Ffmpeg/ffplay with -hwaccel vulkan not working
ffmpeg/ffplay with -hwaccel vulkan not work anymore since [Stable Update] 2026-08-12
Segmentation fault         (core dumped) ffplay -hwaccel vulkan -x 1200 -y 900 https://test-videos.co.uk/vids/bigbuckbunny/mp4/h264/1080/Big_Buck_Bunny_1080_10s_1MB.mp4
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Your post has been moved to a dedicated topic.
Please provide your system information in accordance with forum guidelines. See Mini-HowTo’s (below) :point_down: and any other detail that might help others to diagnose your issue:
inxi -zv8 (short-form)
Your privacy is respected
What is a Quark?
Posted already this information.
No problems before. No problems under Windows 11 Pro with -hwaccel vulkan
inxi -G
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 14 [Radeon RX 5500/5500M /
    Pro 5300/5300M/5500M] driver: amdgpu v: kernel
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    compositor: kwin_wayland driver: X: loaded: amdgpu dri: radeonsi gpu: amdgpu
    resolution: 2560x1440~120Hz
  API: EGL v: 1.5 drivers: radeonsi,swrast
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.1.6-arch1.1 renderer: AMD
    Radeon RX 5500 XT (radeonsi navi14 ACO DRM 3.64 6.18.44-1-MANJARO)
  API: Vulkan v: 1.4.357 drivers: radv surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
Your inxi -zv8 output is incomplete.
Please edit your post and add the full output.
What’s the full terminal output?
Have you tried mpv --hwdec=vaapi?
inxi -zv8:
  Kernel: 6.18.45-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    root=UUID=8ad0a47f-2824-4cc0-820a-82d947361e35 rw quiet loglevel=2
    udev.log_priority=3 ipv6.disable=1 nowatchdog mitigations=off
    random.trust_cpu=on amd_pstate=passive
  Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A info: frameworks v: 6.29.0
  Type: Desktop Mobo: Gigabyte model: B550M AORUS PRO
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends LLC. v: F19 date: 10/28/2025
  System RAM: total: 16 GiB available: 15.52 GiB used: 3.5 GiB (22.6%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Crucial
    part-no: BLS8G4D32AESBK.M8FE serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 2
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701035
    desc: 8x512 KiB L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 1760 min/max: 560/4427 boost: disabled scaling:
    driver: amd-pstate governor: ondemand cores: 1: 1760 2: 1760 3: 1760 4: 1760
    5: 1760 6: 1760 7: 1760 8: 1760 9: 1760 10: 1760 11: 1760 12: 1760
    13: 1760 14: 1760 15: 1760 16: 1760 bogomips: 114983
    constant_tsc cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
    fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv
    lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
    nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
    sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a
    ssse3 stibp succor svm svm_lock syscall tce topoext tsc tsc_scale umip
    v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xtopology
  Type: retbleed status: Vulnerable
  Type: spec_rstack_overflow status: Vulnerable
  Type: spectre_v1 status: Vulnerable: \__user pointer sanitization and
    usercopy barriers only; no swapgs barriers
  Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
  Type: vmscape status: Vulnerable
  Device-1: Advanced Micro Devices \[AMD/ATI\] Navi 14 \[Radeon RX 5500/5500M /
    Pro 5300/5300M/5500M\] vendor: XFX Pine driver: amdgpu v: kernel
    arch: RDNA-1 code: Navi-1x process: TSMC n7 (7nm) built: 2019-20 pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3
    empty: DP-1,DP-2,HDMI-A-1 bus-ID: 08:00.0 chip-ID: 1002:7340
    class-ID: 0300
    display-ID: 0
  Monitor-1: DP-3 model: LG (GoldStar) ULTRAGEAR serial: <filter>
    built: 2023 res: mode: 2560x1440 hz: 120 scale: 100% (1) dpi: 108 gamma: 1.2
    chroma: red: x: 0.686 y: 0.310 green: x: 0.263 y: 0.671 blue: x: 0.149
    y: 0.055 white: x: 0.314 y: 0.329 size: 600x340mm (23.62x13.39")
    diag: 690mm (27.2") ratio: 16:9 modes: 2560x1440, 1920x1080, 1280x720,
    1024x768, 800x600, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
    drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.1.7-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 5500 XT (radeonsi navi14 ACO DRM
    3.64 6.18.45-1-MANJARO) device-ID: 1002:7340 memory: 7.81 GiB unified: no
    display-ID: :1.0
  API: Vulkan v: 1.4.357 layers: 2 device: 0 type: discrete-gpu name: AMD
    Radeon RX 5500 XT (RADV NAVI14) driver: mesa radv v: 26.1.7-arch1.1
    device-ID: 1002:7340 surfaces: N/A
  Device-1: Advanced Micro Devices \[AMD/ATI\] Navi 10 HDMI Audio
    vendor: XFX Pine driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 08:00.1 chip-ID: 1002:ab38 class-ID: 0403
  Device-2: Advanced Micro Devices \[AMD\] Starship/Matisse HD Audio
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.18.45-1-MANJARO status: kernel-api
  Server-2: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlan0 state: down mac: <filter>
    lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel AX200 Bluetooth driver: N/A type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:2 chip-ID: 8087:0029
    class-ID: e001
  Local Storage: total: 931.51 GiB used: 18.86 GiB (2.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 38.9 C
    scheme: GPT
  ID-1: / raw-size: 31.25 GiB size: 30.59 GiB (97.88%) used: 11.35 GiB (37.1%)
    fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: 8ad0a47f-2824-4cc0-820a-82d947361e35
    used: 31.8 MiB (33.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: 58E6-2DF6
  ID-3: /home raw-size: 125 GiB size: 122.48 GiB (97.98%)
    used: 3.51 GiB (2.9%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
    uuid: 25908bf2-9ce2-4089-95e6-a67c0846119c
  ID-4: /srv1/alle raw-size: N/A size: 1.78 TiB used: 1.45 TiB (81.2%)
    fs: cifs dev: /dev/alle
  ID-5: /srv1/apps raw-size: N/A size: 1.78 TiB used: 1.45 TiB (81.2%)
    fs: cifs dev: /dev/apps
  ID-6: /srv1/download raw-size: N/A size: 1.78 TiB used: 1.45 TiB (81.2%)
    fs: cifs dev: /dev/download
  ID-7: /srv1/markus raw-size: N/A size: 1.78 TiB used: 1.45 TiB (81.2%)
    fs: cifs dev: /dev/markus
  ID-8: /srv1/video raw-size: N/A size: 1.78 TiB used: 1.45 TiB (81.2%)
    fs: cifs dev: /dev/video
  ID-9: /srv1/web raw-size: N/A size: 1.78 TiB used: 1.45 TiB (81.2%)
    fs: cifs dev: /dev/web
  ID-10: /var raw-size: 15.62 GiB size: 15.28 GiB (97.78%)
    used: 3.97 GiB (26.0%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
    label: N/A uuid: a72cdcd5-e4c9-47f8-9ccd-aa61da8ef5a2
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
  ID-1: swap-1 type: file size: 1024 MiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 248.67 GiB fs: ntfs label: win
    uuid: 2E48E71448E6D99B
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1.95 GiB fs: ntfs label: N/A
    uuid: 969E57D89E57B00B
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 15.62 GiB fs: ntfs label: work
    uuid: 39A020F743915CBF
  Device-1: 1-5:2 info: Intel AX200 Bluetooth type: bluetooth driver: N/A
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Device-2: 1-9:3 info: Integrated Express RGB LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Hub-2: 1-10:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-3: 1-10.2:5 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-10.3:6 info: CHERRY MX-Board 3.0 Keyboard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046a:010d class-ID: 0300
  Device-2: 1-10.4:7 info: ASUSTek TUF GAMING M3 GEN II
    type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 1.1
    chip-ID: 0b05:1a9b class-ID: 0300 serial: <filter>
  Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 41.4 C mobo: 34.0 C gpu: amdgpu temp: 42.0 C
    mem: 0.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: pm: pacman pkgs: 1375 libs: 418 tools: pamac
    1: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    2: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    3: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
Processes:
  CPU top: 5 of 390
  1: cpu: 3.5% command: kwin_wayland pid: 1293 mem: 246.7 MiB (1.5%)
  2: cpu: 3.5% command: firefox pid: 11069 mem: 874.4 MiB (5.5%)
  3: cpu: 2.7% command: firefox pid: 14940 mem: 397.6 MiB (2.5%)
  4: cpu: 0.7% command: firefox pid: 14276 mem: 496.0 MiB (3.1%)
  5: cpu: 0.3% command: \[kworker/u66:2-thermal_events\] pid: 18809
    mem: 0.00 MiB (0.0%)
  Memory top: 5 of 390
  1: mem: 874.4 MiB (5.5%) command: firefox pid: 11069 cpu: 3.5%
  2: mem: 625.6 MiB (3.9%) command: thunderbird pid: 12329 cpu: 0.1%
  3: mem: 496.0 MiB (3.1%) command: firefox pid: 14276 cpu: 0.7%
  4: mem: 441.5 MiB (2.7%) command: plasmashell pid: 1420 cpu: 0.1%
  5: mem: 397.6 MiB (2.5%) command: firefox pid: 14940 cpu: 2.7%
  Processes: 390 Power: uptime: 5h 14m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.16 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 261 default: graphical tool: systemctl
  Compilers: N/A Shell: Bash v: 5.3.15 running-in: konsole inxi: 3.3.41
ffplay version n9.0.1 Copyright (c) 2003-2026 the FFmpeg developers
  built with gcc 16 (GCC)
  configuration: --prefix=/usr --disable-debug --disable-static --disable-stripping --enable-amf --enable-avisynth --enable-cuda-llvm --enable-lto --enable-fontconfig --enable-frei0r --enable-gmp --enable-gnutls --enable-gpl --enable-ladspa --enable-lcms2 --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libdav1d --enable-libdrm --enable-libdvdnav --enable-libdvdread --enable-libfreetype --enable-libfribidi --enable-libgsm --enable-libharfbuzz --enable-libiec61883 --enable-libjack --enable-libjxl --enable-libmodplug --enable-libmp3lame --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libplacebo --enable-libpulse --enable-librav1e --enable-librsvg --enable-librubberband --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libtheora --enable-libv4l2 --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvpl --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxcb --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-nvdec --enable-nvenc --enable-opencl --enable-opengl --enable-shared --enable-vapoursynth --enable-version3 --enable-vulkan --disable-decoder=magicyuv
  libavutil      61.  1.101 / 61.  1.101
  libavcodec     63.  1.101 / 63.  1.101
  libavformat    63.  1.101 / 63.  1.101
  libavdevice    63.  1.101 / 63.  1.101
  libavfilter    12.  1.101 / 12.  1.101
  libswscale     10.  1.101 / 10.  1.101
  libswresample   7.  1.101 /  7.  1.101
Enable vulkan renderer to support hwaccel vulkan
[Vulkan Renderer @ 0x55651f27d200] Initialized libplacebo v7.360.1 (API v360)
[Vulkan @ 0x55651f2bf040] device extension "VK_KHR_portability_subset" not found, excluding.
[Vulkan @ 0x55651f2bf040] device extension "VK_EXT_host_image_copy" not found, excluding.
[Vulkan Renderer @ 0x55651f27d200] Imported vulkan device properties:
[Vulkan Renderer @ 0x55651f27d200]     Device Name: AMD Radeon RX 5500 XT (RADV NAVI14)
[Vulkan Renderer @ 0x55651f27d200]     Device ID: 1002:7340
[Vulkan Renderer @ 0x55651f27d200]     Device UUID: 00:00:00:00:08:00:00:00:00:00:00:00:00:00:00:00
[Vulkan Renderer @ 0x55651f27d200]     Driver version: 6801007
[Vulkan Renderer @ 0x55651f27d200]     API version: 1.4.354
[Vulkan Renderer @ 0x55651f27d200] Memory heaps supported by device:
[Vulkan Renderer @ 0x55651f27d200]     0: flags 0x0 size 7945M
[Vulkan Renderer @ 0x55651f27d200]     1: flags 0x1 size 8176M
[Vulkan Renderer @ 0x55651f27d200] Memory summary:     0 used     0 res     0 alloc, efficiency 100.00%, utilization 100.00%, max page:  511M
[Vulkan Renderer @ 0x55651f27d200] shaderc SPIR-V version 1.6 rev 1
[Vulkan Renderer @ 0x55651f27d200] Initialized SPIR-V compiler 'shaderc'
[Vulkan Renderer @ 0x55651f27d200] GPU information:
[Vulkan Renderer @ 0x55651f27d200]     GLSL version: 450 (vulkan)
[Vulkan Renderer @ 0x55651f27d200]       max_shmem_size:            65536
[Vulkan Renderer @ 0x55651f27d200]       max_group_threads:         1024
[Vulkan Renderer @ 0x55651f27d200]       max_group_size[0]:         1024
[Vulkan Renderer @ 0x55651f27d200]       max_group_size[1]:         1024
[Vulkan Renderer @ 0x55651f27d200]       max_group_size[2]:         1024
[Vulkan Renderer @ 0x55651f27d200]       subgroup_size:             64
[Vulkan Renderer @ 0x55651f27d200]       min_gather_offset:         -32
[Vulkan Renderer @ 0x55651f27d200]       max_gather_offset:         31
[Vulkan Renderer @ 0x55651f27d200]     Limits:
[Vulkan Renderer @ 0x55651f27d200]       thread_safe:               1
[Vulkan Renderer @ 0x55651f27d200]       callbacks:                 1
[Vulkan Renderer @ 0x55651f27d200]       max_buf_size:              8573157376
[Vulkan Renderer @ 0x55651f27d200]       max_ubo_size:              4294967295
[Vulkan Renderer @ 0x55651f27d200]       max_ssbo_size:             4294967295
[Vulkan Renderer @ 0x55651f27d200]       max_vbo_size:              8573157376
[Vulkan Renderer @ 0x55651f27d200]       max_mapped_size:           8573157376
[Vulkan Renderer @ 0x55651f27d200]       max_buffer_texels:         536870912
[Vulkan Renderer @ 0x55651f27d200]       align_host_ptr:            4096
[Vulkan Renderer @ 0x55651f27d200]       host_cached:               1
[Vulkan Renderer @ 0x55651f27d200]       max_tex_1d_dim:            16384
[Vulkan Renderer @ 0x55651f27d200]       max_tex_2d_dim:            16384
[Vulkan Renderer @ 0x55651f27d200]       max_tex_3d_dim:            8192
[Vulkan Renderer @ 0x55651f27d200]       blittable_1d_3d:           1
[Vulkan Renderer @ 0x55651f27d200]       buf_transfer:              1
[Vulkan Renderer @ 0x55651f27d200]       align_tex_xfer_pitch:      1
[Vulkan Renderer @ 0x55651f27d200]       align_tex_xfer_offset:     4
[Vulkan Renderer @ 0x55651f27d200]       max_variable_comps:        0
[Vulkan Renderer @ 0x55651f27d200]       max_constants:             18446744073709551615
[Vulkan Renderer @ 0x55651f27d200]       max_pushc_size:            256
[Vulkan Renderer @ 0x55651f27d200]       align_vertex_stride:       1
[Vulkan Renderer @ 0x55651f27d200]       max_dispatch[0]:           4294967295
[Vulkan Renderer @ 0x55651f27d200]       max_dispatch[1]:           65535
[Vulkan Renderer @ 0x55651f27d200]       max_dispatch[2]:           65535
[Vulkan Renderer @ 0x55651f27d200]       fragment_queues:           1
[Vulkan Renderer @ 0x55651f27d200]       compute_queues:            4
[Vulkan Renderer @ 0x55651f27d200]     External API interop:
[Vulkan Renderer @ 0x55651f27d200]       UUID: 00:00:00:00:08:00:00:00:00:00:00:00:00:00:00:00
[Vulkan Renderer @ 0x55651f27d200]       PCI: 0000:08:00:0
[Vulkan Renderer @ 0x55651f27d200]       buf export caps: 0x9
[Vulkan Renderer @ 0x55651f27d200]       buf import caps: 0x19
[Vulkan Renderer @ 0x55651f27d200]       tex export caps: 0x9
[Vulkan Renderer @ 0x55651f27d200]       tex import caps: 0x19
[Vulkan Renderer @ 0x55651f27d200]       sync export caps: 0x1
[Vulkan Renderer @ 0x55651f27d200]       sync import caps: 0x0
[Vulkan Renderer @ 0x55651f27d200] Available surface configurations:
[Vulkan Renderer @ 0x55651f27d200]     0: VK_FORMAT_A2B10G10R10_UNORM_PACK32       VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
[Vulkan Renderer @ 0x55651f27d200]     1: VK_FORMAT_A2R10G10B10_UNORM_PACK32       VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
[Vulkan Renderer @ 0x55651f27d200]     2: VK_FORMAT_B8G8R8A8_SRGB                  VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
[Vulkan Renderer @ 0x55651f27d200]     3: VK_FORMAT_B8G8R8A8_UNORM                 VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
[Vulkan Renderer @ 0x55651f27d200]     4: VK_FORMAT_R8G8B8A8_SRGB                  VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
[Vulkan Renderer @ 0x55651f27d200]     5: VK_FORMAT_R8G8B8A8_UNORM                 VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
[Vulkan Renderer @ 0x55651f27d200]     6: VK_FORMAT_R5G6B5_UNORM_PACK16            VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
[Vulkan Renderer @ 0x55651f27d200]     7: VK_FORMAT_R16G16B16A16_UNORM             VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
[Vulkan Renderer @ 0x55651f27d200]     8: VK_FORMAT_R16G16B16A16_SFLOAT            VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
[Vulkan Renderer @ 0x55651f27d200]     9: VK_FORMAT_A2B10G10R10_UNORM_PACK32       VK_COLOR_SPACE_PASS_THROUGH_EXT
[Vulkan Renderer @ 0x55651f27d200]     10: VK_FORMAT_A2R10G10B10_UNORM_PACK32       VK_COLOR_SPACE_PASS_THROUGH_EXT
[Vulkan Renderer @ 0x55651f27d200]     11: VK_FORMAT_B8G8R8A8_SRGB                  VK_COLOR_SPACE_PASS_THROUGH_EXT
[Vulkan Renderer @ 0x55651f27d200]     12: VK_FORMAT_B8G8R8A8_UNORM                 VK_COLOR_SPACE_PASS_THROUGH_EXT
[Vulkan Renderer @ 0x55651f27d200]     13: VK_FORMAT_R8G8B8A8_SRGB                  VK_COLOR_SPACE_PASS_THROUGH_EXT
[Vulkan Renderer @ 0x55651f27d200]     14: VK_FORMAT_R8G8B8A8_UNORM                 VK_COLOR_SPACE_PASS_THROUGH_EXT
[Vulkan Renderer @ 0x55651f27d200]     15: VK_FORMAT_R5G6B5_UNORM_PACK16            VK_COLOR_SPACE_PASS_THROUGH_EXT
[Vulkan Renderer @ 0x55651f27d200]     16: VK_FORMAT_R16G16B16A16_UNORM             VK_COLOR_SPACE_PASS_THROUGH_EXT
[Vulkan Renderer @ 0x55651f27d200]     17: VK_FORMAT_R16G16B16A16_SFLOAT            VK_COLOR_SPACE_PASS_THROUGH_EXT
[Vulkan Renderer @ 0x55651f27d200]     18: VK_FORMAT_A2B10G10R10_UNORM_PACK32       VK_COLOR_SPACE_EXTENDED_SRGB_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     19: VK_FORMAT_A2R10G10B10_UNORM_PACK32       VK_COLOR_SPACE_EXTENDED_SRGB_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     20: VK_FORMAT_B8G8R8A8_SRGB                  VK_COLOR_SPACE_EXTENDED_SRGB_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     21: VK_FORMAT_B8G8R8A8_UNORM                 VK_COLOR_SPACE_EXTENDED_SRGB_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     22: VK_FORMAT_R8G8B8A8_SRGB                  VK_COLOR_SPACE_EXTENDED_SRGB_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     23: VK_FORMAT_R8G8B8A8_UNORM                 VK_COLOR_SPACE_EXTENDED_SRGB_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     24: VK_FORMAT_R5G6B5_UNORM_PACK16            VK_COLOR_SPACE_EXTENDED_SRGB_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     25: VK_FORMAT_R16G16B16A16_UNORM             VK_COLOR_SPACE_EXTENDED_SRGB_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     26: VK_FORMAT_R16G16B16A16_SFLOAT            VK_COLOR_SPACE_EXTENDED_SRGB_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     27: VK_FORMAT_A2B10G10R10_UNORM_PACK32       VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     28: VK_FORMAT_A2R10G10B10_UNORM_PACK32       VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     29: VK_FORMAT_B8G8R8A8_SRGB                  VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     30: VK_FORMAT_B8G8R8A8_UNORM                 VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     31: VK_FORMAT_R8G8B8A8_SRGB                  VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     32: VK_FORMAT_R8G8B8A8_UNORM                 VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     33: VK_FORMAT_R5G6B5_UNORM_PACK16            VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     34: VK_FORMAT_R16G16B16A16_UNORM             VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     35: VK_FORMAT_R16G16B16A16_SFLOAT            VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     36: VK_FORMAT_A2B10G10R10_UNORM_PACK32       VK_COLOR_SPACE_BT709_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     37: VK_FORMAT_A2R10G10B10_UNORM_PACK32       VK_COLOR_SPACE_BT709_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     38: VK_FORMAT_B8G8R8A8_SRGB                  VK_COLOR_SPACE_BT709_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     39: VK_FORMAT_B8G8R8A8_UNORM                 VK_COLOR_SPACE_BT709_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     40: VK_FORMAT_R8G8B8A8_SRGB                  VK_COLOR_SPACE_BT709_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     41: VK_FORMAT_R8G8B8A8_UNORM                 VK_COLOR_SPACE_BT709_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     42: VK_FORMAT_R5G6B5_UNORM_PACK16            VK_COLOR_SPACE_BT709_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     43: VK_FORMAT_R16G16B16A16_UNORM             VK_COLOR_SPACE_BT709_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     44: VK_FORMAT_R16G16B16A16_SFLOAT            VK_COLOR_SPACE_BT709_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     45: VK_FORMAT_A2B10G10R10_UNORM_PACK32       VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     46: VK_FORMAT_A2R10G10B10_UNORM_PACK32       VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     47: VK_FORMAT_B8G8R8A8_SRGB                  VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     48: VK_FORMAT_B8G8R8A8_UNORM                 VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     49: VK_FORMAT_R8G8B8A8_SRGB                  VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     50: VK_FORMAT_R8G8B8A8_UNORM                 VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     51: VK_FORMAT_R5G6B5_UNORM_PACK16            VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     52: VK_FORMAT_R16G16B16A16_UNORM             VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     53: VK_FORMAT_R16G16B16A16_SFLOAT            VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     54: VK_FORMAT_A2B10G10R10_UNORM_PACK32       VK_COLOR_SPACE_BT2020_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     55: VK_FORMAT_A2R10G10B10_UNORM_PACK32       VK_COLOR_SPACE_BT2020_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     56: VK_FORMAT_B8G8R8A8_SRGB                  VK_COLOR_SPACE_BT2020_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     57: VK_FORMAT_B8G8R8A8_UNORM                 VK_COLOR_SPACE_BT2020_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     58: VK_FORMAT_R8G8B8A8_SRGB                  VK_COLOR_SPACE_BT2020_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     59: VK_FORMAT_R8G8B8A8_UNORM                 VK_COLOR_SPACE_BT2020_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     60: VK_FORMAT_R5G6B5_UNORM_PACK16            VK_COLOR_SPACE_BT2020_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     61: VK_FORMAT_R16G16B16A16_UNORM             VK_COLOR_SPACE_BT2020_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     62: VK_FORMAT_R16G16B16A16_SFLOAT            VK_COLOR_SPACE_BT2020_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     63: VK_FORMAT_A2B10G10R10_UNORM_PACK32       VK_COLOR_SPACE_HDR10_ST2084_EXT
[Vulkan Renderer @ 0x55651f27d200]     64: VK_FORMAT_A2R10G10B10_UNORM_PACK32       VK_COLOR_SPACE_HDR10_ST2084_EXT
[Vulkan Renderer @ 0x55651f27d200]     65: VK_FORMAT_B8G8R8A8_SRGB                  VK_COLOR_SPACE_HDR10_ST2084_EXT
[Vulkan Renderer @ 0x55651f27d200]     66: VK_FORMAT_B8G8R8A8_UNORM                 VK_COLOR_SPACE_HDR10_ST2084_EXT
[Vulkan Renderer @ 0x55651f27d200]     67: VK_FORMAT_R8G8B8A8_SRGB                  VK_COLOR_SPACE_HDR10_ST2084_EXT
[Vulkan Renderer @ 0x55651f27d200]     68: VK_FORMAT_R8G8B8A8_UNORM                 VK_COLOR_SPACE_HDR10_ST2084_EXT
[Vulkan Renderer @ 0x55651f27d200]     69: VK_FORMAT_R5G6B5_UNORM_PACK16            VK_COLOR_SPACE_HDR10_ST2084_EXT
[Vulkan Renderer @ 0x55651f27d200]     70: VK_FORMAT_R16G16B16A16_UNORM             VK_COLOR_SPACE_HDR10_ST2084_EXT
[Vulkan Renderer @ 0x55651f27d200]     71: VK_FORMAT_R16G16B16A16_SFLOAT            VK_COLOR_SPACE_HDR10_ST2084_EXT
[Vulkan Renderer @ 0x55651f27d200]     72: VK_FORMAT_A2B10G10R10_UNORM_PACK32       VK_COLOR_SPACE_ADOBERGB_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     73: VK_FORMAT_A2R10G10B10_UNORM_PACK32       VK_COLOR_SPACE_ADOBERGB_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     74: VK_FORMAT_B8G8R8A8_SRGB                  VK_COLOR_SPACE_ADOBERGB_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     75: VK_FORMAT_B8G8R8A8_UNORM                 VK_COLOR_SPACE_ADOBERGB_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     76: VK_FORMAT_R8G8B8A8_SRGB                  VK_COLOR_SPACE_ADOBERGB_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     77: VK_FORMAT_R8G8B8A8_UNORM                 VK_COLOR_SPACE_ADOBERGB_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     78: VK_FORMAT_R5G6B5_UNORM_PACK16            VK_COLOR_SPACE_ADOBERGB_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     79: VK_FORMAT_R16G16B16A16_UNORM             VK_COLOR_SPACE_ADOBERGB_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200]     80: VK_FORMAT_R16G16B16A16_SFLOAT            VK_COLOR_SPACE_ADOBERGB_LINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200] Picked surface configuration 0: VK_FORMAT_A2B10G10R10_UNORM_PACK32 + VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'https://test-videos.co.uk/vids/bigbuckbunny/mp4/h264/1080/Big_Buck_Bunny_1080_10s_1MB.mp4':
  Metadata:
    major_brand     : isom
    minor_version   : 512
    compatible_brands: isomiso2avc1mp41
  Duration: 00:00:10.00, start: 0.000000, bitrate: 837 kb/s
  Stream #0:0[0x1](und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(progressive), 1920x1080 [SAR 1:1 DAR 16:9], 832 kb/s, 60 fps, 60 tbr, 15360 tbn (default)
    Metadata:
      handler_name    : VideoHandler
[Vulkan Renderer @ 0x55651f27d200] Picked surface configuration 45: VK_FORMAT_A2B10G10R10_UNORM_PACK32 + VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55651f27d200] Spent 121.048 ms translating SPIR-V (slow!)
ffplay already does the scaling automatically, is it really necessary to pass -x / -y?
Have you tried without the constrained scale?
Works: ffplay https://test-videos.co.uk/vids/bigbuckbunny/mp4/h264/1080/Big_Buck_Bunny_1080_10s_1MB.mp4
Segmentation error: ffplay -hwaccel vulkan https://test-videos.co.uk/vids/bigbuckbunny/mp4/h264/1080/Big_Buck_Bunny_1080_10s_1MB.mp4
I suspect a bug. This is the baktrace on mine with the same ffmpeg 9.01
0x00007fffc0beb476 in vk_common_QueueSubmit2 (_queue=0x0, submitCount=1, pSubmits=0x7fffffff9d60,
    _fence=0x0) at ../mesa-26.2.1/src/vulkan/runtime/vk_queue.c:1284
1284	   if (vk_device_is_lost(queue->base.device))
(gdb) bt
#0  0x00007fffc0beb476 in vk_common_QueueSubmit2
    (_queue=0x0, submitCount=1, pSubmits=0x7fffffff9d60, _fence=0x0)
#1  0x00007ffff5786444 in vk_queue_submit2 (vk=0x555555718170, queue=0x0, info2=0x7fffffff9d60, fence=0x0)
    at ../src/vulkan/command.c:437
#2  vk_cmd_submit (pcmd=pcmd@entry=0x5555557b4400) at ../src/vulkan/command.c:531
#3  0x00007ffff578a75d in _end_cmd (gpu=0x5555557b4190, pcmd=<optimized out>, submit=true)
    at ../src/vulkan/gpu.c:232
#4  0x00007ffff579e1c4 in vk_pass_run (gpu=0x5555557b4190, params=<optimized out>)
    at ../src/vulkan/gpu_pass.c:966
#5  0x00007ffff57688fa in pl_pass_run (gpu=0x5555557b4190, params=<optimized out>) at ../src/gpu.c:1257
#6  0x00007ffff5756938 in run_pass
    (dp=dp@entry=0x5555558b8720, pass=pass@entry=0x555556382be0, sh=0x5555557aea00)
    at ../src/dispatch.c:1149
#7  0x00007ffff5757cd4 in pl_dispatch_finish (dp=<optimized out>, params=<optimized out>)
    at ../src/dispatch.c:1355
#8  0x00007ffff56f629e in _img_tex
    (pass=0x7fffffffb410, img=0x7fffffffafe0, tag=0x7ffff57a124b "src/renderer.c:1689")
    at src/renderer.c:524
#9  _img_tex
    (pass=pass@entry=0x7fffffffb410, img=img@entry=0x7fffffffafe0, tag=tag@entry=0x7ffff57a124b "src/renderer.c:1689") at src/renderer.c:504
#10 0x00007ffff56fa2c1 in pass_read_image (pass=pass@entry=0x7fffffffb410) at src/renderer.c:1689
#11 0x00007ffff5702f25 in pl_render_image
But we have different hardware so it’s not indicative. Nonetheless, it’s a bug most certainly.
You should do a backtrace yourself and submit it to ffmpeg, or at least ask about.
ffplay without the -x/-y parameters defaults to whatever the host screen dimensions happen to be. For testing, running it at -x 900 -y 1600 is more convenient (on my 1920x1800 screen). Perhaps the OP prefers some finer control.
@polilla
Just musing a little (extra parameters follow the URL):
ffplay https://test-videos.co.uk/vids/bigbuckbunny/mp4/h264/1080/Big_Buck_Bunny_1080_10s_1MB.mp4 -x 1600 -y 900 -hwaccel vulkan
This results in:
Failed to create window: Installed Vulkan doesn't implement the VK_KHR_surface extension
Note that I’m currently running it in a Manjaro WSL instance; the message might be meaningless with respect Manjaro on metal.
Edit:- I’m using an RX 580, similar to the RX 480 that @Yochanan mentions below – neither apparently support certain extensions.
Otherwise (without the -hwaccel parameter) it works as expected, just as you mentioned:
Is vulkan installed properly and updated?
I don’t know where is the problem.
ffmpeg/ffplay or graphics driver or something other.
As i said there is no problem with ffmpeg 9.0.0 or 9.0.1 under Windows 11 Pro.
Is vulkan installed?
I think so. I changed nothing of this part. Only updated to [Stable Update] 2026-08-12 and later to [Stable Update] 2026-08-23
Precisely.
Of course
Isn’t it automatically installed with mesa / radv on a AMD graphics?
Neither my machine nor his support Vulkan accel, but it shouldn’t crash I think. It should exit with the specific error
You can run vkcube in terminal to check your vulkan status but most likely is installed.
Mod edit:- Please avoid consecutive posts. Remedied. No charge.
Linux AMD Vulkan->Y
Y Fully usable.
vkcube in terminal works perfectly.
Sure, but on AMD it was implemented from the 6000(RDNA 2) series onward I believe
It works before. I don’t think they dropped vulkan-support for the AMD 5000-series.
Try this :
RADV_PERFTEST=video_decode mpv --gpu-api=vulkan --hwdec=vulkan https://test-videos.co.uk/vids/bigbuckbunny/mp4/h264/1080/Big_Buck_Bunny_1080_10s_1MB.mp4
you must have mpv installed
That’s an older card and doesn’t seem to support newer Vulkan extensions.
I have a similar issue on my RX 480. In my case my card doesn’t support Vulkan H264 hardware acceleration. I had to use the old VA-API encoder for Sunshine.
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: Dell driver: amdgpu v: kernel
    arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
    gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-3
    empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0a:00.0 chip-ID: 1002:67df
    class-ID: 0300 temp: 44.0 C
$ ffplay -hwaccel vulkan -x 1200 -y 900 https://test-videos.co.uk/vids/bigbuckbunny/mp4/h264/1080/Big_Buck_Bunny_1080_10s_1MB.mp4
[Vulkan Renderer @ 0x55c4268ea2c0] Initialized libplacebo v7.360.1 (API v360)
[Vulkan @ 0x55c4268b8380] device extension "VK_EXT_image_drm_format_modifier" not found, excluding.
[Vulkan @ 0x55c4268b8380] device extension "VK_KHR_portability_subset" not found, excluding.
[Vulkan @ 0x55c4268b8380] device extension "VK_EXT_host_image_copy" not found, excluding.
[Vulkan Renderer @ 0x55c4268ea2c0] Imported vulkan device properties:
[Vulkan Renderer @ 0x55c4268ea2c0]     Device Name: AMD Radeon RX 480 Graphics (RADV POLARIS10)
[Vulkan Renderer @ 0x55c4268ea2c0]     Device ID: 1002:67df
[Vulkan Renderer @ 0x55c4268ea2c0]     Device UUID: 00:00:00:00:0A:00:00:00:00:00:00:00:00:00:00:00
[Vulkan Renderer @ 0x55c4268ea2c0]     Driver version: 6802001
[Vulkan Renderer @ 0x55c4268ea2c0]     API version: 1.4.354
[Vulkan Renderer @ 0x55c4268ea2c0] Memory heaps supported by device:
[Vulkan Renderer @ 0x55c4268ea2c0]     0: flags 0x1 size 7936M
[Vulkan Renderer @ 0x55c4268ea2c0]     1: flags 0x0 size   31G
[Vulkan Renderer @ 0x55c4268ea2c0]     2: flags 0x1 size  256M
[Vulkan Renderer @ 0x55c4268ea2c0] Memory summary:     0 used     0 res     0 alloc, efficiency 100.00%, utilization 100.00%, max page:  496M
[Vulkan Renderer @ 0x55c4268ea2c0] shaderc SPIR-V version 1.6 rev 1
[Vulkan Renderer @ 0x55c4268ea2c0] Initialized SPIR-V compiler 'shaderc'
[Vulkan Renderer @ 0x55c4268ea2c0] GPU information:
[Vulkan Renderer @ 0x55c4268ea2c0]     GLSL version: 450 (vulkan)
[Vulkan Renderer @ 0x55c4268ea2c0]       max_shmem_size:            65536
[Vulkan Renderer @ 0x55c4268ea2c0]       max_group_threads:         1024
[Vulkan Renderer @ 0x55c4268ea2c0]       max_group_size[0]:         1024
[Vulkan Renderer @ 0x55c4268ea2c0]       max_group_size[1]:         1024
[Vulkan Renderer @ 0x55c4268ea2c0]       max_group_size[2]:         1024
[Vulkan Renderer @ 0x55c4268ea2c0]       subgroup_size:             64
[Vulkan Renderer @ 0x55c4268ea2c0]       min_gather_offset:         -32
[Vulkan Renderer @ 0x55c4268ea2c0]       max_gather_offset:         31
[Vulkan Renderer @ 0x55c4268ea2c0]     Limits:
[Vulkan Renderer @ 0x55c4268ea2c0]       thread_safe:               1
[Vulkan Renderer @ 0x55c4268ea2c0]       callbacks:                 1
[Vulkan Renderer @ 0x55c4268ea2c0]       max_buf_size:              33669124096
[Vulkan Renderer @ 0x55c4268ea2c0]       max_ubo_size:              4294967295
[Vulkan Renderer @ 0x55c4268ea2c0]       max_ssbo_size:             4294967295
[Vulkan Renderer @ 0x55c4268ea2c0]       max_vbo_size:              8321499136
[Vulkan Renderer @ 0x55c4268ea2c0]       max_mapped_size:           33669124096
[Vulkan Renderer @ 0x55c4268ea2c0]       max_buffer_texels:         536870912
[Vulkan Renderer @ 0x55c4268ea2c0]       align_host_ptr:            4096
[Vulkan Renderer @ 0x55c4268ea2c0]       host_cached:               1
[Vulkan Renderer @ 0x55c4268ea2c0]       max_tex_1d_dim:            16384
[Vulkan Renderer @ 0x55c4268ea2c0]       max_tex_2d_dim:            16384
[Vulkan Renderer @ 0x55c4268ea2c0]       max_tex_3d_dim:            2048
[Vulkan Renderer @ 0x55c4268ea2c0]       blittable_1d_3d:           1
[Vulkan Renderer @ 0x55c4268ea2c0]       buf_transfer:              1
[Vulkan Renderer @ 0x55c4268ea2c0]       align_tex_xfer_pitch:      1
[Vulkan Renderer @ 0x55c4268ea2c0]       align_tex_xfer_offset:     4
[Vulkan Renderer @ 0x55c4268ea2c0]       max_variable_comps:        0
[Vulkan Renderer @ 0x55c4268ea2c0]       max_constants:             18446744073709551615
[Vulkan Renderer @ 0x55c4268ea2c0]       max_pushc_size:            256
[Vulkan Renderer @ 0x55c4268ea2c0]       align_vertex_stride:       1
[Vulkan Renderer @ 0x55c4268ea2c0]       max_dispatch[0]:           4294967295
[Vulkan Renderer @ 0x55c4268ea2c0]       max_dispatch[1]:           65535
[Vulkan Renderer @ 0x55c4268ea2c0]       max_dispatch[2]:           65535
[Vulkan Renderer @ 0x55c4268ea2c0]       fragment_queues:           1
[Vulkan Renderer @ 0x55c4268ea2c0]       compute_queues:            4
[Vulkan Renderer @ 0x55c4268ea2c0]     External API interop:
[Vulkan Renderer @ 0x55c4268ea2c0]       UUID: 00:00:00:00:0A:00:00:00:00:00:00:00:00:00:00:00
[Vulkan Renderer @ 0x55c4268ea2c0]       PCI: 0000:0a:00:0
[Vulkan Renderer @ 0x55c4268ea2c0]       buf export caps: 0x9
[Vulkan Renderer @ 0x55c4268ea2c0]       buf import caps: 0x19
[Vulkan Renderer @ 0x55c4268ea2c0]       tex export caps: 0x1
[Vulkan Renderer @ 0x55c4268ea2c0]       tex import caps: 0x11
[Vulkan Renderer @ 0x55c4268ea2c0]       sync export caps: 0x1
[Vulkan Renderer @ 0x55c4268ea2c0]       sync import caps: 0x0
[Vulkan Renderer @ 0x55c4268ea2c0] Available surface configurations:
[Vulkan Renderer @ 0x55c4268ea2c0]     0: VK_FORMAT_R16G16B16A16_SFLOAT            VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
[Vulkan Renderer @ 0x55c4268ea2c0]     1: VK_FORMAT_R16G16B16A16_UNORM             VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
[Vulkan Renderer @ 0x55c4268ea2c0]     2: VK_FORMAT_A2R10G10B10_UNORM_PACK32       VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
[Vulkan Renderer @ 0x55c4268ea2c0]     3: VK_FORMAT_A2B10G10R10_UNORM_PACK32       VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
[Vulkan Renderer @ 0x55c4268ea2c0]     4: VK_FORMAT_B8G8R8A8_SRGB                  VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
[Vulkan Renderer @ 0x55c4268ea2c0]     5: VK_FORMAT_B8G8R8A8_UNORM                 VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
[Vulkan Renderer @ 0x55c4268ea2c0]     6: VK_FORMAT_R8G8B8A8_SRGB                  VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
[Vulkan Renderer @ 0x55c4268ea2c0]     7: VK_FORMAT_R8G8B8A8_UNORM                 VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
[Vulkan Renderer @ 0x55c4268ea2c0]     8: VK_FORMAT_R5G6B5_UNORM_PACK16            VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
[Vulkan Renderer @ 0x55c4268ea2c0]     9: VK_FORMAT_R16G16B16A16_SFLOAT            VK_COLOR_SPACE_PASS_THROUGH_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     10: VK_FORMAT_R16G16B16A16_UNORM             VK_COLOR_SPACE_PASS_THROUGH_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     11: VK_FORMAT_A2R10G10B10_UNORM_PACK32       VK_COLOR_SPACE_PASS_THROUGH_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     12: VK_FORMAT_A2B10G10R10_UNORM_PACK32       VK_COLOR_SPACE_PASS_THROUGH_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     13: VK_FORMAT_B8G8R8A8_SRGB                  VK_COLOR_SPACE_PASS_THROUGH_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     14: VK_FORMAT_B8G8R8A8_UNORM                 VK_COLOR_SPACE_PASS_THROUGH_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     15: VK_FORMAT_R8G8B8A8_SRGB                  VK_COLOR_SPACE_PASS_THROUGH_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     16: VK_FORMAT_R8G8B8A8_UNORM                 VK_COLOR_SPACE_PASS_THROUGH_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     17: VK_FORMAT_R5G6B5_UNORM_PACK16            VK_COLOR_SPACE_PASS_THROUGH_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     18: VK_FORMAT_R16G16B16A16_SFLOAT            VK_COLOR_SPACE_DISPLAY_P3_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     19: VK_FORMAT_R16G16B16A16_UNORM             VK_COLOR_SPACE_DISPLAY_P3_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     20: VK_FORMAT_A2R10G10B10_UNORM_PACK32       VK_COLOR_SPACE_DISPLAY_P3_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     21: VK_FORMAT_A2B10G10R10_UNORM_PACK32       VK_COLOR_SPACE_DISPLAY_P3_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     22: VK_FORMAT_B8G8R8A8_SRGB                  VK_COLOR_SPACE_DISPLAY_P3_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     23: VK_FORMAT_B8G8R8A8_UNORM                 VK_COLOR_SPACE_DISPLAY_P3_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     24: VK_FORMAT_R8G8B8A8_SRGB                  VK_COLOR_SPACE_DISPLAY_P3_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     25: VK_FORMAT_R8G8B8A8_UNORM                 VK_COLOR_SPACE_DISPLAY_P3_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     26: VK_FORMAT_R5G6B5_UNORM_PACK16            VK_COLOR_SPACE_DISPLAY_P3_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     27: VK_FORMAT_R16G16B16A16_SFLOAT            VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     28: VK_FORMAT_R16G16B16A16_UNORM             VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     29: VK_FORMAT_A2R10G10B10_UNORM_PACK32       VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     30: VK_FORMAT_A2B10G10R10_UNORM_PACK32       VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     31: VK_FORMAT_B8G8R8A8_SRGB                  VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     32: VK_FORMAT_B8G8R8A8_UNORM                 VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     33: VK_FORMAT_R8G8B8A8_SRGB                  VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     34: VK_FORMAT_R8G8B8A8_UNORM                 VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     35: VK_FORMAT_R5G6B5_UNORM_PACK16            VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     36: VK_FORMAT_R16G16B16A16_SFLOAT            VK_COLOR_SPACE_BT709_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     37: VK_FORMAT_R16G16B16A16_UNORM             VK_COLOR_SPACE_BT709_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     38: VK_FORMAT_A2R10G10B10_UNORM_PACK32       VK_COLOR_SPACE_BT709_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     39: VK_FORMAT_A2B10G10R10_UNORM_PACK32       VK_COLOR_SPACE_BT709_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     40: VK_FORMAT_B8G8R8A8_SRGB                  VK_COLOR_SPACE_BT709_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     41: VK_FORMAT_B8G8R8A8_UNORM                 VK_COLOR_SPACE_BT709_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     42: VK_FORMAT_R8G8B8A8_SRGB                  VK_COLOR_SPACE_BT709_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     43: VK_FORMAT_R8G8B8A8_UNORM                 VK_COLOR_SPACE_BT709_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     44: VK_FORMAT_R5G6B5_UNORM_PACK16            VK_COLOR_SPACE_BT709_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     45: VK_FORMAT_R16G16B16A16_SFLOAT            VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     46: VK_FORMAT_R16G16B16A16_UNORM             VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     47: VK_FORMAT_A2R10G10B10_UNORM_PACK32       VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     48: VK_FORMAT_A2B10G10R10_UNORM_PACK32       VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     49: VK_FORMAT_B8G8R8A8_SRGB                  VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     50: VK_FORMAT_B8G8R8A8_UNORM                 VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     51: VK_FORMAT_R8G8B8A8_SRGB                  VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     52: VK_FORMAT_R8G8B8A8_UNORM                 VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     53: VK_FORMAT_R5G6B5_UNORM_PACK16            VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     54: VK_FORMAT_R16G16B16A16_SFLOAT            VK_COLOR_SPACE_BT2020_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     55: VK_FORMAT_R16G16B16A16_UNORM             VK_COLOR_SPACE_BT2020_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     56: VK_FORMAT_A2R10G10B10_UNORM_PACK32       VK_COLOR_SPACE_BT2020_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     57: VK_FORMAT_A2B10G10R10_UNORM_PACK32       VK_COLOR_SPACE_BT2020_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     58: VK_FORMAT_B8G8R8A8_SRGB                  VK_COLOR_SPACE_BT2020_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     59: VK_FORMAT_B8G8R8A8_UNORM                 VK_COLOR_SPACE_BT2020_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     60: VK_FORMAT_R8G8B8A8_SRGB                  VK_COLOR_SPACE_BT2020_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     61: VK_FORMAT_R8G8B8A8_UNORM                 VK_COLOR_SPACE_BT2020_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     62: VK_FORMAT_R5G6B5_UNORM_PACK16            VK_COLOR_SPACE_BT2020_LINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     63: VK_FORMAT_R16G16B16A16_SFLOAT            VK_COLOR_SPACE_HDR10_ST2084_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     64: VK_FORMAT_R16G16B16A16_UNORM             VK_COLOR_SPACE_HDR10_ST2084_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     65: VK_FORMAT_A2R10G10B10_UNORM_PACK32       VK_COLOR_SPACE_HDR10_ST2084_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     66: VK_FORMAT_A2B10G10R10_UNORM_PACK32       VK_COLOR_SPACE_HDR10_ST2084_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     67: VK_FORMAT_B8G8R8A8_SRGB                  VK_COLOR_SPACE_HDR10_ST2084_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     68: VK_FORMAT_B8G8R8A8_UNORM                 VK_COLOR_SPACE_HDR10_ST2084_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     69: VK_FORMAT_R8G8B8A8_SRGB                  VK_COLOR_SPACE_HDR10_ST2084_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     70: VK_FORMAT_R8G8B8A8_UNORM                 VK_COLOR_SPACE_HDR10_ST2084_EXT
[Vulkan Renderer @ 0x55c4268ea2c0]     71: VK_FORMAT_R5G6B5_UNORM_PACK16            VK_COLOR_SPACE_HDR10_ST2084_EXT
[Vulkan Renderer @ 0x55c4268ea2c0] Picked surface configuration 3: VK_FORMAT_A2B10G10R10_UNORM_PACK32 + VK_COLOR_SPACE_SRGB_NONLINEAR_KHR
  Metadata:
    major_brand     : isom
    minor_version   : 512
    Metadata:
[h264 @ 0x7f3830761c80] Device does not support the VK_KHR_video_decode_queue extension!
[h264 @ 0x7f3830761c80] Failed setup for format vulkan: hwaccel initialisation returned error.
[Vulkan Renderer @ 0x55c4268ea2c0] Picked surface configuration 48: VK_FORMAT_A2B10G10R10_UNORM_PACK32 + VK_COLOR_SPACE_BT709_NONLINEAR_EXT
[Vulkan Renderer @ 0x55c4268ea2c0] Spent 131.069 ms translating SPIR-V (slow!)
Segmentation fault         (core dumped) ffplay -hwaccel vulkaA
mpv is installed and your RADV_PERFTEST works also without any problem.
As @Yochanan pointed out, our GPU’s doesn’t seem to support the newest Vulkan extensions.
I suppose you could add these settings to mpv conf and bashrc to use them automatically with mpv instead of ffplay
Thank you for your help libertypo.
From now i know with Yochanan’s post it’s entered at the Manjaro-Team.
