TL;DR:
I sped up my boot by approximately 20 seconds by running freshclam
with a systemd.timer
instead of the default boot/oneshot/daemon option.
The long version:
freshclam
is supposed to update clamav
virus signature databases several times per day, but there is no need to update signature databases before even reaching graphical.target
So i set a systemd.timer
to run freshclam
every hour by following these guides / bug reports:
Archlinux wiki: Systemd/timers
Fedora bug report for clamav
golinuxcloud: Simple steps to install & configure ClamAV in CentOS 7
After doing so; systemd-analyze
reports boot time of 37 secs, which is fast considering my computer had a minimum boot time of 1 minute before this change.
my config, let me know if there’s a better way to do this:
/etc/systemd/system/.#clamav-freshclam.service
[Unit]
Wants=network-online.target
After=network-online.target
Description=ClamAV virus database updater
Documentation=man:freshclam(1) man:freshclam.conf(5) https://www.clamav.net/documents
If user wants it run from cron, don’t start the daemon.
#ConditionPathExists=!/etc/cron.d/clamav-freshclam
#Wants=network-online.target
#After=network-online.target
[Service]
ExecStart=/usr/bin/freshclam
#StandardOutput=syslog
#no need for [install] section due to systemd.timer
#[Install]
#WantedBy=timers.target
/etc/systemd/system/clamav-freshclam.timer
cat /etc/systemd/system/clamav-freshclam.timer
[Unit]
[Timer]
OnCalendar=--* *:30:00
OnBootSec=16min
[Install]
edit: successfully triggered.
$ systemctl status clamav-freshclam.service
● clamav-freshclam.service - ClamAV virus database updater
Loaded: loaded (/etc/systemd/system/clamav-freshclam.service; static)
Drop-In: /etc/systemd/system/clamav-freshclam.service.d
└─override.conf
Active: inactive (dead) since Sat 2021-05-29 01:30:27 CEST; 8min ago
TriggeredBy: ● clamav-freshclam.timer
Docs: man:freshclam(1)
man:freshclam(1)
Process: 427481 ExecStart=/usr/bin/freshclam (code=exited, status=0/SUCCESS)
Main PID: 427481 (code=exited, status=0/SUCCESS)
mai 29 01:30:27 jacob-satellite-l855 systemd[1]: Started ClamAV virus database updater.
mai 29 01:30:27 jacob-satellite-l855 freshclam[427481]: ClamAV update process started at Sat May 29 01:30:27 2021
mai 29 01:30:27 jacob-satellite-l855 freshclam[427481]: daily.cld database is up-to-date (version: 26184, sigs: 3983619, f-level: 63, builder: raynman)
mai 29 01:30:27 jacob-satellite-l855 freshclam[427481]: main.cvd database is up-to-date (version: 59, sigs: 4564902, f-level: 60, builder: sigmgr)
mai 29 01:30:27 jacob-satellite-l855 freshclam[427481]: bytecode.cvd database is up-to-date (version: 333, sigs: 92, f-level: 63, builder: awillia2)
mai 29 01:30:27 jacob-satellite-l855 systemd[1]: clamav-freshclam.service: Succeeded.
