Hello, I have a problem with my Fiio K3.
This USB DAC was running for about 2,5 years on my pc.
Then without any reason the device stopped working while I was using it for playing music.
I already tried the device on another hardware (Macbook) where it works without any problem.
Changing USB-Cable or the port does not help.
I also tried to change the following parameters under /sys/module/usbcore/parameters/:
use_both_schemes → Y
old_scheme_first → Y
autosuspend → 2
All without any success.
Here is the output of journalctl when I turn on the device:
Okt 13 16:25:37 nightmare-pc kernel: usb 1-10: new high-speed USB device number 18 using xhci_hcd
Okt 13 16:25:37 nightmare-pc kernel: usb 1-10: New USB device found, idVendor=2972, idProduct=0047, bcdDevice= 2.26
Okt 13 16:25:37 nightmare-pc kernel: usb 1-10: New USB device strings: Mfr=1, Product=3, SerialNumber=0
Okt 13 16:25:37 nightmare-pc kernel: usb 1-10: Product: FiiO K3
Okt 13 16:25:37 nightmare-pc kernel: usb 1-10: Manufacturer: GuangZhou FiiO Electronics Co.,Ltd
Okt 13 16:25:37 nightmare-pc kernel: usb 1-10: parse_audio_format_rates_v2v3(): unable to retrieve number of sample rates (clock 41)
Okt 13 16:25:38 nightmare-pc kernel: usb 1-10: parse_audio_format_rates_v2v3(): unable to retrieve number of sample rates (clock 41)
Okt 13 16:25:38 nightmare-pc kernel: usb 1-10: 1:3 : unsupported format bits 0x100000000
Okt 13 16:25:38 nightmare-pc kernel: usb 1-10: USB disconnect, device number 18
Okt 13 16:25:38 nightmare-pc kernel: usb 1-10: new full-speed USB device number 19 using xhci_hcd
Okt 13 16:25:38 nightmare-pc kernel: usb 1-10: Device not responding to setup address.
Okt 13 16:25:38 nightmare-pc kernel: usb 1-10: device not accepting address 19, error -71
Okt 13 16:25:38 nightmare-pc kernel: usb 1-10: WARN: invalid context state for evaluate context command.
Okt 13 16:25:38 nightmare-pc kernel: usb 1-10: new high-speed USB device number 20 using xhci_hcd
Okt 13 16:25:39 nightmare-pc kernel: usb 1-10: Device not responding to setup address.
Okt 13 16:25:39 nightmare-pc kernel: usb 1-10: device not accepting address 20, error -71
Okt 13 16:25:39 nightmare-pc kernel: usb usb1-port10: attempt power cycle
Okt 13 16:25:39 nightmare-pc kernel: usb 1-10: new high-speed USB device number 21 using xhci_hcd
Okt 13 16:25:40 nightmare-pc kernel: usb 1-10: new full-speed USB device number 22 using xhci_hcd
Okt 13 16:25:40 nightmare-pc kernel: usb 1-10: device descriptor read/64, error -71
Okt 13 16:25:45 nightmare-pc (udev-worker)[17148]: controlC4: /usr/lib/udev/rules.d/78-sound-card.rules:5 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-10/1-10:1.0/sound/card4/controlC4/../uevent}="change", ignoring: No such file or directory
Okt 13 16:25:45 nightmare-pc colord-sane[17150]: io/hpmud/pp.c 627: unable to read device-id ret=-1
Hopefully somebody could help me or give me a hint.
Any help is appreciated. Thank you
