Few issues post latest update
Earlier this week I did my normal system update and I’ve noticed some issues, mostly minor/inconsequential but some more inconvenient. Here’s my current kernel:
Currently running: 5.15.177-1-MANJARO (linux515)
   * linux510
   * linux515
When I try to update packages or do a system update now I get an error about stopping at file system boundary and it exits any update, system or individual package:
AUR Explicit (2): skypeforlinux-bin-8.136.0.203-1, google-chrome-133.0.6943.53-1
Sync Explicit (1): firefox-135.0-1
:: (0/2) Failed to download PKGBUILD: google-chrome
:: (1/2) Downloaded PKGBUILD: skypeforlinux-bin
 -> error fetching google-chrome: fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
	 context: exit status 128
I no longer can open Anki, which I use pretty frequently for a variety of things and I consider to be a critical piece of software, and trying to update it lead to the same as above (and wouldn’t have done anything as far as I can tell because I have the most recent version from AUR installed)
The less consequential gripes are more settings that I’m unaware of how to change. My computer now goes into a sort of power sleep after 10-15 minutes which I’d rather turn off, and I use 4 workspaces and despite having my wallpaper/desktop background settings set to be the same for all the workspaces they are only applied to my first workspace. How can I adjust these two things?
Hi, have you tried later LTS Kernels 6.1, 6.6, 6.12?
A bit of system info would help:
inxi -zv8
Also, is your AUR database up-to-date?
Cheers!
Have not tried the LTS Kernels, I’ll have to look into switching to them
  Kernel: 5.15.177-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=daac5ac1-4bfb-4410-8c88-c3aaa96daa44 rw quiet apparmor=1
    security=apparmor resume=UUID=59e46e3f-87f7-49db-bdef-37314e2ccca9
    udev.log_priority=3
  Desktop: Xfce v: 4.20.0 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.20.0
    with: plank,xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
  Type: Desktop Mobo: Micro-Star model: B450 GAMING PRO CARBON AC (MS-7B85)
    v: 1.0 serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: 1.F4 date: 04/22/2021
  System RAM: total: 16 GiB available: 15.55 GiB used: 3.52 GiB (22.6%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-3200C16-8GVKB serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
  Topology: cpus: 1x dies: 1 cores: 6 threads: 12 tpc: 2 smt: enabled cache:
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 2298 min/max: 2200/4208 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2298 2: 2298 3: 2298
    4: 2298 5: 2298 6: 2298 7: 2298 8: 2298 9: 2298 10: 2298 11: 2298 12: 2298
    bogomips: 86435
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
    sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean
    vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spec_rstack_overflow mitigation: safe RET
    prctl and seccomp
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: Micro-Star MSI
    driver: nouveau v: kernel non-free: 550/565.xx+ status: current (as of
    2025-01; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
    built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s ports: active: DP-3,HDMI-A-1 empty: DP-1,DP-2
    bus-ID: 26:00.0 chip-ID: 10de:1f06 class-ID: 0300 temp: 24.0 C
  Device-2: Microdia Webcam Vitade AF driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.4:6
    chip-ID: 0c45:6366 class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.15 compositor: xfwm4 v: 4.20.0 driver:
    X: loaded: modesetting alternate: fbdev,vesa dri: nouveau gpu: nouveau
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1186x382mm (46.69x15.04")
    s-diag: 1246mm (49.06")
  Monitor-1: DP-3 pos: right model: HP Z27n G2 serial: <filter> built: 2019
    res: mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 109 gamma: 1.2 chroma: red:
    x: 0.663 y: 0.329 green: x: 0.302 y: 0.620 blue: x: 0.145 y: 0.047 white:
    x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27")
    ratio: 16:9 modes: 2560x1440, 1920x1200, 1920x1080, 1680x1050, 1600x900,
    1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480, 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI-1 pos: primary,left model: Acer V246HYL
    serial: <filter> built: 2020 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 93 gamma: 1.2 chroma: red: x: 0.651 y: 0.337 green: x: 0.322 y: 0.616
    blue: x: 0.153 y: 0.059 white: x: 0.314 y: 0.329
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1152x864,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Info: Tools: de: xfce4-display-settings x11: xdpyinfo, xprop, xrandr
  Device-1: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 26:00.1 chip-ID: 10de:10f9
    class-ID: 0403
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Focusrite-Novation Scarlett Solo 4th Gen driver: snd-usb-audio
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
    chip-ID: 1235:8218 class-ID: 0102 serial: <filter>
  Device-4: Microdia Webcam Vitade AF driver: snd-usb-audio,uvcvideo
  API: ALSA v: k5.15.177-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: off tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with:
    tools: pacat,pactl,pavucontrol
  Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 21:00.0
    chip-ID: 8086:2526 class-ID: 0280
  Device-2: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 22:00.0
  IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
  Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4:5
    chip-ID: 8087:0025 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 1.36 TiB used: 130.15 GiB (9.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 33.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: PSSD T7
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
    scheme: MBR
  ID-1: / raw-size: 40 GiB size: 39.08 GiB (97.69%) used: 36.47 GiB (93.3%)
    fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: daac5ac1-4bfb-4410-8c88-c3aaa96daa44
    used: 25.6 MiB (26.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: 1475-16ED
  ID-3: /home raw-size: 221.67 GiB size: 217.13 GiB (97.95%)
    used: 93.65 GiB (43.1%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
    label: N/A uuid: c4605162-72ba-4c54-b550-03ec030625f0
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
  ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
    uuid: 59e46e3f-87f7-49db-bdef-37314e2ccca9
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 201.48 GiB fs: ntfs label: N/A
    uuid: F02475C8247591F8
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 509 MiB fs: ntfs label: N/A
    uuid: B06682E46682AB24
  ID-4: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: exfat label: T7
    uuid: 280A-8AE8
  Device-1: 1-2:2 info: Focusrite-Novation Scarlett Solo 4th Gen type: audio
    driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 1235:8218 class-ID: 0102 serial: <filter>
  Device-2: 1-3:3 info: Samsung PSSD T7 type: mass storage driver: uas
    interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 04e8:4001 class-ID: 0806 serial: <filter>
  Device-3: 1-8:4 info: Logitech G9x Laser Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c066 class-ID: 0300
    serial: <filter>
  Device-4: 1-9:5 info: LazyDesigners THE50 type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: feed:0050 class-ID: 0300
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 5-1:2 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2813
  Device-1: 5-1.4:6 info: Microdia Webcam Vitade AF type: video,audio
  Device-2: 5-3:3 info: Micro Star PRO CARBON type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7b85 class-ID: 0300
    serial: <filter>
  Device-3: 5-4:5 info: Intel Wireless-AC 9260 Bluetooth Adapter
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Hub-7: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-8: 6-1:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0813
  System Temperatures: cpu: 52.2 C mobo: N/A gpu: nouveau temp: 24.0 C
  Fan Speeds (rpm): N/A gpu: nouveau fan: 839
  Packages: pm: pacman pkgs: 1556 libs: 465 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://manjaro.kurdy.org/stable/$repo/$arch
    3: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    4: http://manjaro.grena.ge/stable/$repo/$arch
    5: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    6: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    7: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    8: https://mirror.koddos.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 340
  1: cpu: 14.9% command: [kworker/u64:8-events_power_efficient] pid: 208
    mem: 0.00 MiB (0.0%)
  2: cpu: 12.0% command: [kworker/u64:10-events_unbound] pid: 210
  3: cpu: 11.2% command: firefox pid: 2573 mem: 652.5 MiB (4.0%)
  4: cpu: 9.6% command: [kworker/u64:9-events_unbound] pid: 209
  5: cpu: 8.3% command: firefox pid: 4741 mem: 310.4 MiB (1.9%)
  Memory top: 5 of 340
  1: mem: 652.5 MiB (4.0%) command: firefox pid: 2573 cpu: 11.2%
  2: mem: 355.1 MiB (2.2%) command: soffice.bin pid: 5597 cpu: 0.6%
  3: mem: 350.9 MiB (2.2%) command: firefox pid: 2947 cpu: 2.2%
  4: mem: 310.4 MiB (1.9%) command: firefox pid: 4741 cpu: 8.3%
  5: mem: 307.3 MiB (1.9%) command: firefox pid: 2653 cpu: 1.6%
  Processes: 340 Power: uptime: 34m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.21 GiB services: upowerd,xfce4-power-manager
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
    running-in: xfce4-terminal inxi: 3.3.37
As it’s a much newer system than mine, I would think the current LTS ones should be fine. I seem to recall having issues with the 5x series, which is why I abandoned them.
Note I’d have more than 2G swap, though. I guess you don’t use the Hibernate functionality but it may be beneficial anyway. Probably 8G w/o Hibernate or 18G if you do intend to use it.
Switched over to linux6.1 but it didn’t change anything. Still unable to update packages, still unable to open Anki, and the wallpaper behavior is unchaged. Unsure about the hibernate behavior but I’m assuming it’s similar based on everything else
Worth trying the others, but re. the AUR database:
pamac update --aur --force-refresh
… might help. :wink:
hm that failed due to file size, and it looks like my root partition is full.
Filesystem      Size  Used Avail Use% Mounted on
dev             7.8G     0  7.8G   0% /dev
run             7.8G  1.8M  7.8G   1% /run
/dev/nvme0n1p6   40G   37G  205M 100% /
tmpfs           7.8G     0  7.8G   0% /dev/shm
tmpfs           7.8G   69M  7.8G   1% /tmp
/dev/nvme0n1p7  218G   94G  113G  46% /home
/dev/nvme0n1p1   96M   26M   71M  27% /boot/efi
tmpfs           1.6G  120K  1.6G   1% /run/user/1000
I don’t think that’s causing the issue with Anki or the others, but it does look like I need to update my hard-drive partitioning. Is there a straightforward way to do this or a guide I can use to read up on the process? I’ve never done this before myself
What you could do is see how much stuff you can clear out of e.g. the Pacman cache:
du -h /var/cache/pacman/pkg/
It does accumulate, needs to be cleared periodically.
That seems to be returning the size of the cache, is that right? How can I see this size of the contents?
15G	/var/cache/pacman/pkg/
edit:nvm just did a simple ls -al
15G !! You can safely get rid of at least most of that. I believe
pamac clean
will do this (never used it; I do it via sudo rm-rf /var/cache/pacman/pkg/*).
Okay so I cleaned the cache with pacman -Sc (I normally use the yay wrapper so curious if I could’ve just done yay -Sc instead but less important right now)
Was able to do a standard update with yay -Syu afterwards and it failed due to what appears to be an issue with the Google Chrome AUR package if I’m understanding this right?
so excluding that package lead to the update completing as normal.
However this hasn’t addressed the Anki issue at all and I really would like to get that working. Should I start a thread specifically for that?
See here and here.
From the second link, does " Workspace support is missing (ext-workspace protocol was just merged)." imply that currently having multiple workspaces with the display settings transferring between them doesn’t work but will once an update is provided?
