After kde update and a reboot im getting this error after every command in terminal? Im not using git?
❰greg❙~❱✔≻ ls
bash Desktop Downloads git log.txt Music Public python shield-ftp.txt Templates Videos znotes
cherrytree Documents genral-backups konsave_log.txt mount Pictures PycharmProjects quickenx sounds testdir 'VirtualBox VMs' zulu
fatal: not a git repository (or any of the parent directories): .git
Well, I’ve never used fish but I’m guessing it’s probably to be found in its startup files. I don’t know what fish uses, but could it be something like .fishrc? It’ll either way be a hidden file right under your $HOME.
You could also check whether it uses a system-wide configuration file under /etc.
what i did exactly was open my fish terminal, type in fish_config This will open your browser showing a load of options, you need to change to the tab “Prompt”, select a prompt that you’re not currently using then hit “set prompt”. Check if your fish prompt has changed and more importantly check if the git error has gone, if it has try switching back to whatever prompt you want, hit “set prompt” again and should be good.
The browser setting that fish_config takes you to only works while your terminal is “connected” to it, once you exit out on your terminal you need to execute fish_config again to open a new browser config page as the old one will not change your setting any more even though it still is visible.
Well id say no on that as iv never used oh-my-fish and i had this error after the update too. It may be affecting your ability to fix the problem, but i think there is something going on with fish itself. Good luck with it.
