.1 MiB (2.5%) command: firefox pid: 44174 cpu: 1.0%
  5: mem: 176.6 MiB (2.5%) command: firefox pid: 39283 cpu: 0.4%
  Processes: 205 Power: uptime: 2d 16h 40m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 4 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 2.68 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 256
  Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Bash v: 5.2.26
    running-in: urxvtd inxi: 3.3.35
Jul 07 18:20:24 aaa-80e1 kernel: __common_interrupt: 1.55 No irq handler for vector
Jul 07 18:20:27 aaa-80e1 kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Jul 07 18:20:32 aaa-80e1 kernel: kvm_amd: SVM disabled (by BIOS) in MSR_VM_CR on CPU 0
Jul 07 18:20:35 aaa-80e1 bluetoothd[659]: Failed to set mode: Failed (0x03)
Jul 07 18:20:42 aaa-80e1 dbus-broker-launch[900]: Ignoring duplicate name 'org.freedesktop.Notifications' in service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service'
β–‘β–‘ Subject: Invalid service file
β–‘β–‘ Defined-By: dbus-broker
β–‘β–‘ Support: https://groups.google.com/forum/#!forum/bus1-devel
β–‘β–‘
β–‘β–‘ A service file is a ini-type configuration file.
β–‘β–‘
β–‘β–‘ It has one required section
β–‘β–‘ named [D-BUS Service]. The section contains the required key 'Name', which
β–‘β–‘ must be a valid D-Bus name that is unique across all service files. It also
β–‘β–‘ contains at least one of the two optional keys 'SystemdService' and 'Exec',
β–‘β–‘ as well as optionally the key 'User'. Exec must be a valid shell command and
β–‘β–‘ User must be a valid user on the system.
β–‘β–‘
β–‘β–‘ A service file should be named after the D-Bus name it configures. That is
β–‘β–‘ a file containing Name=org.foo.bar1 should be named org.foo.bar1.service.
β–‘β–‘ For backwards compatibility, we only warn when files do not follow this
β–‘β–‘ convention when run as a user bus. The system bus considers this an error
β–‘β–‘ and ignores the service file.
Jul 07 18:21:02 aaa-80e1 lightdm[971]: gkr-pam: unable to locate daemon control file
Jul 07 18:21:03 aaa-80e1 dbus-broker-launch[1014]: Ignoring duplicate name 'org.freedesktop.Notifications' in service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service'
β–‘β–‘
β–‘β–‘
β–‘β–‘
Jul 07 21:13:15 aaa-80e1 dbus-broker-launch[654]: Activation request for 'org.freedesktop.PolicyKit1' failed.
Jul 07 21:13:15 aaa-80e1 dbus-broker-launch[654]: Activation request for 'org.bluez' failed.
Jul 07 21:13:16 aaa-80e1 dbus-broker-launch[654]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: firmware crashed! (guid 13aac144-101a-4e88-9f53-f1c7dcda4eef)
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: firmware register dump:
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [00]: 0x05010000 0x00000000 0x0092E4DC 0xCCC45232
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [04]: 0x0092E4DC 0x00060130 0x00000018 0x0041A760
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [08]: 0xCCC4521E 0x00400000 0x00000000 0x000A5C88
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [12]: 0x00000009 0x00000000 0x0096C09C 0x0096C0A7
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [16]: 0x0096BDBC 0x009287BD 0x00000000 0x009287BD
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [20]: 0x4092E4DC 0x0041A710 0x00000000 0x0F000000
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [24]: 0x809432A7 0x0041A770 0x0040D400 0xC092E4DC
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [28]: 0x80942BC4 0x0041A790 0xCCC4521E 0x00400000
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [32]: 0x80947BA7 0x0041A7B0 0x004050A8 0x0040E074
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [36]: 0x809BDECC 0x0041A7D0 0x004050A8 0x0040E074
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [40]: 0x8099638C 0x0041A7F0 0x004050A8 0x00000000
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [44]: 0x80992076 0x0041A810 0x0044FD68 0x0046FFE8
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [48]: 0x80996BD3 0x0041A830 0x0044FD68 0x00000000
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [52]: 0x800B4405 0x0041A850 0x00422318 0x00005002
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [56]: 0x809A6C34 0x0041A8E0 0x0042932C 0x0042CA44
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: Copy Engine register dump:
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [00]: 0x00034400   1   1   3   3
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [01]: 0x00034800   9   9  44  45
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [02]: 0x00034c00  20  20  83  84
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [03]: 0x00035000  24  24  24  24
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [04]: 0x00035400 3445 3445 252 188
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [05]: 0x00035800   0   0   0   0
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [06]: 0x00035c00   6   6   6   6
Jul 07 21:13:16 aaa-80e1 kernel: ath10k_pci 0000:01:00.0: [07]: 0x00036000   0   0   0   0
In January, the default dbus daemon was changed to dbus-broker. You were asked at the time whether pacman should install dbus-broker-units or dbus-daemon-units; the former was recommended. It seems that dbus-daemon-units was better in some cases. Your logs indicate this may apply to you, but I cannot offer further advice on that.
Still waiting for requested information:
this is from the new user .xsession-errors
what more information do you need?
/bin/sh: line 1: ff-theme-util: command not found
conky: desktop window (0x48e) is root window
conky: window type - override
conky: drawing to created window (0x1600001)
conky: drawing to double buffer
conky: forked to background, pid is 1097
conky: FOUND: console
conky: FOUND: ncurses
conky: FOUND: file
conky: FOUND: x11
conky: FOUND: wayland
i3status: trying to auto-detect output_format setting
i3status: auto-detected "i3bar"
conky: 'i3' x11 session running 'i3' desktop
(clipit:1035): Gtk-WARNING **: 23:39:19.540: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(xfce4-power-manager:1033): Gtk-WARNING **: 23:39:19.569: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(volumeicon:1027): Gtk-WARNING **: 23:39:19.593: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(polkit-gnome-authentication-agent-1:1028): Gtk-WARNING **: 23:39:19.610: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(pamac-tray:1034): Gtk-WARNING **: 23:39:19.653: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
conky: drawing to created window (0x1e00001)
conky: forked to background, pid is 1103
(nm-applet:1031): Gtk-WARNING **: 23:39:19.803: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
conky: FOUND: file
conky: FOUND: x11
(nitrogen:1032): GLib-GObject-CRITICAL **: 23:39:20.472: Attempting to freeze the notification queue for object GtkSettings[0x55744f9afa20]; Property notification does not work during instance finalization.
(nitrogen:1032): GLib-GObject-CRITICAL **: 23:39:20.473: Attempting to thaw the notification queue for object GtkSettings[0x55744f9afa20]; Property notification does not work during instance finalization.
(xfce4-power-manager:1033): xfce4-power-manager-WARNING **: 23:39:20.824: Unable to connect to session manager : Failed to connect to the session manager: SESSION_MANAGER environment variable not defined
[ 07/10/2024 23:39:21.660 parse_config_libconfig WARN ] The refresh-rate option has been deprecated. Please remove it from your configuration file. If you encounter any problems without this feature, please feel free to open a bug report
snd_mixer_handle_events: No such file or directory
(manjaro-hello:1030): Gtk-WARNING **: 23:39:22.927: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
/usr/bin/manjaro-hello:239: DeprecationWarning: 'locale.getdefaultlocale' is deprecated and slated for removal in Python 3.15. Use setlocale(), getencoding() and getlocale() instead.
  sys_locale = locale.getdefaultlocale()[0]
DEBUG:root:_DATA_DIR is /usr/share/application-utility
DEBUG:root:_PREF_FILE is /usr/share/application-utility/preferences.json
DEBUG:root:self.file is {'desktop': '', 'main': '/usr/share/application-utility/default.json'}
INFO:root:json to merge : /usr/share/application-utility/default.json
DEBUG:root:json : /tmp/manjaro-hello-preferences.json
(clipit:1035): GLib-CRITICAL **: 23:39:26.753: g_key_file_set_string: assertion 'string != NULL' failed
WARNING:root:File not exist ? /usr/share/application-utility/i3.json
/usr/bin/manjaro-hello:95: DeprecationWarning: Gtk.Widget.set_margin_left is deprecated
  grid.set_margin_left(5)
DEBUG:root:
--- read data.json with FILTERS ---
DEBUG:root:my desktop: i3
DEBUG:root:filter    :
DEBUG:root:groups    : *
DEBUG:root:	filter app: Epiphany ['advanced'] <
DEBUG:root:	filter app: Falkon ['advanced'] <
DEBUG:root:	filter app: Konqueror ['advanced'] <
DEBUG:root:	filter app: Claws Mail ['advanced'] <
DEBUG:root:	filter app: Atom ['advanced'] <
DEBUG:root:	filter app: Vim ['advanced'] <
DEBUG:root:	filter app: Visual Studio Code OSS ['advanced'] <
DEBUG:root:	filter app: Gnome builder ['advanced'] <
DEBUG:root:filter group : File Sharing ['advanced'] <
DEBUG:root:	filter app: Grsync ['advanced'] <
DEBUG:root:	filter app: Borg ['advanced'] <
DEBUG:root:filter group : System Tools ['advanced'] <
DEBUG:root:filter group : Virtual Computing ['advanced'] <
DEBUG:root:
DEBUG:root:filter    :
DEBUG:root:
DEBUG:root:filter    :
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.025: GFileInfo created without standard::edit-name
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.025: file ../glib/gio/gfileinfo.c: line 1742 (g_file_info_get_edit_name): should not be reached
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.026: GFileInfo created without standard::size
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.026: file ../glib/gio/gfileinfo.c: line 1845 (g_file_info_get_size): should not be reached
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.026: GFileInfo created without standard::content-type
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.026: file ../glib/gio/gfileinfo.c: line 1821 (g_file_info_get_content_type): should not be reached
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.026: GFileInfo created without standard::is-symlink
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.026: file ../glib/gio/gfileinfo.c: line 1676 (g_file_info_get_is_symlink): should not be reached
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.026: GFileInfo created without standard::is-backup
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.026: file ../glib/gio/gfileinfo.c: line 1654 (g_file_info_get_is_backup): should not be reached
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.045: GFileInfo created without standard::edit-name
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.045: file ../glib/gio/gfileinfo.c: line 1742 (g_file_info_get_edit_name): should not be reached
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.045: GFileInfo created without standard::size
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.045: file ../glib/gio/gfileinfo.c: line 1845 (g_file_info_get_size): should not be reached
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.045: GFileInfo created without standard::is-symlink
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.045: file ../glib/gio/gfileinfo.c: line 1676 (g_file_info_get_is_symlink): should not be reached
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.045: GFileInfo created without standard::is-hidden
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.045: file ../glib/gio/gfileinfo.c: line 1632 (g_file_info_get_is_hidden): should not be reached
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.045: GFileInfo created without standard::is-backup
(pcmanfm:1283): GLib-GIO-CRITICAL **: 23:39:32.045: file ../glib/gio/gfileinfo.c: line 1654 (g_file_info_get_is_backup): should not be reached
(mousepad:1357): Gtk-WARNING **: 23:39:47.797: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
Mousepad-Message: 23:39:48.076: Failed to load plugin "mousepad-plugin-gspell": libgspell-1.so.2: cannot open shared object file: No such file or directory
** Message: 23:39:54.237: updates_checker.vala:70: check updates
cp: preserving times for '/var/tmp/pamac/dbs/sync': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync/extra.db': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync/core.files': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync/multilib.files': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync/mhwd.db': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync/multilib.db': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync/extra.files': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync/core.db': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync/refresh_timestamp': Operation not permitted
** Message: 23:39:55.722: updates_checker.vala:100: 0 updates found
[1384, Main Thread] WARNING: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not(): 'glib warning', file /usr/src/debug/firefox/firefox-127.0.1/toolkit/xre/nsSigHandlers.cpp:187
(firefox:1384): Gtk-WARNING **: 23:40:21.715: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
[Parent 1384, Main Thread] WARNING: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not(): 'glib warning', file /usr/src/debug/firefox/firefox-127.0.1/toolkit/xre/nsSigHandlers.cpp:187
(firefox:1384): Gtk-WARNING **: 23:40:23.612: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(firefox:1384): Gtk-WARNING **: 23:40:24.289: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
(firefox:1384): Gtk-WARNING **: 23:40:24.676: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
I don’t know how to do that
  • The results (if any) of installing the murrine theme engine, or at least confirmation that you did or did not try that.
  • the results of perhaps changing your theme (if you did)
  • current dump of your neofetch output
You don’t know how to do what?
 neofetch
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   nuevo_usuario@aaa-80e1
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   ----------------------
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Uptime: 20 mins
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Packages: 1379 (pacman)
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Icons: Papirus-Adapta-Nokto-Maia [GTK2/3]
                               Memory: 1068MiB / 6902MiB
And these?
Well, I have places to be.
Some of the information I’ve managed to drag from you might help someone else. I can only wish you luck.
Cheers.
I did it before creating the user but I don’t know how to see the results.
I don’t know how to change the subject
thank you very much
While I’m no expert on what ff-theme-util does, some Googling suggests that it’s something about creating Firefox themes matching system themes. Given the error logs mentioning Firefox as well, it kind of looks like removing it may have mangled quite a few things.
Perhaps reinstalling theme packages and removing ff-theme-util references might help?
I have almost identical messages in ~/.xsession-errors
on a freshly installed i3 minimal
These are coming from ~/.i3/config
programs get started from there which don’t exist - you might have uninstalled them
nitrogen is used to set and change the background - I don’t think you care about themes in i3
I’d inspect ~/.i3/config and possibly comment out what is not needed
and proceed by ignoring the rest of the messages :man_shrugging:
these are all non fatal - there is always something in ~/.xsession-errors …
yes, but what bothers me is that I have problems with firefox and I don’t know why, I try to open WA or other webapps and the browser closes.
that’s what I want to solve, the issue is not important, unless the problem is because of that.
 firefox --safe-mode
[39049, Main Thread] WARNING: Theme parsing error: gtk-contained-dark.cssebug/firefox/firefox-127.0.1/toolkit/xre/nsSigHandlers.cpp:187
(firefox:39049): Gtk-WARNING **: 15:39:08.862: Theme parsing error: gtk-c
and the problem persists in safe mode, but I don’t understand why the theme error, as far as I remember I have never modified it.
You did try a fresh firefox profile?
Just move ~/.mozilla to somewhere while the browser is not running and then restart it.
it’s not an error - just a warning
I’ll uninstall and reinstall and let you know
no no no - uninstalling and reinstalling will change absolutely nothing
It will literally change nothing at all.
That is a waste of time and effort.
If you want to change something/start fresh - all you need is a new profile in your $HOME
… as I said above …
I just did it and it didn’t work.
 mv ~/.mozilla ~/.mozilla_backup
keeps closing on its own when I open WA
Can you remind me what β€œWA” means?
web application?
If that is the case: I have no clue what that even means :man_shrugging:
starting it from terminal might provide useful output
yes like whatsapp or others for example docs or any other google docs which are the ones I use the most.
Could you explain to me what you mean by this?
open firefox from the terminal?
 firefox
[45421, Main Thread] WARNING: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not(): 'glib warning', file /usr/src/debug/firefox/firefox-127.0.1/toolkit/xre/nsSigHandlers.cpp:187
(firefox:45421): Gtk-WARNING **: 16:15:17.963: Theme parsing error: gtk-contained-dark.css:2871:228: Missing closing bracket for :not()
