Manjaro sometimes fatally hangs up after wake from suspend, to the extent that even REISUB does not work.
I’ve had the issue for a while that my laptop doesn’t always sleep properly, so I’m currently using systemctl suspend to suspend before closing the lid. Regardless of whether I do that or get it to sleep by closing the lid, the laptop will hang up entirely some indefinite time after wake. I don’t see anything relevant in journalctl -b -1.
N.B. Please post the output of inxi -Fayz (use the </> button to format the pasted text, or precede and follow with three backticks ``` or tildes ~~~ on their own lines).
Hi, thanks for the quick response. I believe I’ve already had the issue with several different LTS kernels, but next time this happens, I’ll try booting in the previous LTS just to make sure.
Cheers! I’d suggest posting the logs here just in case we can spot something, next time it happens. I guess the last 150-200 lines should be enough (add | tail -150 to the jounalctl command, for example).
Just had a progressive system hang, meaning that different apps locked up one after the other. No capslock indicator blinking, and I was able to REISUB. Here’s my journalctl:
May 27 12:22:40 chomp NetworkManager[433]: <info> [1716805360.9827] manager: NetworkManager state is now CONNECTED_GLOBAL
May 27 12:22:41 chomp systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
May 27 12:22:41 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC= SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff05:0000:0000:0000:0000:0000:0000:0002 LEN=72 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=131 CODE=0
May 27 12:22:51 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=10.5.130.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=44961 PROTO=2
May 27 12:22:56 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:2c:b6:87:08:00 SRC=10.5.130.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=50408 PROTO=2
May 27 12:24:54 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=10.5.130.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=45055 PROTO=2
May 27 12:24:58 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:2c:b6:87:08:00 SRC=10.5.130.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=50499 PROTO=2
May 27 12:25:08 chomp rtkit-daemon[766]: Supervising 10 threads of 8 processes of 1 users.
May 27 12:25:34 chomp NetworkManager[433]: <info> [1716805534.7574] vpn[0x55aab6985e90,d0ec1e51-afe9-4821-86a6-84836257332c,"<redacted>"]: starting openconnect
May 27 12:25:34 chomp NetworkManager[433]: <info> [1716805534.7586] audit: op="connection-activate" uuid="d0ec1e51-afe9-4821-86a6-84836257332c" name="<redacted>" pid=840 uid=1000 result="success"
May 27 12:25:34 chomp kernel: tun: Universal TUN/TAP device driver, 1.6
May 27 12:25:36 chomp NetworkManager[433]: <warn> [1716805536.9087] vpn[0x55aab6985e90,d0ec1e51-afe9-4821-86a6-84836257332c,"<redacted>"]: final secrets request failed to provide sufficient secrets
May 27 12:25:42 chomp NetworkManager[433]: <info> [1716805542.9249] vpn[0x55aab6986300,7339df05-9980-480d-8ac6-d334f374b361,"<redacted>"]: starting openconnect
May 27 12:25:42 chomp NetworkManager[433]: <info> [1716805542.9259] audit: op="connection-activate" uuid="7339df05-9980-480d-8ac6-d334f374b361" name="<redacted>" pid=840 uid=1000 result="success"
May 27 12:25:51 chomp rtkit-daemon[766]: Supervising 10 threads of 8 processes of 1 users.
May 27 12:25:53 chomp gnome-keyring-daemon[670]: asked to register item /org/freedesktop/secrets/collection/login/80, but it's already registered
May 27 12:25:53 chomp gnome-keyring-d[670]: asked to register item /org/freedesktop/secrets/collection/login/80, but it's already registered
May 27 12:25:53 chomp gnome-keyring-daemon[670]: asked to register item /org/freedesktop/secrets/collection/login/81, but it's already registered
May 27 12:25:53 chomp gnome-keyring-d[670]: asked to register item /org/freedesktop/secrets/collection/login/81, but it's already registered
May 27 12:25:53 chomp NetworkManager[433]: <info> [1716805553.1468] manager: (vpn0): new Tun device (/org/freedesktop/NetworkManager/Devices/13)
May 27 12:25:53 chomp NetworkManager[49725]: Connected to 129.132.99.164:443
May 27 12:25:53 chomp NetworkManager[49725]: SSL negotiation with <redacted>
May 27 12:25:53 chomp NetworkManager[49725]: Server certificate verify failed: signer not found
May 27 12:25:53 chomp NetworkManager[49725]: Connected to HTTPS on <redacted> with ciphersuite (TLS1.2)-(ECDHE-X25519)-(RSA-SHA256)-(AES-256-GCM)
May 27 12:25:53 chomp NetworkManager[49725]: Got CONNECT response: HTTP/1.1 200 OK
May 27 12:25:53 chomp NetworkManager[49725]: CSTP connected. DPD 30, Keepalive 30
May 27 12:25:53 chomp NetworkManager[49725]: Established DTLS connection (using GnuTLS). Ciphersuite (DTLS1.2)-(ECDHE-RSA)-(AES-256-GCM).
May 27 12:25:53 chomp NetworkManager[49725]: Configured as 148.187.134.9 + 2001:620:808:1200:8000::16/115, with SSL connected and DTLS connected
May 27 12:25:53 chomp NetworkManager[49725]: Session authentication will expire at Sun Jun 2 12:25:52 2024
May 27 12:25:53 chomp avahi-daemon[434]: Joining mDNS multicast group on interface vpn0.IPv4 with address 148.187.134.9.
May 27 12:25:53 chomp avahi-daemon[434]: New relevant interface vpn0.IPv4 for mDNS.
May 27 12:25:53 chomp avahi-daemon[434]: Registering new address record for 148.187.134.9 on vpn0.IPv4.
May 27 12:25:53 chomp avahi-daemon[434]: Joining mDNS multicast group on interface vpn0.IPv6 with address 2001:620:808:1200:8000::16.
May 27 12:25:53 chomp avahi-daemon[434]: New relevant interface vpn0.IPv6 for mDNS.
May 27 12:25:53 chomp avahi-daemon[434]: Registering new address record for 2001:620:808:1200:8000::16 on vpn0.*.
May 27 12:25:53 chomp NetworkManager[433]: <info> [1716805553.2490] device (vpn0): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external')
May 27 12:25:53 chomp NetworkManager[433]: <info> [1716805553.2529] device (vpn0): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
May 27 12:25:53 chomp NetworkManager[433]: <info> [1716805553.2544] device (vpn0): Activation: starting connection 'vpn0' (0ac99f0f-e575-494d-8c6e-45a6019ed0f1)
May 27 12:25:53 chomp NetworkManager[433]: <info> [1716805553.2548] device (vpn0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
May 27 12:25:53 chomp NetworkManager[433]: <info> [1716805553.2552] device (vpn0): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
May 27 12:25:53 chomp NetworkManager[433]: <info> [1716805553.2560] device (vpn0): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
May 27 12:25:53 chomp NetworkManager[433]: <info> [1716805553.2570] device (vpn0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
May 27 12:25:53 chomp systemd[1]: Starting Network Manager Script Dispatcher Service...
May 27 12:25:53 chomp openconnect[49725]: Using vhost-net for tun acceleration, ring size 32
May 27 12:25:53 chomp systemd[1]: Started Network Manager Script Dispatcher Service.
May 27 12:25:53 chomp NetworkManager[433]: <info> [1716805553.2804] policy: set '<redacted>' (vpn0) as default for IPv4 routing and DNS
May 27 12:25:53 chomp NetworkManager[433]: <info> [1716805553.2805] policy: set '<redacted>' (vpn0) as default for IPv6 routing and DNS
May 27 12:25:53 chomp NetworkManager[433]: <info> [1716805553.2929] device (vpn0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
May 27 12:25:53 chomp NetworkManager[433]: <info> [1716805553.2931] device (vpn0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
May 27 12:25:53 chomp NetworkManager[433]: <info> [1716805553.2934] device (vpn0): Activation: successful, device activated.
May 27 12:25:58 chomp rtkit-daemon[766]: Supervising 10 threads of 8 processes of 1 users.
May 27 12:26:03 chomp systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
May 27 12:26:58 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=10.5.130.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=45146 PROTO=2
May 27 12:27:00 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:2c:b6:87:08:00 SRC=10.5.130.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=50590 PROTO=2
May 27 12:27:42 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=34.107.243.93 DST=10.5.131.170 LEN=76 TOS=0x00 PREC=0x60 TTL=119 ID=59241 PROTO=TCP SPT=443 DPT=48658 WINDOW=287 RES=0x00 ACK PSH URGP=0
May 27 12:27:42 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=34.107.243.93 DST=10.5.131.170 LEN=76 TOS=0x00 PREC=0x60 TTL=119 ID=59242 PROTO=TCP SPT=443 DPT=48658 WINDOW=287 RES=0x00 ACK PSH URGP=0
May 27 12:27:42 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=34.107.243.93 DST=10.5.131.170 LEN=76 TOS=0x00 PREC=0x60 TTL=119 ID=59243 PROTO=TCP SPT=443 DPT=48658 WINDOW=287 RES=0x00 ACK PSH URGP=0
May 27 12:27:42 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=34.107.243.93 DST=10.5.131.170 LEN=76 TOS=0x00 PREC=0x60 TTL=119 ID=59244 PROTO=TCP SPT=443 DPT=48658 WINDOW=287 RES=0x00 ACK PSH URGP=0
May 27 12:27:42 chomp wpa_supplicant[508]: wlp2s0: PMKSA-CACHE-ADDED 44:e9:68:a9:58:b2 0
May 27 12:27:42 chomp wpa_supplicant[508]: wlp2s0: PMKSA-CACHE-ADDED 44:e9:68:a9:5c:10 0
May 27 12:27:42 chomp wpa_supplicant[508]: wlp2s0: PMKSA-CACHE-ADDED 44:e9:68:a9:58:32 0
May 27 12:27:42 chomp wpa_supplicant[508]: wlp2s0: PMKSA-CACHE-ADDED 44:e9:68:a9:67:d0 0
May 27 12:27:42 chomp wpa_supplicant[508]: wlp2s0: PMKSA-CACHE-ADDED 44:e9:68:a9:2e:b2 0
May 27 12:27:42 chomp wpa_supplicant[508]: wlp2s0: PMKSA-CACHE-ADDED 44:e9:68:a9:67:b2 0
May 27 12:27:42 chomp wpa_supplicant[508]: wlp2s0: PMKSA-CACHE-ADDED 44:e9:68:a9:5f:72 0
May 27 12:27:42 chomp wpa_supplicant[508]: wlp2s0: PMKSA-CACHE-ADDED 44:e9:68:a9:4f:b2 0
May 27 12:27:42 chomp wpa_supplicant[508]: wlp2s0: PMKSA-CACHE-ADDED 44:e9:68:a9:67:32 0
May 27 12:27:42 chomp wpa_supplicant[508]: wlp2s0: PMKSA-CACHE-ADDED 44:e9:68:a9:5b:f2 0
May 27 12:27:42 chomp wpa_supplicant[508]: wlp2s0: PMKSA-CACHE-ADDED 44:e9:68:a9:5c:f2 0
May 27 12:27:42 chomp wpa_supplicant[508]: wlp2s0: PMKSA-CACHE-ADDED 44:e9:68:a9:5c:d0 0
May 27 12:27:42 chomp wpa_supplicant[508]: wlp2s0: PMKSA-CACHE-ADDED 44:e9:68:a9:4f:d0 0
May 27 12:27:42 chomp wpa_supplicant[508]: wlp2s0: PMKSA-CACHE-ADDED 44:e9:68:a9:58:72 0
May 27 12:27:42 chomp wpa_supplicant[508]: wlp2s0: PMKSA-CACHE-ADDED 44:e9:68:a9:5c:b2 0
May 27 12:27:43 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=34.107.243.93 DST=10.5.131.170 LEN=76 TOS=0x00 PREC=0x60 TTL=119 ID=59245 PROTO=TCP SPT=443 DPT=48658 WINDOW=287 RES=0x00 ACK PSH URGP=0
May 27 12:27:45 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=34.107.243.93 DST=10.5.131.170 LEN=76 TOS=0x00 PREC=0x60 TTL=119 ID=59246 PROTO=TCP SPT=443 DPT=48658 WINDOW=287 RES=0x00 ACK PSH URGP=0
May 27 12:27:48 chomp clamd[436]: Mon May 27 12:27:48 2024 -> SelfCheck: Database status OK.
May 27 12:27:48 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=34.107.243.93 DST=10.5.131.170 LEN=76 TOS=0x00 PREC=0x60 TTL=119 ID=59247 PROTO=TCP SPT=443 DPT=48658 WINDOW=287 RES=0x00 ACK PSH URGP=0
May 27 12:28:34 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=18.165.183.16 DST=10.5.131.170 LEN=91 TOS=0x00 PREC=0x00 TTL=245 ID=58091 PROTO=TCP SPT=443 DPT=46858 WINDOW=133 RES=0x00 ACK PSH URGP=0
May 27 12:28:34 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=18.165.183.8 DST=10.5.131.170 LEN=91 TOS=0x00 PREC=0x00 TTL=245 ID=37840 PROTO=TCP SPT=443 DPT=53330 WINDOW=133 RES=0x00 ACK PSH URGP=0
May 27 12:28:35 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=18.165.183.8 DST=10.5.131.170 LEN=91 TOS=0x00 PREC=0x00 TTL=245 ID=37843 PROTO=TCP SPT=443 DPT=53330 WINDOW=133 RES=0x00 ACK PSH FIN URGP=0
May 27 12:28:35 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=18.165.183.98 DST=10.5.131.170 LEN=76 TOS=0x00 PREC=0x00 TTL=245 ID=61922 PROTO=TCP SPT=443 DPT=56834 WINDOW=136 RES=0x00 ACK PSH URGP=0
May 27 12:28:35 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=18.165.183.98 DST=10.5.131.170 LEN=52 TOS=0x00 PREC=0x00 TTL=245 ID=61923 PROTO=TCP SPT=443 DPT=56834 WINDOW=136 RES=0x00 ACK FIN URGP=0
May 27 12:28:35 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=18.165.183.98 DST=10.5.131.170 LEN=52 TOS=0x00 PREC=0x00 TTL=245 ID=61924 PROTO=TCP SPT=443 DPT=56834 WINDOW=136 RES=0x00 ACK FIN URGP=0
May 27 12:28:35 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=18.165.183.98 DST=10.5.131.170 LEN=76 TOS=0x00 PREC=0x00 TTL=245 ID=61925 PROTO=TCP SPT=443 DPT=56834 WINDOW=136 RES=0x00 ACK PSH FIN URGP=0
May 27 12:28:35 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=18.165.183.16 DST=10.5.131.170 LEN=91 TOS=0x00 PREC=0x00 TTL=245 ID=58095 PROTO=TCP SPT=443 DPT=46858 WINDOW=133 RES=0x00 ACK PSH FIN URGP=0
May 27 12:28:35 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=18.165.183.8 DST=10.5.131.170 LEN=91 TOS=0x00 PREC=0x00 TTL=245 ID=37844 PROTO=TCP SPT=443 DPT=53330 WINDOW=133 RES=0x00 ACK PSH FIN URGP=0
May 27 12:28:35 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=18.165.183.98 DST=10.5.131.170 LEN=76 TOS=0x00 PREC=0x00 TTL=245 ID=61926 PROTO=TCP SPT=443 DPT=56834 WINDOW=136 RES=0x00 ACK PSH FIN URGP=0
May 27 12:28:36 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=18.165.183.8 DST=10.5.131.170 LEN=91 TOS=0x00 PREC=0x00 TTL=245 ID=37845 PROTO=TCP SPT=443 DPT=53330 WINDOW=133 RES=0x00 ACK PSH FIN URGP=0
May 27 12:28:36 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=18.165.183.16 DST=10.5.131.170 LEN=91 TOS=0x00 PREC=0x00 TTL=245 ID=58096 PROTO=TCP SPT=443 DPT=46858 WINDOW=133 RES=0x00 ACK PSH FIN URGP=0
May 27 12:28:36 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=18.165.183.98 DST=10.5.131.170 LEN=76 TOS=0x00 PREC=0x00 TTL=245 ID=61927 PROTO=TCP SPT=443 DPT=56834 WINDOW=136 RES=0x00 ACK PSH FIN URGP=0
May 27 12:28:48 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=18.165.183.119 DST=10.5.131.170 LEN=91 TOS=0x00 PREC=0x00 TTL=245 ID=30482 PROTO=TCP SPT=443 DPT=53924 WINDOW=133 RES=0x00 ACK PSH URGP=0
May 27 12:28:49 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=3.68.170.153 DST=10.5.131.170 LEN=91 TOS=0x00 PREC=0x00 TTL=51 ID=60865 DF PROTO=TCP SPT=443 DPT=51716 WINDOW=8 RES=0x00 ACK PSH URGP=0
May 27 12:28:49 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=3.68.170.153 DST=10.5.131.170 LEN=91 TOS=0x00 PREC=0x00 TTL=51 ID=60866 DF PROTO=TCP SPT=443 DPT=51716 WINDOW=8 RES=0x00 ACK PSH URGP=0
May 27 12:28:55 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=3.68.170.153 DST=10.5.131.170 LEN=115 TOS=0x00 PREC=0x00 TTL=51 ID=60871 DF PROTO=TCP SPT=443 DPT=51716 WINDOW=8 RES=0x00 ACK PSH FIN URGP=0
May 27 12:29:03 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=10.5.130.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=45229 PROTO=2
May 27 12:29:20 chomp kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=74:70:fd:14:51:0e:10:b3:d5:56:92:e7:08:00 SRC=3.68.170.153 DST=10.5.131.170 LEN=154 TOS=0x00 PREC=0x00 TTL=51 ID=60874 DF PROTO=TCP SPT=443 DPT=51716 WINDOW=8 RES=0x00 ACK PSH FIN URGP=0
May 27 12:29:25 chomp kernel: BUG: unable to handle page fault for address: 000000000000ab79
May 27 12:29:25 chomp kernel: #PF: supervisor read access in kernel mode
May 27 12:29:25 chomp kernel: #PF: error_code(0x0000) - not-present page
May 27 12:29:25 chomp kernel: PGD 0 P4D 0
May 27 12:29:25 chomp kernel: Oops: 0000 [#1] PREEMPT SMP PTI
May 27 12:29:25 chomp kernel: CPU: 0 PID: 15350 Comm: Isolated Web Co Tainted: P OE 6.6.30-2-MANJARO #1 69c42fdaf31cfc71a81bbcc18193a13d33819dca
May 27 12:29:25 chomp kernel: Hardware name: LENOVO 81EU/LNVNB161216, BIOS 7PCN46WW 11/26/2020
May 27 12:29:25 chomp kernel: RIP: 0010:refill_obj_stock+0x4f/0x180
May 27 12:29:25 chomp kernel: Code: c7 40 08 03 00 65 4c 03 3d 8e a6 63 5c 49 8b 47 10 48 39 f8 0f 84 9c 00 00 00 4c 89 ff e8 69 f2 ff ff 49 89 c6 e8 71 16 d9 ff <48> 8b 45 00 a8 03 0f 85 c9 00 00 00 65 48 ff 00 e8 6c 49 d9 ff 49
May 27 12:29:25 chomp kernel: RSP: 0000:ffffaa7f0490fb98 EFLAGS: 00010002
May 27 12:29:25 chomp kernel: RAX: 0000000000000002 RBX: 0000000000000479 RCX: 0000000000000004
May 27 12:29:25 chomp kernel: RDX: ffff9b4306d68000 RSI: 0000000000000000 RDI: ffff9b4306d68000
May 27 12:29:25 chomp kernel: RBP: 000000000000ab79 R08: ffff9b4106865cd0 R09: 0000000000000000
May 27 12:29:25 chomp kernel: R10: ffff9b43b2f12fa0 R11: 0000000000000000 R12: 0000000000000202
May 27 12:29:25 chomp kernel: R13: 000000000013456b R14: ffff9b411ca3a580 R15: ffff9b4473e30840
May 27 12:29:25 chomp kernel: FS: 00007ff530c78780(0000) GS:ffff9b4473e00000(0000) knlGS:0000000000000000
May 27 12:29:25 chomp kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
May 27 12:29:25 chomp kernel: CR2: 000000000000ab79 CR3: 000000017e01a006 CR4: 00000000003706f0
May 27 12:29:25 chomp kernel: Call Trace:
May 27 12:29:25 chomp kernel: <TASK>
May 27 12:29:25 chomp kernel: ? __die+0x23/0x70
May 27 12:29:25 chomp kernel: ? page_fault_oops+0x171/0x4e0
May 27 12:29:25 chomp kernel: ? exc_page_fault+0x7f/0x180
May 27 12:29:25 chomp kernel: ? asm_exc_page_fault+0x26/0x30
May 27 12:29:25 chomp kernel: ? refill_obj_stock+0x4f/0x180
May 27 12:29:25 chomp kernel: obj_cgroup_uncharge_zswap+0x1d/0x60
May 27 12:29:25 chomp kernel: zswap_free_entry+0x1b/0x140
May 27 12:29:25 chomp kernel: zswap_invalidate+0x73/0x80
May 27 12:29:25 chomp kernel: swap_range_free+0x7e/0xd0
May 27 12:29:25 chomp kernel: swapcache_free_entries+0x10e/0x270
May 27 12:29:25 chomp kernel: free_swap_slot+0xb4/0xc0
May 27 12:29:25 chomp kernel: put_swap_folio+0xe0/0x3d0
May 27 12:29:25 chomp kernel: delete_from_swap_cache+0x63/0x80
May 27 12:29:25 chomp kernel: folio_free_swap+0x7a/0x90
May 27 12:29:25 chomp kernel: do_swap_page+0x9b4/0xd20
May 27 12:29:25 chomp kernel: ? set_ptes.isra.0+0x1e/0xa0
May 27 12:29:25 chomp kernel: ? __pte_offset_map+0x1b/0x180
May 27 12:29:25 chomp kernel: __handle_mm_fault+0x80b/0xdb0
May 27 12:29:25 chomp kernel: handle_mm_fault+0x17f/0x360
May 27 12:29:25 chomp kernel: do_user_addr_fault+0x15b/0x660
May 27 12:29:25 chomp kernel: exc_page_fault+0x7f/0x180
May 27 12:29:25 chomp kernel: asm_exc_page_fault+0x26/0x30
May 27 12:29:25 chomp kernel: RIP: 0033:0x7ff525020497
May 27 12:29:25 chomp kernel: Code: 44 89 bb d0 03 00 00 4c 89 a3 d8 03 00 00 48 89 ab e0 03 00 00 4c 89 bb e8 03 00 00 44 89 bb f0 03 00 00 4c 89 ab f8 03 00 00 <4c> 89 ab 00 04 00 00 0f 11 83 08 04 00 00 bf 10 00 00 00 ff 15 90
May 27 12:29:25 chomp kernel: RSP: 002b:00007ffd9c075b50 EFLAGS: 00010246
May 27 12:29:25 chomp kernel: RAX: 00007ff52aa94918 RBX: 00007ff51430bc00 RCX: 00000000101d0000
May 27 12:29:25 chomp kernel: RDX: 0000000000000001 RSI: 0000000000000000 RDI: 00007ff530700018
May 27 12:29:25 chomp kernel: RBP: 0002000100000000 R08: 00007ff5191f53d0 R09: 00007ff5191f53d0
May 27 12:29:25 chomp kernel: R10: 0000000000000001 R11: 00007ff514ad4c00 R12: 00007ff523122858
May 27 12:29:25 chomp kernel: R13: 00007ff523494878 R14: 0000000000000001 R15: 0000000000000000
May 27 12:29:25 chomp kernel: </TASK>
May 27 12:29:25 chomp kernel: Modules linked in: vhost_net vhost vhost_iotlb tap tun usbhid xt_recent ip6t_REJECT nf_reject_ipv6 xt_hl ip6t_rt ipt_REJECT xt_LOG nf_log_syslog xt_limit xt_addrtype xt_tcpudp xt_conntrack ip6table_filter ip6_tables iptable_filter nft_reject_ipv4 nf_reject_ipv4 nft_reject nft_ct nft_masq nft_chain_nat nf_tables nf_nat_h323 nf_conntrack_h323 nf_nat_pptp nf_conntrack_pptp nf_nat_tftp nf_conntrack_tftp nf_nat_sip nf_conntrack_sip nf_nat_irc nf_conntrack_irc nf_nat_ftp nf_conntrack_ftp nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c rfcomm ccm snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio qrtr cmac algif_hash algif_skcipher af_alg bnep uinput nvidia_uvm(POE) intel_rapl_msr intel_rapl_common intel_tcc_cooling snd_soc_avs x86_pkg_temp_thermal snd_soc_hda_codec intel_powerclamp coretemp snd_soc_skl snd_soc_hdac_hda kvm_intel snd_hda_ext_core snd_soc_sst_ipc snd_soc_sst_dsp snd_soc_acpi_intel_match nvidia_drm(POE) kvm snd_soc_acpi irqbypass snd_soc_core crct10dif_pclmul
May 27 12:29:25 chomp kernel: joydev uvcvideo snd_compress crc32_pclmul videobuf2_vmalloc i915 nvidia_modeset(POE) ac97_bus snd_pcm_dmaengine snd_hda_intel polyval_clmulni uvc mousedev iwlmvm btusb polyval_generic gf128mul snd_intel_dspcfg ghash_clmulni_intel videobuf2_memops snd_intel_sdw_acpi btrtl sha512_ssse3 btintel videobuf2_v4l2 mac80211 snd_hda_codec sha256_ssse3 videodev sha1_ssse3 btbcm drm_buddy btmtk libarc4 snd_hda_core i2c_algo_bit aesni_intel iTCO_wdt videobuf2_common bluetooth hid_multitouch iwlwifi ttm snd_hwdep crypto_simd intel_pmc_bxt mc ecdh_generic mei_hdcp mei_pxp ee1004 iTCO_vendor_support nvidia(POE) wmi_bmof cryptd drm_display_helper intel_wmi_thunderbolt ideapad_laptop snd_pcm rapl cfg80211 intel_cstate sparse_keymap snd_timer intel_lpss_pci vfat intel_uncore snd i2c_i801 platform_profile mei_me intel_xhci_usb_role_switch i2c_hid_acpi cec pcspkr fat intel_lpss roles i2c_hid rfkill soundcore i2c_smbus idma64 mei intel_gtt intel_pch_thermal video wmi acpi_pad mac_hid crypto_user fuse loop dm_mod nfnetlink
May 27 12:29:25 chomp kernel: bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 serio_raw atkbd libps2 vivaldi_fmap nvme i8042 nvme_core xhci_pci crc32c_intel nvme_common xhci_pci_renesas serio
May 27 12:29:25 chomp kernel: ---[ end trace 0000000000000000 ]---
May 27 12:29:25 chomp kernel: note: Isolated Web Co[15350] exited with irqs disabled
May 27 12:29:25 chomp kernel: note: Isolated Web Co[15350] exited with preempt_count 4
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: Error sending STATISTICS_CMD: time out after 2000ms.
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: Current CMD queue read_ptr 136 write_ptr 137
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: Transport status: 0x0000004A, valid: 6
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: Loaded firmware version: 29.4063824552.0 7265D-29.ucode
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000230 | trm_hw_status0
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | trm_hw_status1
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00043D6C | branchlink2
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x0004B002 | interruptlink1
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x0000437A | interruptlink2
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | data1
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000080 | data2
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x07030000 | data3
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0xE9413FBC | beacon time
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x8F31703F | tsf low
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x000015D2 | tsf hi
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | time gp1
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x2653ACBE | time gp2
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000001 | uCode revision type
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x0000001D | uCode version major
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0xF2390AA8 | uCode version minor
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000210 | hw version
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00C89200 | board version
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x0000001C | hcmd
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x24022000 | isr0
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00800000 | isr1
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000002 | isr2
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00417CC0 | isr3
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | isr4
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x0AE6001C | last cmd Id
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | wait_event
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000080 | l2p_control
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00010030 | l2p_duration
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x0000003F | l2p_mhvalid
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000080 | l2p_addr_match
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000005 | lmpm_pmg_sel
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x03031934 | timestamp
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00345888 | flow_handler
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: Fseq Registers:
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_ERROR_CODE
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_TOP_INIT_VERSION
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_CNVIO_INIT_VERSION
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_OTP_VERSION
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_TOP_CONTENT_VERSION
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_ALIVE_TOKEN
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_CNVI_ID
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_CNVR_ID
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | CNVI_AUX_MISC_CHIP
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | CNVR_AUX_MISC_CHIP
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_PREV_CNVIO_INIT_VERSION
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_WIFI_FSEQ_VERSION
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_BT_FSEQ_VERSION
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_CLASS_TP_VERSION
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: Collecting data: trigger 2 fired.
May 27 12:29:30 chomp kernel: ieee80211 phy0: Hardware restart was requested
May 27 12:29:30 chomp kernel: iwlwifi 0000:02:00.0: Queue 0 is active on fifo 7 and stuck for 2500 ms. SW [136, 137] HW [137, 137] FH TRB=0x0700088
May 27 12:29:36 chomp kernel: iwlwifi 0000:02:00.0: Queue 10 is active on fifo 1 and stuck for 10000 ms. SW [220, 232] HW [232, 232] FH TRB=0x0c010a0e7
May 27 12:29:52 chomp kernel: watchdog: BUG: soft lockup - CPU#0 stuck for 26s! [firefox:1176]
May 27 12:29:52 chomp kernel: Modules linked in: vhost_net vhost vhost_iotlb tap tun usbhid xt_recent ip6t_REJECT nf_reject_ipv6 xt_hl ip6t_rt ipt_REJECT xt_LOG nf_log_syslog xt_limit xt_addrtype xt_tcpudp xt_conntrack ip6table_filter ip6_tables iptable_filter nft_reject_ipv4 nf_reject_ipv4 nft_reject nft_ct nft_masq nft_chain_nat nf_tables nf_nat_h323 nf_conntrack_h323 nf_nat_pptp nf_conntrack_pptp nf_nat_tftp nf_conntrack_tftp nf_nat_sip nf_conntrack_sip nf_nat_irc nf_conntrack_irc nf_nat_ftp nf_conntrack_ftp nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c rfcomm ccm snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio qrtr cmac algif_hash algif_skcipher af_alg bnep uinput nvidia_uvm(POE) intel_rapl_msr intel_rapl_common intel_tcc_cooling snd_soc_avs x86_pkg_temp_thermal snd_soc_hda_codec intel_powerclamp coretemp snd_soc_skl snd_soc_hdac_hda kvm_intel snd_hda_ext_core snd_soc_sst_ipc snd_soc_sst_dsp snd_soc_acpi_intel_match nvidia_drm(POE) kvm snd_soc_acpi irqbypass snd_soc_core crct10dif_pclmul
May 27 12:29:52 chomp kernel: joydev uvcvideo snd_compress crc32_pclmul videobuf2_vmalloc i915 nvidia_modeset(POE) ac97_bus snd_pcm_dmaengine snd_hda_intel polyval_clmulni uvc mousedev iwlmvm btusb polyval_generic gf128mul snd_intel_dspcfg ghash_clmulni_intel videobuf2_memops snd_intel_sdw_acpi btrtl sha512_ssse3 btintel videobuf2_v4l2 mac80211 snd_hda_codec sha256_ssse3 videodev sha1_ssse3 btbcm drm_buddy btmtk libarc4 snd_hda_core i2c_algo_bit aesni_intel iTCO_wdt videobuf2_common bluetooth hid_multitouch iwlwifi ttm snd_hwdep crypto_simd intel_pmc_bxt mc ecdh_generic mei_hdcp mei_pxp ee1004 iTCO_vendor_support nvidia(POE) wmi_bmof cryptd drm_display_helper intel_wmi_thunderbolt ideapad_laptop snd_pcm rapl cfg80211 intel_cstate sparse_keymap snd_timer intel_lpss_pci vfat intel_uncore snd i2c_i801 platform_profile mei_me intel_xhci_usb_role_switch i2c_hid_acpi cec pcspkr fat intel_lpss roles i2c_hid rfkill soundcore i2c_smbus idma64 mei intel_gtt intel_pch_thermal video wmi acpi_pad mac_hid crypto_user fuse loop dm_mod nfnetlink
May 27 12:29:52 chomp kernel: bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 serio_raw atkbd libps2 vivaldi_fmap nvme i8042 nvme_core xhci_pci crc32c_intel nvme_common xhci_pci_renesas serio
May 27 12:29:52 chomp kernel: CPU: 0 PID: 1176 Comm: firefox Tainted: P D OE 6.6.30-2-MANJARO #1 69c42fdaf31cfc71a81bbcc18193a13d33819dca
May 27 12:29:52 chomp kernel: Hardware name: LENOVO 81EU/LNVNB161216, BIOS 7PCN46WW 11/26/2020
May 27 12:29:52 chomp kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x6e/0x2e0
May 27 12:29:52 chomp kernel: Code: 77 7f f0 0f ba 2b 08 0f 92 c2 8b 03 0f b6 d2 c1 e2 08 30 e4 09 d0 3d ff 00 00 00 77 5b 85 c0 74 10 0f b6 03 84 c0 74 09 f3 90 <0f> b6 03 84 c0 75 f7 b8 01 00 00 00 66 89 03 65 48 ff 05 e3 dd c4
May 27 12:29:52 chomp kernel: RSP: 0000:ffffaa7f039b3ba8 EFLAGS: 00000202
May 27 12:29:52 chomp kernel: RAX: 0000000000000001 RBX: ffff9b4106865cd8 RCX: 0000000000000001
May 27 12:29:52 chomp kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff9b4106865cd8
May 27 12:29:52 chomp kernel: RBP: ffff9b4106865cd8 R08: ffffd8bb85d98680 R09: 0000000000000028
May 27 12:29:52 chomp kernel: R10: 0000000000000001 R11: 0000000000000000 R12: 00000000003a423b
May 27 12:29:52 chomp kernel: R13: 03ffffffffffffff R14: ffff9b4106865cd0 R15: 0000000000000000
May 27 12:29:52 chomp kernel: FS: 00007fd6b08b9580(0000) GS:ffff9b4473e00000(0000) knlGS:0000000000000000
May 27 12:29:52 chomp kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
May 27 12:29:52 chomp kernel: CR2: 00007fd6010d4000 CR3: 0000000105c4a004 CR4: 00000000003706f0
May 27 12:29:52 chomp kernel: Call Trace:
May 27 12:29:52 chomp kernel: <IRQ>
May 27 12:29:52 chomp kernel: ? watchdog_timer_fn+0x1b8/0x220
May 27 12:29:52 chomp kernel: ? __pfx_watchdog_timer_fn+0x10/0x10
May 27 12:29:52 chomp kernel: ? __hrtimer_run_queues+0x10f/0x2b0
May 27 12:29:52 chomp kernel: ? hrtimer_interrupt+0xf8/0x230
May 27 12:29:52 chomp kernel: ? __sysvec_apic_timer_interrupt+0x4d/0x140
May 27 12:29:52 chomp kernel: ? sysvec_apic_timer_interrupt+0x6d/0x90
May 27 12:29:52 chomp kernel: </IRQ>
May 27 12:29:52 chomp kernel: <TASK>
May 27 12:29:52 chomp kernel: ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
May 27 12:29:52 chomp kernel: ? native_queued_spin_lock_slowpath+0x6e/0x2e0
May 27 12:29:52 chomp kernel: ? __mod_lruvec_page_state+0x99/0x130
May 27 12:29:52 chomp kernel: _raw_spin_lock+0x29/0x30
May 27 12:29:52 chomp kernel: zswap_load+0x9c/0x490
May 27 12:29:52 chomp kernel: swap_readpage+0x81/0x460
May 27 12:29:52 chomp kernel: swapin_readahead+0x464/0x4e0
May 27 12:29:52 chomp kernel: do_swap_page+0x1c8/0xd20
May 27 12:29:52 chomp kernel: ? do_syscall_64+0x66/0x80
May 27 12:29:52 chomp kernel: ? syscall_exit_to_user_mode+0x22/0x40
May 27 12:29:52 chomp kernel: ? __pte_offset_map+0x1b/0x180
May 27 12:29:52 chomp kernel: __handle_mm_fault+0x80b/0xdb0
May 27 12:29:52 chomp kernel: handle_mm_fault+0x17f/0x360
May 27 12:29:52 chomp kernel: do_user_addr_fault+0x15b/0x660
May 27 12:29:52 chomp kernel: exc_page_fault+0x7f/0x180
May 27 12:29:52 chomp kernel: asm_exc_page_fault+0x26/0x30
May 27 12:29:52 chomp kernel: RIP: 0033:0x7fd6a7ee1597
May 27 12:29:52 chomp kernel: Code: 4c 8d 3d dc 88 c3 02 49 39 ae 98 00 00 00 76 3c 49 8b 8e f0 00 00 00 49 8b 86 a8 00 00 00 48 01 e8 31 d2 49 f7 b6 a0 00 00 00 <4c> 8b 24 d1 4d 85 e4 74 19 f6 43 08 01 0f 85 9c 00 00 00 48 8b 03
May 27 12:29:52 chomp kernel: RSP: 002b:00007fff27afaf20 EFLAGS: 00010246
May 27 12:29:52 chomp kernel: RAX: 0000000000000000 RBX: 00007fff27afb0a0 RCX: 00007fd6010d3000
May 27 12:29:52 chomp kernel: RDX: 0000000000000200 RSI: 00007fd610e5e100 RDI: 00007fff27afb0a0
May 27 12:29:52 chomp kernel: RBP: 000000000000011c R08: 00007fd544561f78 R09: 0000000000000112
May 27 12:29:52 chomp kernel: R10: 00007fd6a6186cb0 R11: 00007fff27afd130 R12: 00007fd610e5e100
May 27 12:29:52 chomp kernel: R13: 00000000000003e8 R14: 00007fd66ff64980 R15: 00007fd6aab19e50
May 27 12:29:52 chomp kernel: </TASK>
May 27 12:29:55 chomp openconnect[49725]: Failed to send DPD request. Expect disconnect
May 27 12:29:58 chomp kernel: watchdog: BUG: soft lockup - CPU#2 stuck for 22s! [slack:3934]
May 27 12:29:58 chomp kernel: Modules linked in: vhost_net vhost vhost_iotlb tap tun usbhid xt_recent ip6t_REJECT nf_reject_ipv6 xt_hl ip6t_rt ipt_REJECT xt_LOG nf_log_syslog xt_limit xt_addrtype xt_tcpudp xt_conntrack ip6table_filter ip6_tables iptable_filter nft_reject_ipv4 nf_reject_ipv4 nft_reject nft_ct nft_masq nft_chain_nat nf_tables nf_nat_h323 nf_conntrack_h323 nf_nat_pptp nf_conntrack_pptp nf_nat_tftp nf_conntrack_tftp nf_nat_sip nf_conntrack_sip nf_nat_irc nf_conntrack_irc nf_nat_ftp nf_conntrack_ftp nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c rfcomm ccm snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio qrtr cmac algif_hash algif_skcipher af_alg bnep uinput nvidia_uvm(POE) intel_rapl_msr intel_rapl_common intel_tcc_cooling snd_soc_avs x86_pkg_temp_thermal snd_soc_hda_codec intel_powerclamp coretemp snd_soc_skl snd_soc_hdac_hda kvm_intel snd_hda_ext_core snd_soc_sst_ipc snd_soc_sst_dsp snd_soc_acpi_intel_match nvidia_drm(POE) kvm snd_soc_acpi irqbypass snd_soc_core crct10dif_pclmul
May 27 12:29:58 chomp kernel: joydev uvcvideo snd_compress crc32_pclmul videobuf2_vmalloc i915 nvidia_modeset(POE) ac97_bus snd_pcm_dmaengine snd_hda_intel polyval_clmulni uvc mousedev iwlmvm btusb polyval_generic gf128mul snd_intel_dspcfg ghash_clmulni_intel videobuf2_memops snd_intel_sdw_acpi btrtl sha512_ssse3 btintel videobuf2_v4l2 mac80211 snd_hda_codec sha256_ssse3 videodev sha1_ssse3 btbcm drm_buddy btmtk libarc4 snd_hda_core i2c_algo_bit aesni_intel iTCO_wdt videobuf2_common bluetooth hid_multitouch iwlwifi ttm snd_hwdep crypto_simd intel_pmc_bxt mc ecdh_generic mei_hdcp mei_pxp ee1004 iTCO_vendor_support nvidia(POE) wmi_bmof cryptd drm_display_helper intel_wmi_thunderbolt ideapad_laptop snd_pcm rapl cfg80211 intel_cstate sparse_keymap snd_timer intel_lpss_pci vfat intel_uncore snd i2c_i801 platform_profile mei_me intel_xhci_usb_role_switch i2c_hid_acpi cec pcspkr fat intel_lpss roles i2c_hid rfkill soundcore i2c_smbus idma64 mei intel_gtt intel_pch_thermal video wmi acpi_pad mac_hid crypto_user fuse loop dm_mod nfnetlink
May 27 12:29:58 chomp kernel: bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 serio_raw atkbd libps2 vivaldi_fmap nvme i8042 nvme_core xhci_pci crc32c_intel nvme_common xhci_pci_renesas serio
May 27 12:29:58 chomp kernel: CPU: 2 PID: 3934 Comm: slack Tainted: P D OEL 6.6.30-2-MANJARO #1 69c42fdaf31cfc71a81bbcc18193a13d33819dca
May 27 12:29:58 chomp kernel: Hardware name: LENOVO 81EU/LNVNB161216, BIOS 7PCN46WW 11/26/2020
May 27 12:29:58 chomp kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x223/0x2e0
May 27 12:29:58 chomp kernel: Code: c5 01 41 c1 e4 10 41 c1 e5 12 45 09 ec 44 89 e0 c1 e8 10 66 87 43 02 89 c2 c1 e2 10 81 fa ff ff 00 00 77 5e 31 d2 eb 02 f3 90 <8b> 03 66 85 c0 75 f7 44 39 e0 0f 84 8e 00 00 00 c6 03 01 48 85 d2
May 27 12:29:58 chomp kernel: RSP: 0000:ffffaa7f0f67fba8 EFLAGS: 00000202
May 27 12:29:58 chomp kernel: RAX: 00000000000c0101 RBX: ffff9b4106865cd8 RCX: 0000000000000003
May 27 12:29:58 chomp kernel: RDX: 0000000000000000 RSI: 0000000000000101 RDI: ffff9b4106865cd8
May 27 12:29:58 chomp kernel: RBP: ffff9b4473f35040 R08: ffffd8bb86b31840 R09: 0000000000000028
May 27 12:29:58 chomp kernel: R10: 0000000000000001 R11: 0000000000000000 R12: 00000000000c0000
May 27 12:29:58 chomp kernel: R13: 00000000000c0000 R14: ffff9b4106865cd0 R15: 0000000000000000
May 27 12:29:58 chomp kernel: FS: 00007ff4d8f41040(0000) GS:ffff9b4473f00000(0000) knlGS:0000000000000000
May 27 12:29:58 chomp kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
May 27 12:29:58 chomp kernel: CR2: 000023d50061c154 CR3: 00000002268ee002 CR4: 00000000003706e0
May 27 12:29:58 chomp kernel: Call Trace:
May 27 12:29:58 chomp kernel: <IRQ>
May 27 12:29:58 chomp kernel: ? watchdog_timer_fn+0x1b8/0x220
May 27 12:29:58 chomp kernel: ? __pfx_watchdog_timer_fn+0x10/0x10
May 27 12:29:58 chomp kernel: ? __hrtimer_run_queues+0x10f/0x2b0
May 27 12:29:58 chomp kernel: ? hrtimer_interrupt+0xf8/0x230
May 27 12:29:58 chomp kernel: ? __sysvec_apic_timer_interrupt+0x4d/0x140
May 27 12:29:58 chomp kernel: ? sysvec_apic_timer_interrupt+0x6d/0x90
May 27 12:29:58 chomp kernel: </IRQ>
May 27 12:29:58 chomp kernel: <TASK>
May 27 12:29:58 chomp kernel: ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
May 27 12:29:58 chomp kernel: ? native_queued_spin_lock_slowpath+0x223/0x2e0
May 27 12:29:58 chomp kernel: ? __mod_lruvec_page_state+0x99/0x130
May 27 12:29:58 chomp kernel: _raw_spin_lock+0x29/0x30
May 27 12:29:58 chomp kernel: zswap_load+0x9c/0x490
May 27 12:29:58 chomp kernel: swap_readpage+0x81/0x460
May 27 12:29:58 chomp kernel: swapin_readahead+0x1e2/0x4e0
May 27 12:29:58 chomp kernel: do_swap_page+0x1c8/0xd20
May 27 12:29:58 chomp kernel: ? folio_add_new_anon_rmap+0x45/0xe0
May 27 12:29:58 chomp kernel: ? set_ptes.isra.0+0x1e/0xa0
May 27 12:29:58 chomp kernel: ? __pte_offset_map+0x1b/0x180
May 27 12:29:58 chomp kernel: __handle_mm_fault+0x80b/0xdb0
May 27 12:29:58 chomp kernel: handle_mm_fault+0x17f/0x360
May 27 12:29:58 chomp kernel: do_user_addr_fault+0x15b/0x660
May 27 12:29:58 chomp kernel: exc_page_fault+0x7f/0x180
May 27 12:29:58 chomp kernel: asm_exc_page_fault+0x26/0x30
May 27 12:29:58 chomp kernel: RIP: 0033:0x55f733a32db0
May 27 12:29:58 chomp kernel: Code: 89 cc bb 02 00 00 00 48 89 5d b0 bb 04 00 00 00 41 bf 06 00 00 00 4c 89 7d 80 e9 1c ff ff ff 45 31 c9 0f 1f 84 00 00 00 00 00 <46> 0f b6 14 0a 66 46 89 14 49 49 ff c1 4d 39 c8 75 ee e9 71 f7 ff
May 27 12:29:58 chomp kernel: RSP: 002b:00007ffd0b4bee08 EFLAGS: 00010246
May 27 12:29:58 chomp kernel: RAX: 000055f73a290ca8 RBX: 00000000ffffffff RCX: 0000098808c75fb2
May 27 12:29:58 chomp kernel: RDX: 000023d50061c154 RSI: 000000000009a008 RDI: 0000098808c75f80
May 27 12:29:58 chomp kernel: RBP: 00007ffd0b4bee70 R08: 000000000000003d R09: 0000000000000000
May 27 12:29:58 chomp kernel: R10: 000023d500582141 R11: 0000098808c75b00 R12: 00007ffd0b4bef30
May 27 12:29:58 chomp kernel: R13: 00007ffd0b4bf148 R14: 0000098808c75f80 R15: 000000000009a045
May 27 12:29:58 chomp kernel: </TASK>
May 27 12:30:04 chomp openconnect[49725]: CSTP Dead Peer Detection detected dead peer!
May 27 12:30:07 chomp openconnect[49725]: Failed to reconnect to host <redacted>: No route to host
May 27 12:30:07 chomp openconnect[49725]: sleep 10s, remaining timeout 300s
May 27 12:30:10 chomp kernel: watchdog: BUG: soft lockup - CPU#1 stuck for 22s! [kcompactd0:48]
May 27 12:30:10 chomp kernel: Modules linked in: vhost_net vhost vhost_iotlb tap tun usbhid xt_recent ip6t_REJECT nf_reject_ipv6 xt_hl ip6t_rt ipt_REJECT xt_LOG nf_log_syslog xt_limit xt_addrtype xt_tcpudp xt_conntrack ip6table_filter ip6_tables iptable_filter nft_reject_ipv4 nf_reject_ipv4 nft_reject nft_ct nft_masq nft_chain_nat nf_tables nf_nat_h323 nf_conntrack_h323 nf_nat_pptp nf_conntrack_pptp nf_nat_tftp nf_conntrack_tftp nf_nat_sip nf_conntrack_sip nf_nat_irc nf_conntrack_irc nf_nat_ftp nf_conntrack_ftp nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c rfcomm ccm snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio qrtr cmac algif_hash algif_skcipher af_alg bnep uinput nvidia_uvm(POE) intel_rapl_msr intel_rapl_common intel_tcc_cooling snd_soc_avs x86_pkg_temp_thermal snd_soc_hda_codec intel_powerclamp coretemp snd_soc_skl snd_soc_hdac_hda kvm_intel snd_hda_ext_core snd_soc_sst_ipc snd_soc_sst_dsp snd_soc_acpi_intel_match nvidia_drm(POE) kvm snd_soc_acpi irqbypass snd_soc_core crct10dif_pclmul
May 27 12:30:10 chomp kernel: joydev uvcvideo snd_compress crc32_pclmul videobuf2_vmalloc i915 nvidia_modeset(POE) ac97_bus snd_pcm_dmaengine snd_hda_intel polyval_clmulni uvc mousedev iwlmvm btusb polyval_generic gf128mul snd_intel_dspcfg ghash_clmulni_intel videobuf2_memops snd_intel_sdw_acpi btrtl sha512_ssse3 btintel videobuf2_v4l2 mac80211 snd_hda_codec sha256_ssse3 videodev sha1_ssse3 btbcm drm_buddy btmtk libarc4 snd_hda_core i2c_algo_bit aesni_intel iTCO_wdt videobuf2_common bluetooth hid_multitouch iwlwifi ttm snd_hwdep crypto_simd intel_pmc_bxt mc ecdh_generic mei_hdcp mei_pxp ee1004 iTCO_vendor_support nvidia(POE) wmi_bmof cryptd drm_display_helper intel_wmi_thunderbolt ideapad_laptop snd_pcm rapl cfg80211 intel_cstate sparse_keymap snd_timer intel_lpss_pci vfat intel_uncore snd i2c_i801 platform_profile mei_me intel_xhci_usb_role_switch i2c_hid_acpi cec pcspkr fat intel_lpss roles i2c_hid rfkill soundcore i2c_smbus idma64 mei intel_gtt intel_pch_thermal video wmi acpi_pad mac_hid crypto_user fuse loop dm_mod nfnetlink
May 27 12:30:10 chomp kernel: bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 serio_raw atkbd libps2 vivaldi_fmap nvme i8042 nvme_core xhci_pci crc32c_intel nvme_common xhci_pci_renesas serio
May 27 12:30:10 chomp kernel: CPU: 1 PID: 48 Comm: kcompactd0 Tainted: P D OEL 6.6.30-2-MANJARO #1 69c42fdaf31cfc71a81bbcc18193a13d33819dca
May 27 12:30:10 chomp kernel: Hardware name: LENOVO 81EU/LNVNB161216, BIOS 7PCN46WW 11/26/2020
May 27 12:30:10 chomp kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x6e/0x2e0
May 27 12:30:10 chomp kernel: Code: 77 7f f0 0f ba 2b 08 0f 92 c2 8b 03 0f b6 d2 c1 e2 08 30 e4 09 d0 3d ff 00 00 00 77 5b 85 c0 74 10 0f b6 03 84 c0 74 09 f3 90 <0f> b6 03 84 c0 75 f7 b8 01 00 00 00 66 89 03 65 48 ff 05 e3 dd c4
May 27 12:30:10 chomp kernel: RSP: 0018:ffffaa7f0021b900 EFLAGS: 00000202
May 27 12:30:10 chomp kernel: RAX: 0000000000000001 RBX: ffffd8bb85f845e8 RCX: 0000000000000867
May 27 12:30:10 chomp kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffffd8bb85f845e8
May 27 12:30:10 chomp kernel: RBP: 00007ff5142d6000 R08: 0000008000000000 R09: 0200000000000080
May 27 12:30:10 chomp kernel: R10: 0000000000000000 R11: ffff9b43d902a9c0 R12: ffff9b418fadee00
May 27 12:30:10 chomp kernel: R13: ffff9b431c02e3c0 R14: 0000000000000001 R15: ffffff8000000000
May 27 12:30:10 chomp kernel: FS: 0000000000000000(0000) GS:ffff9b4473e80000(0000) knlGS:0000000000000000
May 27 12:30:10 chomp kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
May 27 12:30:10 chomp kernel: CR2: 00007fe7ee974000 CR3: 00000001b14f2002 CR4: 00000000003706e0
May 27 12:30:10 chomp kernel: Call Trace:
May 27 12:30:10 chomp kernel: <IRQ>
May 27 12:30:10 chomp kernel: ? watchdog_timer_fn+0x1b8/0x220
May 27 12:30:10 chomp kernel: ? __pfx_watchdog_timer_fn+0x10/0x10
May 27 12:30:10 chomp kernel: ? __hrtimer_run_queues+0x10f/0x2b0
May 27 12:30:10 chomp kernel: ? hrtimer_interrupt+0xf8/0x230
May 27 12:30:10 chomp kernel: ? __sysvec_apic_timer_interrupt+0x4d/0x140
May 27 12:30:10 chomp kernel: ? sysvec_apic_timer_interrupt+0x6d/0x90
May 27 12:30:10 chomp kernel: </IRQ>
May 27 12:30:10 chomp kernel: <TASK>
May 27 12:30:10 chomp kernel: ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
May 27 12:30:10 chomp kernel: ? native_queued_spin_lock_slowpath+0x6e/0x2e0
May 27 12:30:10 chomp kernel: _raw_spin_lock+0x29/0x30
May 27 12:30:10 chomp kernel: page_vma_mapped_walk+0x6a2/0x950
May 27 12:30:10 chomp kernel: try_to_migrate_one+0x17b/0xcf0
May 27 12:30:10 chomp kernel: rmap_walk_anon+0xca/0x1b0
May 27 12:30:10 chomp kernel: try_to_migrate+0xf9/0x110
May 27 12:30:10 chomp kernel: ? __pfx_try_to_migrate_one+0x10/0x10
May 27 12:30:10 chomp kernel: ? __pfx_folio_not_mapped+0x10/0x10
May 27 12:30:10 chomp kernel: ? __pfx_folio_lock_anon_vma_read+0x10/0x10
May 27 12:30:10 chomp kernel: ? __pfx_invalid_migration_vma+0x10/0x10
May 27 12:30:10 chomp kernel: migrate_pages_batch+0x55b/0xba0
May 27 12:30:10 chomp kernel: ? __pfx_compaction_alloc+0x10/0x10
May 27 12:30:10 chomp kernel: ? __pfx_compaction_free+0x10/0x10
May 27 12:30:10 chomp kernel: ? __pfx_remove_migration_pte+0x10/0x10
May 27 12:30:10 chomp kernel: migrate_pages+0xa86/0xd30
May 27 12:30:10 chomp kernel: ? folio_add_lru+0x58/0xa0
May 27 12:30:10 chomp kernel: compact_zone+0x831/0xf20
May 27 12:30:10 chomp kernel: proactive_compact_node+0x85/0xe0
May 27 12:30:10 chomp kernel: kcompactd+0x35b/0x430
May 27 12:30:10 chomp kernel: ? __pfx_autoremove_wake_function+0x10/0x10
May 27 12:30:10 chomp kernel: ? __pfx_kcompactd+0x10/0x10
May 27 12:30:10 chomp kernel: kthread+0xe5/0x120
May 27 12:30:10 chomp kernel: ? __pfx_kthread+0x10/0x10
May 27 12:30:10 chomp kernel: ret_from_fork+0x31/0x50
May 27 12:30:10 chomp kernel: ret_from_fork_asm+0x1b/0x30
May 27 12:30:10 chomp kernel: </TASK>
May 27 12:30:20 chomp openconnect[49725]: Failed to reconnect to host <redacted>: No route to host
May 27 12:30:20 chomp openconnect[49725]: sleep 20s, remaining timeout 290s
May 27 12:30:20 chomp kernel: watchdog: BUG: soft lockup - CPU#0 stuck for 52s! [firefox:1176]
May 27 12:30:20 chomp kernel: Modules linked in: vhost_net vhost vhost_iotlb tap tun usbhid xt_recent ip6t_REJECT nf_reject_ipv6 xt_hl ip6t_rt ipt_REJECT xt_LOG nf_log_syslog xt_limit xt_addrtype xt_tcpudp xt_conntrack ip6table_filter ip6_tables iptable_filter nft_reject_ipv4 nf_reject_ipv4 nft_reject nft_ct nft_masq nft_chain_nat nf_tables nf_nat_h323 nf_conntrack_h323 nf_nat_pptp nf_conntrack_pptp nf_nat_tftp nf_conntrack_tftp nf_nat_sip nf_conntrack_sip nf_nat_irc nf_conntrack_irc nf_nat_ftp nf_conntrack_ftp nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c rfcomm ccm snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio qrtr cmac algif_hash algif_skcipher af_alg bnep uinput nvidia_uvm(POE) intel_rapl_msr intel_rapl_common intel_tcc_cooling snd_soc_avs x86_pkg_temp_thermal snd_soc_hda_codec intel_powerclamp coretemp snd_soc_skl snd_soc_hdac_hda kvm_intel snd_hda_ext_core snd_soc_sst_ipc snd_soc_sst_dsp snd_soc_acpi_intel_match nvidia_drm(POE) kvm snd_soc_acpi irqbypass snd_soc_core crct10dif_pclmul
May 27 12:30:20 chomp kernel: joydev uvcvideo snd_compress crc32_pclmul videobuf2_vmalloc i915 nvidia_modeset(POE) ac97_bus snd_pcm_dmaengine snd_hda_intel polyval_clmulni uvc mousedev iwlmvm btusb polyval_generic gf128mul snd_intel_dspcfg ghash_clmulni_intel videobuf2_memops snd_intel_sdw_acpi btrtl sha512_ssse3 btintel videobuf2_v4l2 mac80211 snd_hda_codec sha256_ssse3 videodev sha1_ssse3 btbcm drm_buddy btmtk libarc4 snd_hda_core i2c_algo_bit aesni_intel iTCO_wdt videobuf2_common bluetooth hid_multitouch iwlwifi ttm snd_hwdep crypto_simd intel_pmc_bxt mc ecdh_generic mei_hdcp mei_pxp ee1004 iTCO_vendor_support nvidia(POE) wmi_bmof cryptd drm_display_helper intel_wmi_thunderbolt ideapad_laptop snd_pcm rapl cfg80211 intel_cstate sparse_keymap snd_timer intel_lpss_pci vfat intel_uncore snd i2c_i801 platform_profile mei_me intel_xhci_usb_role_switch i2c_hid_acpi cec pcspkr fat intel_lpss roles i2c_hid rfkill soundcore i2c_smbus idma64 mei intel_gtt intel_pch_thermal video wmi acpi_pad mac_hid crypto_user fuse loop dm_mod nfnetlink```
It really seems like my system loves to crash during pacman updates, leaving me to clean up the doodoo by chrooting in from a livedisk and re-running the last pacman install. The pacman log is not particularly helpful:
[2024-06-11T11:43:28+0200] [ALPM] running '00-timeshift-autosnap.hook'...
[2024-06-11T11:43:28+0200] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshif
t-autosnap.conf set to TRUE.
[2024-06-11T11:43:28+0200] [ALPM] transaction started
I guess the binary corruption of the log happened during the kernel panic. I recall that pacman was attempting to install some newer nvidia drivers and possibly a newer kernel.
Over the weekend, I ran a successful upgrade, this time pacman crashed. The only thing that happened between these events is that I put the system to sleep using systemctl --suspend, unplugged power and usb devices, and carried it around for a while.
For this reason, I still suspect that the kernel panic is related to some power management issues, but I don’t know how to debug this.
