File selection dialogs have changed
The file selection dialogs (e.g. browser dialog for picking files to upload), (which I believe is a system-wide UI and not an app UI) used to list recent locations, and, as I’m in the habit of moving some files through /tmp before I upload (a lot of uploads are things I don’t want to keep), it would list tmp as a recently used folder, that I could select (and would often default to it if it was the last used folder).
But now, the dialog lists “Recent files” and “Recent Loc…” without actually listing recent locations. And if I click on Recent Loc… it is empty.
Seems like a bug, or a poorly designed “upgrade”.
Please redirect if this question belongs elsewhere.
When the file picker dialog opens, right-click on the left panel and select Show All Entries. Also make sure that the Hide Section “Recent” box is not ticked:
Open System Settings → Security & Privacy → Recent Files and make sure it is set to keep history:
If the setting looks correct, try clearing the history - maybe there is an issue with the database.
Everything seems to be set correctly. Except I don’t have a “Show All Entries” item in my sidebar menu.
The “Show All Entries” option will only show when you right-click on certain areas of the sidebar. Try it with your pointer hovering over the “Places” section heading:
I noticed the change too. It took a little getting used to, but after a few days I stopped thinking about it. If the new dialog is coming from a toolkit update rather than Manjaro itself, there may not be much that can be done except tweaking the relevant desktop or application settings.
That is always the case. We do not modify such things.
I’ve never had any success getting that “Show All Entries” to appear.
But there is an “Add Entry” that can be applied to any section. I ended up adding a Tmp entry that points to /tmp, which “solved” my problem (but doesn’t solve the elimination of a perfectly good feature that I had relied on).
For consideration:
Is it possible that all entries are already shown (no sections are hidden)?
In that case, it might make sense that “Show All Entries” doesn’t make an appearance and only “Add Entry” does.
Try Hiding an entry, then check for Show All Entries.
I have absolutely considered that. I actually do not no what triggers a thing to be a recent item. I do regularly upload things from /tmp. it is possible that only downloads, or saves from other applications, lead to “recent locations” being updated, and that uploads do not. It is also possible that at some point someone decided to skip over “system-ish” locations that might somehow pollute recent locations, and marked “/tmp” as something that should be skipped. There are other possibilities as well. Since I have a workaround I saw no need to go wading through source code trying to track down wild guesses like this. But it does in fact seem likely that this is part of the problem. But before the changes that sparked this thread, /tmp did show up just fine as a recent location. Some coder somewhere tried to make something better and made it worse, because our worldviews are not identical.
