Fifine AM8 Microphone records distorted voice
I’ve just bought this microphone and it records my voice distorted as if I was drunk and my nasal holes were obstructed. Is this a matter of settings or drivers?
Moderator edit: Corrected model number in topic title
Welcome to the Manjaro Community! :vulcan_salute:
Unfortunately, without at least some basic information about your system & setup, it is impossible for people wishing to help to be able to do so.
To this end, could you provide the output of the command:
inxi -zv8
… please select ALL the output in the Terminal, then paste here;
Highlight all the pasted text then click the </> button at the top of the Reply window, or add three backticks ``` (or three tildes ~~~) on their own lines above and below the pasted text.
This formats it correctly for the Forum, and the information will hopefully give us an insight.
Also see: [HowTo] Request support
Cheers! :wink:
Distortion is most likely to be caused by setting the microphone gain too high
Review for this microphone has gain set to “around 12 O’Clock” (50%)
youtube - podcastage - FiFine AM8 Review
Microphone gain can be adjusted manually on the microphone so there is unlikely to be additional gain controls in alsamixer
